Old 06-04-2006, 11:16 PM   #4876
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by THE DOCTOR
New belts and gears and they broke again. The top 3 guys all had MTX-4's and we all broke our belts. The other two put new belts on before the 30 min main and still broke. The other two dropped out so I had the lead from the 15 min mark and at the last fuel stop I broke. I am going to try using the stock belts again.
The stock urethane belts will definitely last longer, but my side rubber belt lasted for 3 months, the front rubber belt lasted for 4 months and I changed out the rear one as a precaution at the 4 month mark but it never stripped or broke. FYI, the front and side belt stripped but did not break.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-05-2006, 12:30 AM   #4877
chookgb's Avatar
Trader Rating: 26 (100%+)
Originally Posted by RR
Hi asw7576,
are the spur and pinion gears really becoming thinner???
i really need to know, cos yesterday during my club race.
I stripped my 2nd speed spur on every qualifying heat.
and I'm running stock pinion and spurs setup(17/23 n 59/53).
not only myself... the whole team is suffering from sudden strange happening
and we never had this problem before!!!
Pls enlighten
cos we've up and coming big race next month
HELP!!!!!
had the same problems the stock aluminium pinions wear and then are prone to stripping spurs get yourself some steel pinions they are a must
chookgb is offline   Reply With Quote
Old 06-05-2006, 12:41 AM   #4878
RR
RR's Avatar
Send a message via AIM to RR
Hi chookgb
we've actually change to a new pinion...
and it stripped again...
could it be the quality of the spurs?
RR is offline   Reply With Quote
Old 06-05-2006, 01:09 AM   #4879
chookgb's Avatar
Hi chookgb
did you put a steel pinion or standard pinion on, which are aluminium?
Old 06-05-2006, 01:26 AM   #4880
itchy b's Avatar
Originally Posted by asw7576
They are steel disc.
Yes, you can use metalic brake pads but I don't think it will fit ( I guess they are too thick so keep it original or buy the yellow pads ).
g'day asw7576,
after further inspection of vented disk and pad clearence i had a go at fitting the metalic app pads in there as the pads that were fitted were a home made specials(looks like bits of brake pad from a family car glued onto backing plate )which together were thicker than the app pads
i only had to ream out the holes with a dremell as hole centres were 1-2mm closer together, screwed them in and adjusted them and "TADDAH"!
they worked wonderfully well
good reliable braking and no brake fade to speak of throughout the day
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-05-2006, 01:31 AM   #4881
RR
RR's Avatar
oh... i put on the standard pinion which is aluminium.
you mean... even new standard pinion will strip the spurs too
Old 06-05-2006, 02:02 AM   #4882
itchy b's Avatar
sounds like the gear mesh might be set a little too loose,
when you set the mesh try removing 1st gear spur and setting mesh to 2nd gear fairly close so you only have a tiny amount of movement back and forth, then refit 1st gear and make sure everything spins freely and you should'nt strip gears so frequently.
i set mine up this way just as a friend showed me and have'nt stripped a gear yet in 110 minutes if racing and practice
cheers
joe
EX1.5-SC10 4x4
Old 06-05-2006, 03:02 AM   #4883
chookgb's Avatar
i am presuming your mesh is fine and your mount screws are all secure, i feel the problem lies mainly in the flex in the chassis which will be solved with the 4mm chassis, but as i said the only consistant solve i have had is to install the optional mugen steel pinions with new spur gears and also to make sure the clutch bell bearings are in good order and the clutch bell is shimmed so there is very little end float to prevent any side ways movement,also the 2 speed housing bearing must be checked as i have had more than one creep out of position which is another source of problems.
Old 06-05-2006, 03:40 AM   #4884
chippy's Avatar
Donít forget the carbon fiber battery tray also helped buy eliminating some of the chassis flex.
Since doing the above havent stripped a spur gear
chippy is offline   Reply With Quote
Old 06-05-2006, 07:56 AM   #4885
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Well, I had my first experience of stripping my 1st gear twice this weekend!!!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-05-2006, 07:58 AM   #4886
Osiris 75's Avatar
I even tried the MTX3 Spur gears, because I was told the teeth were a little thicker. Stripped that one too!!
Chris Kemper
Old 06-05-2006, 08:18 AM   #4887
stefan's Avatar
Send a message via AIM to stefan
What I see often, is that people adjust their pinions and spurs and the 1st gear is fine, but the engine is mounted at an angle and they have way too much play on 2nd gear.
It's a good idea, to take 1st gear spur off, adjust the gap on 2nd gear and the put 1st gear back on and fine adjust.
I haven't stripped a spur yet doing this.
stefan is offline   Reply With Quote
Old 06-05-2006, 08:39 AM   #4888
itchy b's Avatar
EX1.5-SC10 4x4
Old 06-05-2006, 10:47 AM   #4889
RR
RR's Avatar
Default thanks a lot Guys
Thanks a lot guys, appreciated the kind support in answering my question
but unfortunately, the advises that you all had gave
I've been there, and done that already
thanks again guys
Old 06-05-2006, 12:01 PM   #4890
Seisick's Avatar
Default no more stripping
on my first race with the mtx4 about 3 weeks ago, I stripped 2 spurs within an hour, I realized that the mtx4 needs 100% perfect alignment and with endplay, this is what I did to prevent stripping spurs, so far my 3rd spur has lasted since then! that's over 4 hours racing and they're perfect!
1) one piece engine mount, used the kyosho rrr or G4 since I have no access for the 3 racing,kawahara or skyline.
2) when using one of these 2 engine mounts, the engine was located too much within the chasis, so i had to use a spacer between the collect and the front bearing of the engine.
3) 5x7mm 0.1mm associated shims used between all the 5x8mm bearings, clutch nut and thrust bearing, the centax is freer since there's no friction among the 3 bearings, thrust bearing, and clutch bell against the shoe!
4) since I used a one piece engine mount not designed for the mtx4, I needed to add space for the bearing stopper h0756 where the thust bearing sits, I use the 3x4.5mm associated shim.
5) the endplay for the centax is minimun since I use shims before the first clutch bearing, the centax is freer, and when the clutch engage with the perfect alignment the spurs are always in contact with the steel pinions.
beware that as the clutch shoe wears ( i use yellow) you'll have to readjust the space between the shoe and bell and therefore the hole alignment, it's worth at the end cuz my 2nd spur has lasted more than 4 hours of racing.
6) I forgot to mention that I also use a 6x8 0.1mm shim between the pin and the bearing for the 2nd gear hub, cuz I noticed that there was a little touching with the rear brace, it was this or dremeling the rear brace, i preferred the shim!
7) 3x10mm cap screws for the engine mount and 3x10mm flat head screws for the chassis, extra 2mm tightening!
5x7 shims associated 2293
3x4.5 shims associated 2321
6x8 shims, can't find the number but I think they're hpi
happy racing!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
