Old 05-24-2006, 12:10 AM   #4741
Derby Bros Racing's Avatar
Originally Posted by jam rock
Does anybody know how to get tghe car to stop pushing on and off power.
if it's pushing both on and off power, i suggest you soften the front end of the car or stiffen the rear. this can be done with tires, springs, diff oil, etc.
i'd start with tires. softer overall will make the car not slide through the turns that feels like a push. it may be your track condition being very slippery also.
make the front swaybar flat or don't use and/or stiffen the rear swaybar.
if you have stock rear diff setup which is 10k, go to like 30k or 50k. this will help the onpower steering.
take off the spacers on the rear uprights where the rear upper links connect.
the body... use a high steering characteristic body like a stratus 3.1 or the parma type m
hope this helps
Derby Bros Racing is offline   Reply With Quote
Old 05-24-2006, 07:30 AM   #4742
Send a message via MSN to ZELOKO
Originally Posted by SalvadoriRacing
no way........
i was at the track during this event and none of mugens were checked and approved......
i have 2 drivers in my team and the fuel line of their cars is the shortest as possible, both tanks were measured and both held 76ml........
most cars were checked at room temp because when the problem occured all mtx4 owners took their cars to the technical inspection and checked their tanks......so the question about the tank and fuel temperature is eliminated......
I think the filter installed in the tank is decomposable and this is causing the problem with fuel capacity.......
I also heard that at the 1/8 offroad WC the Mugen guys were matching fuel tanks because some tanks could be filled up to 133ml
Perfect problem explanation... LoL...
I haven't had thought about the fuel filter... can be..
ZELOKO is offline   Reply With Quote
Old 05-24-2006, 09:46 AM   #4743
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
SOLOARTIST 702 WAS HERE SOLOARTIST702 WAS HERE
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 05-24-2006, 07:38 PM   #4744
Smile
Is it just me or is the one-way real difficult to take out of the car. Maybe I'm doing something wrong but I removed the 4 center screws for diff access and then the 4 outer screws that hold the up arms and control the roll-center. What am I doing wrong?
By the way, this car is amazing. Every time I race it, I always leave real impressed.
mgreen is offline   Reply With Quote
Old 05-24-2006, 07:55 PM   #4745
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
It is difficult. You have to yank it out and twist it but it will come out. Not really an "easy access" design as they claim. By the way the V-One RRR is the same thing.
Racing4Evo is offline   Reply With Quote
Old 05-24-2006, 08:16 PM   #4746
thanks for all the comments re pushing. I was wondering if this is a general problem with the car or just me and my setup. I have tried most of the things you all have said here but the car still pushes. The following is what i have done so far
1. change front diff oil to 450wt, 600wt in the rear
2. raise front roll center by .5mm
3. use 2.5mm rear sway bar
4. droop set to 0 in front and 4 in rear
5. caster set to 0.....no spacers in front of arm....all at rear
6. blue springs on front lowest hole, grey on rear at hole 4
7. using 37 shore front and rear
8. reduce rear spacer to 1mm instead of 2mm.
I will try it at a different track this weekend.
jam rock is offline   Reply With Quote
Old 05-24-2006, 08:26 PM   #4747
iwk2much's Avatar
What tire split are you running?
Mike Strack
iwk2much is offline   Reply With Quote
Old 05-24-2006, 09:12 PM   #4748
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Does anyone know where I can find Micro Systems Tires, I did search for them but no luck...
thanks ALL
Jason
jscamry is offline   Reply With Quote
Old 05-24-2006, 09:25 PM   #4749
PROVK's Avatar
Trader Rating: 14 (100%+)
Change one thing at a time!!
Thats the only way you ll learn how to set up a car
PROVK is offline   Reply With Quote
Old 05-24-2006, 10:14 PM   #4750
gfd2726's Avatar
Send a message via AIM to gfd2726
thanks ALL
Jason
Try contact Sam at http://www.kamikazetoysandhobbies.com/home.htm
I belive he has them in stock.
gfd2726 is offline   Reply With Quote
Old 05-24-2006, 11:36 PM   #4751
Team Kamikaze's Avatar
Thanks GORDON !!! I do have them in stock just email me at [email protected] thanks
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-25-2006, 01:28 AM   #4752
Originally Posted by ogreasurada
yeah, i saw these on rc-toro
silverM3 is offline   Reply With Quote
Old 05-25-2006, 01:42 AM   #4753
stefan's Avatar
Send a message via AIM to stefan
Not diff but shock oil...
stefan is offline   Reply With Quote
Old 05-25-2006, 07:36 PM   #4754
yes,,,,,sorry not diff oil but shock oil. I am also running a 2mm split. all these changes was done one at a time and they all improved to handling but the car still pushes.
Old 05-25-2006, 07:40 PM   #4755
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Try going light blue springs front and blue springs in the back. You said you had the 2.5mm bar, try making it more stiff. What diff oil you using? Try going softer oil upfront and harder oil back.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
