Old 06-07-2006, 12:56 PM   #4936
GK
Suspended
Originally Posted by asw7576
Can I use MTX3 flywheel to MTX4 ?
Yes
GK is offline   Reply With Quote
Old 06-07-2006, 01:30 PM   #4937
Send a message via MSN to Adim_X
Thanks for the replies guys. I will try those diameters.
Adim_X is online now   Reply With Quote
Old 06-07-2006, 09:41 PM   #4938
asw7576's Avatar
Originally Posted by GK
Yes
Are you sure ?
Anybody ?
Old 06-07-2006, 09:56 PM   #4939
Chris West's Avatar
Send a message via MSN to Chris West
yes you can use the mtx3 flywheel the only difference is the width of the contact patch that comes in contact with your starter box, i have used mtx3 flywheel in mtx4 when i swaped engines so it does fit
Chris
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 06-08-2006, 05:10 AM   #4940
MAVICXXX's Avatar
Chris
hows the weight different?
MAVICXXX is offline   Reply With Quote
Old 06-08-2006, 05:17 AM   #4941
MAVICXXX's Avatar
Originally Posted by rcfoolz
shortening the wheel base is suppose to help in HIGH bite situation to allow the car to turn better.......in fast direction changes, however in large sweeping turns, it would do just the opposite. It would be good if you are running on small electric tracks.
If I am incorrect, please someone correct me. This is just theory. However, I don't realy see a need to do this, there is way too many other adjustments that can be done to make the car do what you want.
yep..it mostly helps you to take tight corners better instead of your car become too sensitive..and i do try out at our local hi speed swinger sweeper..looks and feels ok to me..sorry i cant snap a photo,but roughly the place that i did is ..if you look at the fron bulkhead,at the rear part,there is a 1mm extra portion you can take as aguide to cut,but its not only that,you will have to cater also the fron sway mounting and also the right bulhead surface..sound like too complicated,but if you spend bout 2hrs,then you get it right..then apply thick shims or washer to make the arm move/stay backwards,so mean your front wheelbase already closer to the rear..if i m not mistaken,it gona be 260mm++.
i didnt loose my rear too with the modification..r40 has it,but its from the rear..
Old 06-08-2006, 05:21 AM   #4942
MAVICXXX's Avatar
Originally Posted by Adim_X
What diameters are you guys truing your tires at. I am a beginner and will probably scrub a lot of the foam off due to poor driving. I would like my foams to last, while still getting decent performance. thanks
bro..it depends to what front side pulley you are using?24?25?24 you will have to take front and rear diameter difference by 2.5mm,then you wil get all four tyres rotates equally..25 pulley will gives you a full 4wd at same tyre diameter..
comeback to your tracl surface and layout..maybe you need big or less tyre diameter for it..this you will have to try out..
try go mugen web and look for gear ratio and roll out chart..study that ez chart and you wil get it..good luck.
Old 06-08-2006, 05:25 AM   #4943
MAVICXXX's Avatar
Originally Posted by itchy b
mabe you can try and adjust the pulley across towards the side that is rubbing to centralise it better.
maybe the pin has'nt located into the slot properly also
yep..eventhough it is sitting on..doesnt mean it is ok..i meant you will have to see it without belt assembly,look for if the flange or adaptor you call it is little voble,then this can contributes to belt wear,especialy urethane belt..if it is,change the adaptor..the plastic pulley might be affected too..
Old 06-08-2006, 05:33 AM   #4944
MAVICXXX's Avatar
This is what I do in my car :;
Side Belt Tensioner : flip it so it is directed toward the front.
Upper Deck Design : I guess nothing you can do with it without major modification.
4mm or 6mm Rear Shock Tower : Use 3x16mm countersunk screws to joint the shock tower and bulkhead. Also use 3x10mm or 3x12mm countersunk for top bulkhead.
Clutchbell : Use longer screws like 3x14mm ?
Fuel Tank : Use short piping and 1 novarossi filter to keep it below 75cc.
I also switch back to original mtx4 brake disc ( thin ). MTX3 prospec disc are too thick and it is too close to carburator ( novarossi or jp engines ).
if you turn it front,you will have to press the tension bearing lower..mechanical tensioner theory,shouldt go closer to the mid point coz you will loose the belt play smoothness and ez belt displacement when vibrates..unles you really apply the tension.That my question to Kenji,after market tensioner place it forward,Kenji replied that way..the purpose is to avoid the belt touching the manefol and most efficient to be at the place..but they will think of an alternative or just let it be as it does not affect the performance..
as for the brake disc,i am using kfactory disc..
Old 06-08-2006, 06:48 AM   #4945
Seisick's Avatar
the highly used sidebelt on my mtx4 was very loose when using the 24t pulley, so when a teeth of the belt got ripped I figured a way to apply higher tension, the tensioner has no more movement and the belt in that part almost touches each other, so I used the belt tensioner of the mtx3, and with a little piece of graphite from a a mtx3 front tower broken, I now have a belt tensioner that goes next to the 24t pulley, the sidebelt now has the right tension both front and rear and just took a few grams and less than $10 bucks, the best is that your sidebelt will last longer since therea are no more missing teeth. by the way I use stock belt!
will post pics!
happy racing!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 06-08-2006, 09:37 AM   #4946
Jammin'Trey's Avatar
Send a message via ICQ to Jammin'Trey
Hey does anyone know when the Prospec version is going to be out?
Jammin'Trey is offline   Reply With Quote
Old 06-08-2006, 01:18 PM   #4947
gfd2726's Avatar
Send a message via AIM to gfd2726
I am using Kyosho RRR's side belt on my MTX4 and it's perfect. I am still using the same belt since day 1.
gfd2726 is offline   Reply With Quote
Old 06-08-2006, 01:32 PM   #4948
stefan's Avatar
Send a message via AIM to stefan
August 22, 2006, 12:34 p.m.,pacific time
stefan is offline   Reply With Quote
Old 06-08-2006, 02:06 PM   #4949
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Gotta make room on my credit card!!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-08-2006, 02:46 PM   #4950
Really is there a release date?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
