Old 05-03-2006, 09:21 PM   #4561
Derby Bros Racing's Avatar
Originally Posted by richey
Thanks for the update....
hi rich,
do you have the parma type m body instock? the mugen drivers seem to like them a lot last vegas race...
Derby Bros Racing is offline   Reply With Quote
Old 05-03-2006, 09:38 PM   #4562
Team Kamikaze's Avatar
Originally Posted by Jo Gutierrez
hi rich,
MERON
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-03-2006, 10:22 PM   #4563
rmdhawaii's Avatar
Thanks Jo! Appreciate the explanation and reasoning behind your decision.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-03-2006, 10:24 PM   #4564
richey's Avatar
Send a message via MSN to richey
hi rich,
Yes i have three left.
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 05-05-2006, 02:06 AM   #4565
itchy b's Avatar
Originally Posted by Dreamcatcher
What setup did you use?
sorry about that d.c, city life has made me a bit slow
as to the set up i dont really know because my friend set it up on his hudy, and to educate me on the finer points of the mugen machine.
i will be racing it this sunday on the same track and it will get a spray of vht sunay morning so it'll be verry different again, i'll post after racing, should know whats what then whether good or bad
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-07-2006, 01:41 AM   #4566
typer's Avatar
Does the serpent 710 has the same clutch shoe size with the mtx4?
typer is offline   Reply With Quote
Old 05-07-2006, 05:12 PM   #4567
Bigtbone's Avatar
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
Send a message via AIM to Bigtbone
ANyone know of a shop that has the rear universals in stock?
Bigtbone is offline   Reply With Quote
Old 05-08-2006, 12:08 AM   #4568
try calling leemuse. you will find his phone number at www.gasrccar.com
or you can also try www.nitrohouse.com
good luck.. hope this helps
Old 05-08-2006, 01:44 AM   #4569
richey's Avatar
I have them.
Old 05-08-2006, 04:37 AM   #4570
itchy b's Avatar
went racing the mtx4 for the first time yesterdayon a different one to the one i usually race on and am very happy with how the car performed, not so happy with how the organic part of the car did though ran 6deg on rear with 3deg toe, 2deg front with 1deg toe out, 1.5 droop 4mm fr r/h 5mm rr r/h
with 37s all round. as the porpose of the day for me was to learn the track and the best way to stay on it i found the car stable and easier to drive than last time i ran there with my g4 1 yr ago and with 1-1.5 second better lap times! drove better and better every race and finished the day 2nd in the 20 min B final promising debue for my mtx4, cant wait till 21st to try getting it to go quicker
EX1.5-SC10 4x4
Old 05-08-2006, 06:07 AM   #4571
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Ichy, try taking some toe and camber out of the rear. 3* is too much for all but the loosest of conditions. You are going to be losing a lot of straight-away speed. I never run mine past 2* in. It sounds like you are on the right track to success though, good job!
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 05-08-2006, 07:41 AM   #4572
itchy b's Avatar
thanks for the tip, i've been runing 1 deg rr toe on my g4 on low traction which worked well, but i,ll find out how the mtx4 goes on 21st testing some different combos.
1 question i need to ask is about the roll centre adjustment on the rear suspension arm, looking at the car tonight i found that the front inserts
in the the rear bulkhead that hold the hinge pin are in the highest setting while the inserts in the rear of the rear bulkhead are in the lowest setting which i found a little strange. is this a normal setting option or did the previous owner of the car set this incorrectly?
i assume that the setting should be the same front to the back but if someone could shed some light on this it would be much appreciated
because this is one extra adjustment on the mtx4 that my g4 didnt have
cheers
joe
EX1.5-SC10 4x4
Old 05-08-2006, 07:50 AM   #4573
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
It looks like the person before you had put anti-squat in the car, basicly to helps on initial acceleration for the most part. If you have the other adjustment inserts, place it flat, in the middle or flip the ones over in the front of the rear lower pin and run it all the way down. This will free up the car a little and if you need more rear traction, raise it up. I run mine in the middle on most tracks, unless grip is insain. Also, I run 1.5mm tow RR on each side and 3.5 camber,(or till the tires just start to cone inward.)
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-08-2006, 08:10 AM   #4574
itchy b's Avatar
thanks for the info and advice, i'll be changing it first thing. the other mugen runners at our track are running the lowest setting as vht is used on the track for high traction but 6 deg cam cones the tyres in slightly so at least i got 1 thing right if you have ever watched the 1/8th 2001 worlds video thats the track im atempting to race at to give you an idea of my chalenge
EX1.5-SC10 4x4
Old 05-08-2006, 07:04 PM   #4575
Jammin'Trey's Avatar
Send a message via ICQ to Jammin'Trey
Where can I get a mtx-4 for cheap, i have an MTX-3 and love it to death but was wondering if this has been discussed before........Sorry, I am a newb.......(to nitro onroad... )
P.s. do many people use digital servos, and where can I get a really ghood reciever pack for my mtx-3?
Jammin'Trey is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
