Old 06-27-2006, 07:24 PM   #5101
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by TomB
i'd like to know this question also. does the Knack racing 0.8 module diff gears change the roll out of the car?
also what is the grading with the clutch shoes is this correct?
black; = softest, most bite
grey
yellow
red; hardest most slip
???im confused because i was told before the red was the most bite, thats why it wears out quicker. but i am now told that it is infact what i listed above. is this right?
i think your have your info upside down.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 06-27-2006, 07:28 PM   #5102
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
No problem Jam Rock.
As far as the clutch shoes goes;
black-hardest
grey-softer
yellow-softer than grey
red-softest.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 06-27-2006, 08:04 PM   #5103
sebby55's Avatar
Sohlman,Thanks for bringing Mike to the shop.First time meeting him an I must say the guy is a class act.
PS.Mike is Mike Swauger and the shop is Brooklyn Hobbies.
sebby55 is offline   Reply With Quote
Old 06-28-2006, 05:18 AM   #5104
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Originally Posted by stefan
Gotta have that:
how do i get my hands on one of these bad boys??
any idear of the cost of one
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 06-28-2006, 05:32 AM   #5105
Corse-R's Avatar
Being you in Australia, is very hard you can get one of those, is made by M-Mod who is in reality the European distributor of Mugen, maybe you can try to put your hands in one of those buying it on a European on-line shop.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-28-2006, 06:39 AM   #5106
dose any one know the weight of the car stock ??
i have alot of after market parts and want to know the difference
has any one compared the new chassi to the 3Racing 4mm
Futaba
Mugen
Novarossi
Byron's
Old 06-28-2006, 07:11 AM   #5107
4wheeldrift's Avatar
Default maintenance
Whats the consensus on regular maintenance required to keep the MTX 4 running top-notch. Some of the things I have questions about:
How often do you change the oils in the diffs and shocks?
How often do you inspect the bearings?
How often do you break the car all the way down?
4wheeldrift is offline   Reply With Quote
Old 06-28-2006, 07:11 AM   #5108
YBSLOW's Avatar
Weight depends alot on what electronics you use? Stock my car weighed 1765 grams and now weighs 1688 grams.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-28-2006, 07:25 AM   #5109
Trader Rating: 14 (100%+)
Diff and Shock Oils - Once every couple of races
Bearings - Clean and Lube after every race
Total tear down and cleaning - After every race
I dont know if anyone else is as anal as I am about cleaning the car part by part but its a great time to inspect for damage and wear. For bearings, i took the seals off and blasted the grease out then lubed them up with some high performance light machine oil and put the seals back on. I check them to make sure theyre not getting gritty. Shocks I usually leave alone unless I hear air in them its still good to rebuild them with fresh fluid and new seals.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 06-28-2006, 10:40 AM   #5110
Corse-R's Avatar
I change the oil on diffs and the shocks ever few months, all depending on how much I've raced. But as a guide, each 2 months or so... probably the shock oils are changed at races.
On each teardown.
After every race as a routine for cleaning. I inspect everything and change parts as needed.
Cheers,
Corse-R
Old 06-28-2006, 02:18 PM   #5111
Mad_killaH's Avatar
Default OS TZ 5port
Its that ok if i run my os 5port 40% ?
Mad_killaH is offline   Reply With Quote
Old 06-28-2006, 05:15 PM   #5112
Chris West's Avatar
Send a message via MSN to Chris West
how do you guys get your cars under 1700 grams
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 06-28-2006, 05:16 PM   #5113
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
what are the spring weights in lbs
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-28-2006, 06:49 PM   #5114
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Titanium.
Racing4Evo is offline   Reply With Quote
Old 06-28-2006, 07:39 PM   #5115
Send a message via MSN to Adim_X
Do you guys tune your clutch in the car, or do you remove the engine? I am having trouble getting my shift point correct on the car. Is it possible to have the clutch spring too tight, that the car will shift into second way to soon do to engine rpm? The shift point feels ok when the car is rolling, but if i gun it from a stop it seems as if my rpms may get a little high and the car shifts too soon. Is there anyway to adjust the clutch externally? How do you guys lock the flywheel, when you work on the clutch in the car? SOrry for all the questions!
Adim_X is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
