Old 06-22-2006, 12:53 AM   #5056
Slo,
What is your rear ride height, maybe you could reduce it?
What position are your front shocks in, perhaps you could install them in a more verticle position?
Are you racing at the Winterchamps on the 24th?
Hope this helps
SNACKPACK is offline   Reply With Quote
Old 06-22-2006, 03:03 AM   #5057
madbeats's Avatar
Default thanks kidDynomite
Originally Posted by kidDynomite
You know what we'd say
Seriously, the 720 is killer, even the RRR/Evo is still the car to beat in my eyes. But the MTX-4 ... I'm diggin it. You can almost throw it down on any track with the stock setting and school with it. I would suggest to get an aftermarket rear shock tower like Skyline and at least front universals (Mugen). Get the parts to make a front diff (posted the parts you'll need). A set of dark blue springs and a 2.2 rear sway bar for tuning.
And spares, but that's a given. And thats basically all I can think of right now to help you get dialed. So that should make your wife happy.
kidDynomite
can you get the link scott posted , you are rigth the front universals is on the list
madbeats
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 06-22-2006, 03:37 AM   #5058
Originally Posted by Scott Fisher
You need:
T0258 Diff pulley
T0202 Diff cup
C0228 Diff gear (manual says it comes without the little o-rings
T0243 S3 (little o-rings)
T0244 S5 (bigger o-rings)
C0227 Spacer
B06401 2x6 screws..... you might already have some of these.
T0215 Joint pin
Hi Madbeats,
These are the parts required.
Old 06-22-2006, 04:30 AM   #5059
madbeats's Avatar
Default thanks
thanks man ,thats great
Originally Posted by SNACKPACK
Hi Madbeats,
Old 06-22-2006, 05:49 AM   #5060
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Slo,
Hope this helps
Hey SNACKPACK no i am not racing at the winterchamps this year i am in Townsville. I have tried 2 different ride heights, 4.5 & 5 in the front and 5 & 5.5 on the rear. The front shocks are in the stock hole and the rear are down one hole.
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 06-22-2006, 01:01 PM   #5061
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by Slo-MTX4
I run a front spool now. What i am having trouble with is coming into a corner the car is unpredictable and is loose in the rear the only thing that concerns me a bit with that setup of yours is the harder springs in the rear.
Have you tried the 25T pulley? I've been using it and it really makes the car easier to drive. I found that when I switched over to the 25t pulley, I was looking for steering instead of trying to get rid of it. I found the car to be more balanced.
Racing4Evo is offline   Reply With Quote
Old 06-22-2006, 02:14 PM   #5062
asw7576's Avatar
What about rear tires wear for 45 minutes ?
In MTX3 I use 23T front side pulley and the rear tires wear considerably lower rate than using 24T.
Old 06-22-2006, 02:22 PM   #5063
Racing4Evo's Avatar
It's always a compromise. At the last race, I had 1.1mm rear tire wear for 32min which in my opinion is not that bad since tire wear is generally high at that track.
Old 06-22-2006, 02:39 PM   #5064
asw7576's Avatar
I guess it's minimal...... Not bad at all.
I usually race with 61F / 65R ( 4mm split ) because I feel my car become harder to drive when the rear tires are about the same size with front.
Old 06-22-2006, 02:43 PM   #5065
Racing4Evo's Avatar
Have you tried using the 25t pulley, then using softer tires in the front (traction permitting) to even out the tire wear? You just need to change your setup a bit. It will feel different driving it but the car is more consistent in a long race that way.
Old 06-23-2006, 11:53 AM   #5066
hey guys,
i have only recently put together my mtx4 with o.s 12tz and i have no idea wats happening with it. When the car is on the starter box the wheels move quite fast even though i have realeased (counter clockwise) the throttle stop screw and if i release it to much the brakes fully closes the carb. when i put the car on the ground it just stops,when the brakes are on the engines stops and it does not move the slide valve. does anyone know how to fix this, any help will be apreciated
dienem is offline   Reply With Quote
Old 06-23-2006, 11:56 AM   #5067
Send a message via MSN to Adim_X
I am no expert but it sounds as if your clutch is engaging too soon, or is dragging. Set your idle so that you have a 1mm or so gap with the brakes compressed so that the brakes will not kill the engine. Now tighten your clutch spring a little bit and see if that helps. You car should idle without spinning the wheels. you may have to readjust your clutch a few times to get it right.
Adim_X is online now   Reply With Quote
Old 06-23-2006, 12:39 PM   #5068
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I believe Adim_X is correct.
You need tighten the clutch adjustment nut and set the idle back to stock settings. Then go from there.
Artificial-I is offline   Reply With Quote
Old 06-23-2006, 04:48 PM   #5069
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Check to see the clutch adjustment. I also think it could be the thrust bearing. If the thrust bearing doesnt work, the clutchbell will move with the movement of the engine and stall when you apply brake.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 06-24-2006, 11:28 AM   #5070
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
My clutch has at least 4-5 hours on it and I ahve had no issues with the thrust bearing. I do have a spare in my box for when it does though.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
