Old 06-26-2006, 06:57 PM   #5086
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
The kit comes with a locker, all you need is the outdrives, and the pins that go through them.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is online now   Reply With Quote
Old 06-26-2006, 07:43 PM   #5087
kidDynomite's Avatar
Originally Posted by Slo-MTX4
Thanks Kid,
Just one thing though, would this still be ok with the spool in the front instead of the geared diff or should i get some gears?
For this track, the diff worked out better because of the really tight turns. The spool didn't help the car dive into the turns. The diff lets you roll better into them without scrubbing to much speed. The last set-up gives the car just the right amount of roll (traction). I'd get some gears and build your self a diff anyways. If you have extra cash, build two fronts with 50k & 100k and another rear with 50k (high grip tracks). That way you'll be good for most conditions.
kidDynomite is offline   Reply With Quote
Old 06-26-2006, 07:44 PM   #5088
Originally Posted by GrandeGixxer
for a low bite track, 3* per side is common. I am assuming that it is 3* per side.
Correct. Thanks, Joe.
Old 06-26-2006, 07:49 PM   #5089
Have any of you guys tried the 0.8 module diff gears for the MTX-4? If anybody has used them, how were they and what did you like or dislike about them. I have a set but have not put them in yet.
Rody is offline   Reply With Quote
Old 06-26-2006, 07:50 PM   #5090
I usually run 30,000 in the front diff and 10,000 in the rear. Sometimes I will go down to 5,000 in the rear. I also have never had the need to run softer tirers in the front. I alwats run either the same or harder in the front.
Joe Cude
Old 06-26-2006, 08:00 PM   #5091
what do you mean 3mm over the ride height?
jam rock is offline   Reply With Quote
Old 06-26-2006, 08:00 PM   #5092
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
I run 10,000 in the rear aswell. My thinking also at the moment is that i need to get rid of the 2 hole pistons in the front shocks. I am running 600 in the front shocks aswell, but i think the it allows the front to dive to much and unsettle the rear of the car.
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 06-26-2006, 08:03 PM   #5093
Slo-MTX4's Avatar
My understanding of this would be so that you lift the car 3mm before the wheels come off the ground from its resting ride hieght.
Old 06-26-2006, 08:05 PM   #5094
Joe Cude
Old 06-26-2006, 08:23 PM   #5095
Scooby Horton's Avatar
Will it break? Thanks
Scooby Horton is offline   Reply With Quote
Old 06-26-2006, 09:20 PM   #5096
how do you measure the 3 mm? If you use a droop gauge what should the reading be? Currently I am at 0* on the front and 4* on the rear with ride height 4.5 front and 5.5 rear.
Old 06-27-2006, 03:56 AM   #5097
To measure from ride height, you use your ride height gauge. measure the ride height, compress the suspension, let it settle, then using a screwdriver or allen wrench or whatever, push the bottom of the car up from the center. As soon as the wheels lift off the board, measure again. Then check the rear droop. This is the only way to do it really.
Joe Cude
Old 06-27-2006, 05:25 AM   #5098
i'd like to know this question also. does the Knack racing 0.8 module diff gears change the roll out of the car?
also what is the grading with the clutch shoes is this correct?
black; = softest, most bite
grey
yellow
red; hardest most slip
???im confused because i was told before the red was the most bite, thats why it wears out quicker. but i am now told that it is infact what i listed above. is this right?
TomB is offline   Reply With Quote
Old 06-27-2006, 06:30 AM   #5099
sohlman's Avatar
Trader Rating: 89 (100%+)
grey
yellow
Here's a link to a MRX4 thread that explains the differences in clutch shoes.
http://www.rctech.net/forum/showpost...postcount=1320
Steve Sohl
sohlman is offline   Reply With Quote
Old 06-27-2006, 06:51 PM   #5100
Thanks!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
