Mugen MTX-4
#5281
turbuckles
Do you have the PT# for the mtx4?
ICULKN
MTX4 LIFE
ICULKN
MTX4 LIFE
#5282
Originally Posted by GrandeGixxer
What are your tires cut to? If there is any overdrive or underdrive cut into the tires, it will feel like this. This is because either the front of rear tires are scrubbing because they have to travel a different distance to get around.
#5283
Originally Posted by blanks596
O.K., front tires wore to 59.08, and the Rear tires wore to 57.43. I'm using the 23 tooth side pulley so the overdrive ration chart shows that I'm somewhere around 1.116 for my overdrive or underdrive, but I don't know what these numbers mean. I think that they refer to the rotation ratio, but what is it that I'm looking for: anythinkg close to 1:1? I'm racing this weekend at Revelations.
#5284
O.K., so i think I've got the overdrive issue understood. 2mm split vs. 1mm split refers to the difference in tire cut (rear 60 & front 58 vs rear 60 & front 59) In general you want more tread on the rear because these cars are generally set up to have overdrive. This means that the front tires are spinning faster than the rears. A 2mm split would lessen the overdrive ratio more than a 1mm split, but for the most part, overdrive will still exist. By the end of the race do you want the front and rear tires to be as even as possible, or do you still want the rear to have more tread? Based on my tire wear readings ( rear 57.43 and front 59.08) would this suggest that my front end hooked up more than my rear or some combo between traction and driving style?
Thanx for the help, and I hope I'm not being too annoying
#5285
#5286
I believe it is caused by too much overdrive. It is also caused by how much you slide the rear end of the car around. It is pretty much a common thing for the rears to wear faster than the fronts do. What I usually do is measure the rears after a run and re-true the fronts to get the overdrive back.
#5288
#5291
BTW Blanks, you need to move the MTX-4 to the top of your list. It doesn't belong below that G4.
#5293
when is the ProSpec comin'?
#5294
Originally Posted by Roger
sohlman: I drilled out the hole to make my brace lighter. I also polished it so that I can wear it around my nick and have some BLING !!! Had dinner with Hananouchi and he told me that you'l be here in the bay during the GP San Jose. We all gotta hook up.
Just got back from vacation...I won't be able to make it out for the San Jose GP We'll check up another time.
#5295
i use the 25,the belt is titter and i hate overdrive, it wrecks the belts and the front drives and my tire size is the same split at the end of a race, and i found that when you use overdrive the rear tires wearout faster,i dont know why but they do so i run 18-25
