Old 05-13-2006, 08:17 PM   #4606
dg8one's Avatar
ISAAC
youre kit came with spool all you need is the outdrive from x3 and pin that's it
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 05-13-2006, 08:18 PM   #4607
dg8one's Avatar
Originally Posted by Jo Gutierrez
when you need more parts or anything else, try calling/emailing sam of www.kamikazercracing.com (pinoy din )
hey jo
salamat...... i solve that problem
TOKWA'T BABOY LTD
Old 05-13-2006, 08:25 PM   #4608
Originally Posted by dg8one
ISAAC
Ok.
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 05-13-2006, 08:31 PM   #4609
dg8one's Avatar
hey guys
when is this motor gonna hit the US?
and who, where i can get one?
thanks
TOKWA'T BABOY LTD
Old 05-13-2006, 08:32 PM   #4610
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
hey guys
thanks
www.rc-champ.co.jp has them i believe. Price should be around $300 shipped.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 05-14-2006, 07:01 PM   #4611
Send a message via MSN to Adim_X
Hello,
Any of you guys ever run in cincinati? What shore of foams should I use? and what gearing should I run? I have a stock mtx 4.
Adim_X is online now   Reply With Quote
Old 05-14-2006, 07:29 PM   #4612
ira
ira's Avatar
Trader Rating: 18 (100%+)
I was just there this past weekend, I ran 40 shore tires front and rear.
Gearing was 18/24 and 59/52, my front tire size was 57mm and the rear was 59mm. Stock setup works good when the traction is up.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 05-14-2006, 09:02 PM   #4613
PROVK's Avatar
Trader Rating: 14 (100%+)
Hi all
It seems pretty hard to get 1mm offset foams.
Is the any problems using a zero offset wheel ? and
which tyres are best in low grip situations.
Thank you
PROVK is offline   Reply With Quote
Old 05-14-2006, 09:52 PM   #4614
Speedbug's Avatar
Originally Posted by PROVK
Hi all
Thank you
0 degree offset wheels do run a bit close to the hubs, especially while cornering. However there are a couple ways around it.
1. If you are using the standard plastic hexes, you can put a 1mm washer between the bearing and the hex.
2. If you have alloy hexes with the locking screws, you can just space it out from the bearing and use the lock screw to hold it in place on the axel.
I personally run the alloy hexes but also use the washer for added security in case you cop a hit in the rear wheel, it won't push in.
Hope this helps!
Speedbug is offline   Reply With Quote
Old 05-14-2006, 10:19 PM   #4615
raffaelli's Avatar
where can i get 3 Racing stuff in the US?
24ITA
raffaelli is offline   Reply With Quote
Old 05-14-2006, 10:53 PM   #4616
PROVK's Avatar
Hope this helps!
Thank you
Old 05-15-2006, 03:05 AM   #4617
itchy b's Avatar
g'day all, ran my mtx4 on the weekend at my home track[medium size, low bite, bumpy suface] using purple springs, rear lower arm roll in mid hole 2 deg toe. car was verry loose on power, a fellow racer suggested i remove rear sway bar as i only have the 2.5mm one i did this and the car hooked up realy good, but rolled around in the rear a lot and needed to get some stearing back so i reduced the front droop to 1mm up from ride height and it did the trick as the car turned in to the corners quite good.
1st qualifier; started 2 laps down(the tz5p runs much better if i remember to fill the tank with fuel you learn something new evey day ) once under way the car ran verry good and easier to drive consistently quicker than my g4 that i've been running for 18 months.
2nd qualifier; filled tank car was still good and finished 2nd with 19 laps, 5.06 min, 2 laps gained from 1st qualifier and a personal best by 8 sec!
3rd qualifier; increased ride height to clear rubberised repairs to cracks in ashfelt surface(some rubbing of chassis in 2nd qualifier) got the jump on the field in the out lap and gapped them to win it and set another personal best 19 laps 5.0145 min to quallify 4th in the a main! another pb
a final; started off slow, took a couple of minutes to get on the pace as tyres wore down a bit, then got good pace out of it. after the third pit stop of the 15 min final the car started to go side ways out of the corners on anything but light throttle, just like it would with a stripped belt,but would accelerate in a straight line with no problems untill i get to the corners again.
it was still driveable if i took it easy at the corners and bends so i continued till the finishand was about midfield i think.
when i inspected the car todey under the light i found the belts had no teeth missing although the rear belt is a little worn on the back of each tooth, also the side belt skips on the rear side pulley when i turn the front or rear wheels with the other wheels pressed to the bench to stop them turning, pluss the rear side pulley is a little worn along the middle of the teeth.
is this the most likely cause of the spin out problem?
is their another area i should be looking at?
also is there a good way to find rear traction on this set up using a 2.1mm rear sway barr that will be consistent to drive?
any help would be appreciated
thanks
joe
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-15-2006, 03:53 AM   #4618
itchy b's Avatar
on a closer look at the car under lights i found that the left front cvd pin has popped out of the hole and i only had 3 wheel drive, no wonder it got tail happy its a shame that happened as the car was really coming on strong at that stage of the race
EX1.5-SC10 4x4
Old 05-15-2006, 10:49 AM   #4619
Trader Rating: 15 (100%+)
Hi all
Thank you
Jaco's new rims are 1 deg offsets. They say that they are 0 offset but they are really 1 deg,
THE DOCTOR is offline   Reply With Quote
Old 05-15-2006, 12:04 PM   #4620
asw7576's Avatar
Are all Kawahara tires 2 mm offset ?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
