Old 07-06-2006, 03:05 AM   #5266
What tyre split do you guys find works well with the 25T front side pulley. I have always used the 24T. It will be used on a large flowing track.
Rody is offline   Reply With Quote
Old 07-06-2006, 07:56 AM   #5267
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by asw7576
I assume you are talking about the shims ( 1mm shim coin type ) underneath upper front hinge pins. That would change the front roll center of the car.
No shims would increase the front roll center thus creating more body roll and more grip. Very good setup for high speed sweeper corners and medium to high speed corners. Stability is good but there is tendency of understeer for some tight corners.
Thicker shims would decrease the front roll center and thus creating less body roll. Very good for slow corners or technical track.
You need to match your setup to your track.
Cool, I didn't know that, I'll try it out as well. What I was actually referring to are the shims that go on top, between the upper deck, and the front shock tower....
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 07-06-2006, 08:44 PM   #5268
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Snackpack is correct in his definition of roll center and how it alters the suspension characteristics. It seems that a lot of people have misinterpreted the concept.
Racing4Evo is offline   Reply With Quote
Old 07-06-2006, 08:47 PM   #5269
Racing4Evo's Avatar
Those are the caster clips. The more foward your upper arm is or the more clips you have behind the arm; the more off power steering and less on power steering you will have. If the arm is moved back or if the clips are placed in front of the arm; the less off power and more on power steering you will get.
Old 07-07-2006, 07:52 AM   #5270
Osiris 75's Avatar
Thanks!!
Chris Kemper
Old 07-07-2006, 09:13 AM   #5271
blanks596's Avatar
Trader Rating: 14 (100%+)
Default Slight drag
Please HElP!!! Has anyone experienced a slight drag that may be coming from the front end of the car (mtx4 w/oneway) When I roll the car with the side belt, there is drag, without it, there is no drag. The tension on the side belt is good. I figured it is coming from the front end and not the back because rolling without the side belt allows the rear drive train to roll freely without the front oneway engaging. Has anyone experienced anything similar?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 07-07-2006, 09:17 AM   #5272
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
What are your tires cut to? If there is any overdrive or underdrive cut into the tires, it will feel like this. This is because either the front of rear tires are scrubbing because they have to travel a different distance to get around.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 07-07-2006, 09:29 AM   #5273
blanks596's Avatar
Wow, I didn't check the diameters of tires that I was practicing with, but the tires that I will be racing this weekend start at 60.5 for both front and rear. I could say that rolling my car with these diameters produced a bit less drag. I have not changed anything from stock drive train set up to adjust the roll out. That is something that I have not learned yet
Max S
Old 07-07-2006, 12:09 PM   #5274
kidDynomite's Avatar
Joe's right, so you'll need to figure out what side pulley your running for whatever track conditions you're racing on. And measure out tire wear for the split or no split. Also, the rubber belts help free up the car some.
kidDynomite is offline   Reply With Quote
Old 07-07-2006, 12:11 PM   #5275
Osiris 75's Avatar
Is it normal for the teeth on the side belt to wear? I think I've run the car through about 3/4 of a gallon!!!
Chris Kemper
Old 07-07-2006, 12:22 PM   #5276
Send a message via MSN to Adim_X
Any of you guys going to the byrons race? IF so does anyone have a spare m8 spektrum module, mine are at horizon getting tuned to work for my m11. I thought i would have them back, but I am not going to get them in time. I can put down a deposit and return it sunday.
Adim_X is offline   Reply With Quote
Old 07-07-2006, 12:49 PM   #5277
Corse-R's Avatar
Check for an uneven alignment of the side pulleys and watch for dirt and debriss on the side pulleys, clean it completely, the dirt goes on the teeth of the pulleys and makes them to be smaller with more chances of belt slipping or teeth stripping.
Also check for pulley damage, change them if you see some damage and replace the belt for a new one.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-07-2006, 01:56 PM   #5278
What do you guys use to adjust your linkages (front toe, rear camber)? Right now I'm using the L-shaped allen wrenches
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 07-07-2006, 02:28 PM   #5279
Corse-R's Avatar
Switch to the titanium turnbuckles and use a 4mm open wrench (what I use is the 4mm Tamiya TRF key (keep it from my electric days, don't know if is available now).
Cheers,
Corse-R
Old 07-07-2006, 03:31 PM   #5280
Dave, you can buy Lunsford 4mm wrench for the Ti turnbuckles. I actually run the Lunsford turnbuckles after I saw a couple racers snap the Mugen Ti ones. There's just something about U.S. grade Ti that's incredibly strong. I use them on all my nitro vehicles. Never snapped one yet.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
