Old 06-01-2006, 08:30 PM   #4846
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by THE DOCTOR
Is anyone else having trouble making it thru a whole race day on one set of rubber belts. The side belt is fine but the front and rear belts end up bending forward on the first run and after four runs it's time to change them before the main.
My rubber belts last about 2 months. 3 gallons of running. If you are breaking them in one day, I would look at your pulleys and drivetrain stuff.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-01-2006, 08:55 PM   #4847
Trader Rating: 15 (100%+)
Originally Posted by GrandeGixxer
I am still running the original front and rear belts from my car. They have at least 4 hours on them. I still have the original side belt that I run for practice. I then put a newer one on for the races. It is worn, but doesn't skip or anything. I think the belts are fine.
Are they rubber, option belts or the originals?
THE DOCTOR is offline   Reply With Quote
Old 06-01-2006, 08:56 PM   #4848
They don't break but the teeth get ripped off of them.
Old 06-01-2006, 09:32 PM   #4849
Roger's Avatar
Thats about right for me also. 3-3.5 gallons along with 2 months of runtime. As Scott said, check all your pulleys.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 06-01-2006, 09:33 PM   #4850
Derby Bros Racing's Avatar
Originally Posted by PROVK
Jo
will post some when I get home.
Will be testing tommorow.
How do you post pictures?
provk
i upload my pics to photobucket.com (any free photo web hosting will do) and then copy the URL address. you then click on "Insert Image" and paste the URL.
doctor
check your diff tensioners also (two rings that hold the diff and also apply tension to the belt)... make sure they are BOTH in the same position. another thing that could eat it up is when the tension is too loose. so put the tension to the max. the car won't free roll as good but will be easy on the belts....
Derby Bros Racing is offline   Reply With Quote
Old 06-01-2006, 10:14 PM   #4851
PROVK's Avatar
Trader Rating: 14 (100%+)
You take the chassis brace off, pop the linkage, remove the belt, take the 4 mounting screws out and slide it out the back. How is that tearing apart the whole car? I can get the engine in or out in about 2 minutes. Easy Day.
Try that with Mugen 4mm chassis, mtx-3 prosepec disk and engine mounts
PROVK is offline   Reply With Quote
Old 06-02-2006, 05:08 AM   #4852
the mugen 4mm is not milled out for a one peice engine mount either....
TomB is offline   Reply With Quote
Old 06-02-2006, 05:53 AM   #4853
Two weeks ago I put new pulleys in the front but not in the rear and it did the same thing. I was wondering if it was to loose? I have always put it on the loosest setting. The tension always seemed to be good for new belts.
I was also wondering if it could be from the bumpy sections in our track when we are on the throtle wide open in a big sweeper? You can hear the car skipping on the tops of them.
I am thinking of going back to the stock belts because of the cost and labor issue.
Old 06-02-2006, 06:20 AM   #4854
GrandeGixxer's Avatar
Rubbers
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 06-02-2006, 11:11 AM   #4855
Rubbers
For your personal protection. The question is are you selfish and turn the ribs inside out.
Old 06-02-2006, 11:23 AM   #4856
I am only selfish half the time. I let her get pleasure on the other half. Studded are better though.
Joe Cude
Old 06-02-2006, 11:38 AM   #4857
yeah you don't want the belts to skip on a nitro car. i was surprised that i could get away with it with mod electric (really loose setting for more efficiency). give the stiffest setting a try
Old 06-02-2006, 11:51 AM   #4858
asw7576's Avatar
Your belt setting was too loose.
5mm - 6mm play is enough for front and rear belts. 8mm - 9mm play for middle belt. The power from engine is more powerful than EP cars, so always keep them little bit tight.
I soaked and cleaned the belts with Armour All liquids for durability and longetivity. Most of my belts last very long time except if damage occured from crashes or stones went inside the bulkhead.
I race once or twice a month.
Old 06-02-2006, 01:09 PM   #4859
Smile
I'm still going strong with mine. I don't race my car as much as I would like to, but I would say that I have well over 4 hours on my belts.
mgreen is offline   Reply With Quote
Old 06-02-2006, 02:02 PM   #4860
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Only 4 hours??? I may have to try that Armor All technique!!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
