Old 06-14-2006, 08:32 PM   #4996
Send a message via MSN to Adim_X
How do you guys maintain your foam tires. Do you tru them after every run?
I ran the same set of tires all day, and my back tires are seriously cambered. I should I tru them back flat, or leave them as they are.
Adim_X is offline   Reply With Quote
Old 06-15-2006, 12:32 AM   #4997
asw7576's Avatar
If the tires are slightly cone inside that means you have set the chamber correctly. Generally people prefer front tires to wear flat and slightly cone at rear.
If the tires are cone inside heavily that means your negative chamber are too much, and vice versa.
Truing tires are up to you.
Old 06-15-2006, 05:51 AM   #4998
Corse-R's Avatar
If your tyres are coning outwards (like you were driving positive camber), you need to add more camber to the rear tyres until you wear them flat or almost flat (is virtually impossible to wear the rear external tyre almost flat due to the transfer of mass during cornering and getting out of turns, the tyre will scrub and doesn't matter what you do).
One day tried to compensate it at 100% and finished with very different suspension setups on the rear/inner and the rear/outer wheel and handling was quite different if you turn to left or right, car was twitchy but wear the tyres almost equal.
Sometimes you will see people putting a higher shore on the outer side and helps, but you need to take into account that one tyre will have less grip. You may look into this (higher shore on rear/outer or front/outer depending how your track punishes the tyres).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-15-2006, 06:08 AM   #4999
I built my car to the kit set up and I think it called for a -3 camber in the rear, and that did some serious coning of my tires. Should I not follow recommended camber settings, and just find a happy medium for tire wear?
Old 06-15-2006, 06:18 AM   #5000
asw7576's Avatar
cone inside or outside ?
Old 06-15-2006, 06:20 AM   #5001
itchy b's Avatar
sounds like you race on a tight track with mostly lower speed corners.
adjust camber till your tyres are wearing square and even and you should be right, you'll find that grip will be more consistent.
at the track i race at which has faster corners and sweepers i need to run 6 deg camber and the tyres only cone in very slightly which is pretty much what you want , so every track has its own requirments. hope that helps
cheers
joe
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-15-2006, 06:27 AM   #5002
Kyosho3PKRacer's Avatar
Send a message via AIM to Kyosho3PKRacer Send a message via MSN to Kyosho3PKRacer
Wow Joe 6deg? What track is that? EC? or somwhere else.
Kyosho3PKRacer is offline   Reply With Quote
Old 06-15-2006, 06:35 AM   #5003
asw7576's Avatar
6 degree ? Wow !!
Mine is 4.5 Left - 4 Right for Rear tires.
And 4 Left - 3.5 Right for Front tires.
Old 06-15-2006, 07:57 AM   #5004
itchy b's Avatar
hey matt, you checking out what the competition is up to eh?
EX1.5-SC10 4x4
Old 06-15-2006, 08:07 AM   #5005
itchy b's Avatar
Originally Posted by asw7576
6 degree ? Wow !!
yep, its the moorebank track in sydney, my car reaches top revs 5-10 mtrs from the end of the straight using 18/24 pinions, the corner can be taken almost full speed.
i believe that the track can be played on vrc , so give it a go, you'll see what i mean
your track in the pictures is a beauty, nice layout
EX1.5-SC10 4x4
Old 06-15-2006, 08:37 AM   #5006
Yeah trying to see what people are doing over in the Mugen camp get some secrets and take them back to RRR thread
Should be a good meet this Sunday anyway looking forward to it.
Old 06-15-2006, 09:21 AM   #5007
RClover's Avatar
Hi Corse-R...how's everybody...long time no see...
RClover is offline   Reply With Quote
Old 06-15-2006, 02:14 PM   #5008
Corse-R's Avatar
Yep... so much time, how's everything by there?
Cheers,
Corse-R
Old 06-15-2006, 03:29 PM   #5009
Dialed Pile's Avatar
Originally Posted by jeff whiting
Oops I just re-read my post and I missed a word.
I just had this same problem. I think you will find that if you take off that rear arm you will discover one of the following. A broken rear arm at the rear pin location or the the lower pin is bent. In my case the lower arm was broken where the pin goes through and allowed the arm to move forward and hit the spur but NOT enough to really be that noticable or come completly off
Right on! Thanks man, broken arm at pin.
Thank you
MUGEN
Dialed Pile is offline   Reply With Quote
Old 06-18-2006, 06:29 PM   #5010
Seisick's Avatar
congrats to ishitani for 2nd place at the nationals and swauger for 3rd and TQ.
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
