Old 07-20-2006, 10:13 PM   #5476
wallyedmonds's Avatar
ok LOL im to old for this, but i think i understand. i just play with the car till i can drive it ok.
wallyedmonds is offline   Reply With Quote
Old 07-20-2006, 11:44 PM   #5477
Originally Posted by wallyedmonds
i thot adding shims to the rear uprights makes more camber change, to do roll center you change the lower arm position LOW MID HIGH. IDONO this stuff allways meses me up, if i need more traction i add shims to the upright,
Changing the length of the suspension arms determines camber change. Decreasing the length of the upper arm (or camber link, for the rear of the MTX), will result in more camber change as the suspension compresses.
Hope this provides some clarity, my original post covers everything regarding roll centre with the exception of its dynamic nature.
SNACKPACK is offline   Reply With Quote
Old 07-21-2006, 03:59 AM   #5478
when you add shims to the upright you change how aggressive the camber gain is.
Old 07-21-2006, 05:28 AM   #5479
nitro junkie just a few questions.
when you say "lower front roll centre" do you mean taking shims out from under the top a arm on the inside baulks?
also rear lower roll centres means placing the inside camber link at the lower hole right? (also "A" block = low right?)
or is it the other way around?
TomB is offline   Reply With Quote
Old 07-21-2006, 06:15 AM   #5480
Lowering the front roll centre would be REMOVING shims from under the inside of the front upper arms.
Placing the camber link lowe on the inside is RAISING the roll centre...
Rody is offline   Reply With Quote
Old 07-21-2006, 06:16 AM   #5481
Lowering the front roll centre would be ADDING shims from under the inside of the front upper arms.
Placing the camber link lower on the inside is RAISING the roll centre...
Old 07-21-2006, 08:22 AM   #5482
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
yes and shims under rear camber link as well
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 07-21-2006, 08:24 AM   #5483
ADJUSTING ROLL CENTER
The way that you adjust the roll center differs from one car to the next. However, the
theory is the same in that you want to change the angle of the suspension arms by
making them more “tilted” or more “flat” horizontally.
To fine-tune roll center, make changes to the angle of the upper arm.
To make larger changes to roll center, make changes to the angle of the lower arm.
It is very important that you have the same settings on the left and right sides of the car.
IMPORTANT!
Changing roll center settings impacts several other settings on the car, such as
downstops, camber, and ride height. When changing front or rear roll center, re-check
your other settings.
WHEELBASE
Wheelbase refers to the horizontal distance between the front and rear axles. Changes
to wheelbase can have a dramatic effect on the handling of your car, since it readjusts
the distribution of weight on the wheels, which adjusts traction. Not all R/C cars have
the option to adjust the wheelbase.
By adjusting the wheelbase at one end of the car, you affect the traction at that end of
the car. For example, by shortening the wheelbase at the rear of the car, you place more
weight over the rear wheels (resulting in more rear traction.)
EFFECTS OF WHEELBASE ADJUSTMENT
Longer
• Car more difficult to turn around sharp corners.
• Increased stability.
• Better handling over bumps and ruts.
• Better on more open tracks with high-speed corners.
Shorter
• Car turns sharp corners more easily.
• Increased steering response
• Better on tighter, more technical tracks
the way you adjust the wheelbase is the c spacers that clip on the actual front upper hinge pin it self
Futaba
Mugen
Novarossi
Byron's
Old 07-21-2006, 03:40 PM   #5484
rcracerdude's Avatar
Send a message via Yahoo to rcracerdude
Default MTX-4 FOR SALE
interested on buying an MTX-4? PLEASE CLICK HERE
Ken Gutierrez
derbybrosracing.com
rcracerdude is offline   Reply With Quote
Old 07-21-2006, 09:28 PM   #5485
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Wouldve already ripped the car from your hands if I didnt had one.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 07-21-2006, 10:51 PM   #5486
has any one had problems with the 3racing 2speed all af a sudden first starts sliping its a real pain in the ass what i did to fix the problem is shim up the screw and washer as well as lock tight the spacer first gear sits on other wise it would slip on the 2speed shaft
Futaba
Mugen
Novarossi
Byron's
Old 07-21-2006, 11:36 PM   #5487
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
This problem was an issue back about page 70 or 80. The 3 racing shaft, being titanium, just doesn't hold up. It wears down. Your best off using the K factory steel light weight hollow shaft.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 07-21-2006, 11:42 PM   #5488
asw7576's Avatar
Many said negative things about this particular products.
Back to original stuffs and you are set.
Old 07-22-2006, 01:48 AM   #5489
Roger's Avatar
IMPORTANT!
WHEELBASE
Longer
Shorter
Man, this sounds all too familiar. I've read this information somewhere. Oh, let me guess, this is from the set-up book for the xray electric car. Man, you typed all this exactly what the manual reads. Oh, by the way, there is NO WAY (unless modified) you can change the wheelbase of a MTX-4 or 3. Track width, you can change ( 198,199,200mm ), not wheelbase. Trust me, i've spoken to Swauger about this afew times and I had to modify the rear for a shorter wheelbase for my MTX-4.
"the way you adjust the wheelbase is the c spacers that clip on the actual front upper hinge pin it self "
Could you explain this to us. The " C spacer " (or caster clips) that you are reffering changes the caster, NOT THE WHEELBASE !! "
Now, on a xray FK05 or a T2, you can change the wheel base in the REAR ONLY !!!!
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 07-22-2006, 03:05 AM   #5490
its from the 1/10 all in one set up station not the xray electric car
read when i posted that 12:30 in the morning i was wasted just got home from the clubs
Futaba
Mugen
Novarossi
Byron's
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
