Old 06-28-2006, 07:49 PM   #5116
rocca30's Avatar
frist try to tighten up your 2-speed first . i dont think its you clutch but you can adjust your clutch with the motor still in your car.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 06-28-2006, 07:58 PM   #5117
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
To change the clutch in the car: There is a small hole just inboard of the 2nd gear pinion. You need to find a small L wrench that will fit in the hole and also key into the clutch nut. Once you do this, turn it until it hits something and then just turn the flywheel to either tighten or loosen the clutch nut.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 06-28-2006, 08:03 PM   #5118
Send a message via MSN to Adim_X
Thanks for the advice, that makes lot of sense. Are any of you guys in the midwest going to the rc pro series in cincinnati this weekend. It would be nice to meet some of you and hit you up for some help.
Adim_X is online now   Reply With Quote
Old 06-28-2006, 09:13 PM   #5119
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
any one runing the new chassis how dose it compair to the 3Racing one??
whats the price difference or which is best value for money and dose the same job??
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 06-28-2006, 09:14 PM   #5120
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You may have problems with both your 2-speed and your clutch.
The 2 speed is centrifugal and if the clutch doesn't engage right it won't change the 2-speed. If you think about it the 2 speed doesn't turn unless the spur gears turn. The spurs won't turn unless the clutch bell is turning, and the clutch bell won't turn if the clutch doesn't engage. I would work on getting a good launch of the car (clutch) and then get the 2-speed set. Obviously if the 2 speed shifts way too early then the car will not have good pull out of the corners as it will be in the wrong gear. Keep plugging away and it will be OK. If you are having an occasional problem with the rpm going way up before the clutch engages it could be the one way, or the shaft it rides on. I would work on the clutch and 2-speed first however.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-29-2006, 12:07 AM   #5121
Corse-R's Avatar
The Mugen 4mm chasis hits with the crankcase of Sirios, needs to be milled to clear out things.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-29-2006, 01:21 AM   #5122
Im running a STI in my MTX-4 with the Mugen 4mm Chassis. No clearance issues at all. Im running the engine mounts from the MTX-3 Prospec though so that may be the difference
Rody is offline   Reply With Quote
Old 06-29-2006, 01:30 AM   #5123
how would you compare it to the 3Racing chassis
Futaba
Mugen
Novarossi
Byron's
Old 06-29-2006, 07:14 AM   #5124
YBSLOW's Avatar
Originally Posted by Chris West
how do you guys get your cars under 1700 grams
K-Factory 2 speed parts
aluminum front axle
mugen titanium pillow balls
aluminum screws in radio tray
no aluminum parts where the originals are plastic
small throttle servo
if you want to loose another 50 grams use a AAA reciever pack.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-29-2006, 07:21 AM   #5125
typer's Avatar
Whats the effect of using 10k diff oil at the rear compared to 30k?
typer is offline   Reply With Quote
Old 06-29-2006, 08:09 AM   #5126
That will allow the rear wheels to counter rotate easier. This will lock down the rear end a little better.
Joe Cude
Old 06-29-2006, 09:18 AM   #5127
gfd2726's Avatar
Send a message via AIM to gfd2726
Mugen 4mm optional chassis is milled out and 3Racing 4mm chassis is not.
gfd2726 is offline   Reply With Quote
Old 06-29-2006, 09:46 AM   #5128
Trader Rating: 14 (100%+)
Where can I find a Carbon Fiber Battery Tray and a blade adjustable rear roll bar? I know 3Racing makes them but I dont really want to order from overseas (rc-mart).
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 06-29-2006, 09:52 AM   #5129
YBSLOW's Avatar
I've seen them on Ebay.
YBSLOW Racing
Old 06-29-2006, 11:00 AM   #5130
I've seen them on the 'Bay too but theyre from Dinball, hes overseas and I've heard numberous stories about him and rc-mart. Ive also seen the brass one that they claim that Mugen drivers used at the Nat's to lower thier CG
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
