Old 05-02-2006, 01:11 PM   #4546
rcracerdude's Avatar
Send a message via Yahoo to rcracerdude
i would suggest using 25t pulley. you could also check the chart for the gearing ratio. this should solve the loose belt issue and you'll also notice you could run same tire diameter for front and rear. Easier to put overdrive on the car also... just an opinion
about the small clutch bearings, they don't last as long compared to the mtx-3 type clutch bearing. however, we've tried aftermarket bearings and they seemed to last longer. try AVID RC BEARING (they did last the whole week racing and an hour main in Vegas ) . We also tried ceramic bearing, and boy they're smooth! Try to look on ebay. Last longer too. Take note on meshing the gears; very important!
Ken Gutierrez
derbybrosracing.com
rcracerdude is offline   Reply With Quote
Old 05-02-2006, 01:26 PM   #4547
asw7576's Avatar
Originally Posted by rcfoolz
In the clutch, the 3 bearings I havn't had a problem with them there, but the ones in the break and in the steering servo saver, I've lost 4 of the little buggers in this area. I lost breaks this past weekend and I tried everything, then I finally pulled the rear section off the chassis and found that the lower bearing was completely shot. Anybody else have this happen?
You can submit your car to guinness's book of world record
Probably you crushed it without knowing it ?
Old 05-02-2006, 01:28 PM   #4548
asw7576's Avatar
Do you use 25t or 24t side pulley ? Which one do you feel comfortable driving it ?
Old 05-02-2006, 02:39 PM   #4549
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
It is not recommended to use rubber shielded bearings on the clutch. This is due the ammount of heat they will be recieving. Over here, I have only seen one case of broken clutch bearings and it was caused by the gap in the clutch bell.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 05-02-2006, 03:13 PM   #4550
Derby Bros Racing's Avatar
take your time setting the gap/play of the clutch bell. the bearings, since they are smaller than the mtx-3, require a little more attention and checking.
i like checking and replacing (if necessary) the clutch bearings every about 2 hours of runtime. replacing them don't hurt too bad because i get them from www.avidrc.com and they are only a buck each (the same price goes for all the other bearings for the car, by the way).
i also do some extra steps before installing new clutch bearings that make them roll faster/more free. and it also avoid excess grease to fly-off to the clutch which can cause slip.
1. blast off the stock grease inside the bearing using air compressor.
2. spray with motor cleaner or denature alcohol to get rid of the grease then blast with the air compressor again.
3. once they dry off, i lightly oil the bearings with light bearing oil.
these steps are pretty easy and quick but you will see the difference. spin the clutch bell with unprepped bearings and then try it with prepped ones. the prepped bearings make the clutch bell spin so much faster and longer.
Derby Bros Racing is offline   Reply With Quote
Old 05-02-2006, 04:06 PM   #4551
The truth is Im more comfortable with the 24t pulley since i could use a better side belt (kevlar reinforced) - more peace of mind However, the 25t pulley gives a better handling for the car since you could easily adjust overdrive without sacrificing too much of tire split, i.e. gives the car better turn-in. I guess, its all up to personal preferences...
Ken Gutierrez
derbybrosracing.com
Old 05-02-2006, 07:16 PM   #4552
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I don't see why rubber shielded bearings in the clutch bell are a problem. Even the front bearing on the crankcase has a rubber shield and that gets more heat than the clutchbell.
Also the 25t pulley does give a more balanced car I noticed when you are looking for more steering because you don't have to run a split to maintain a 1:1 drive ratio and that will mean your rear roll center is higher. This is from having the add more preload to the rear shocks in order to maintain ride height which will flatten the angle of the lower arms.
Racing4Evo is offline   Reply With Quote
Old 05-02-2006, 10:06 PM   #4553
MAVICXXX's Avatar
24 and 25 pulley is mostly matters for overdrive or ez words front tyre vs rear tyre rotation. It depends on which and what track you are running and ofcoz what do you want the car to do.
Centax bearing is very crucial for me to take care,i have to make sure it is nicely place,lubricated and good condition.X3 and X4 bearing are different,i still like then X3 bearing coz it last better compares to X4 but rotation speed turns back to X4 due to the size.Normally i will assemble by using small shim size as inner diameter the bearing to avoid both inner bearing touching while the rotation take place.Vobles?ooo..thats very much giving me worries.So far,i lost 2 centax inner bearing for my 8races.
bearing without seal is more higher rotation,steel cover is better than rubber interms of bearing rotation,more smooth.
MAVICXXX is offline   Reply With Quote
Old 05-03-2006, 06:34 PM   #4554
Trader Rating: 15 (100%+)
Default receiver pack
What do you use for receiver battery pack in your MTX-4 chassis?
Thank you, Alain.
1/10 Durango DEX 410 V3
Alain Patry is offline   Reply With Quote
Old 05-03-2006, 06:51 PM   #4555
GrandeGixxer's Avatar
I have a 1900 mah Lipo with a VXR regulator(Thanks Rich, got it today). SHould be good to run for a whole day, takes a little longer to charge though.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 05-03-2006, 06:56 PM   #4556
Thank's Joe.
Alain.
Old 05-03-2006, 07:32 PM   #4557
rmdhawaii's Avatar
I'm just curious if you've tried ceramic bearings (i.e Boca Bearings Ceramic Lightning Ultra Seals for MTX-4) for your clutch and/or what your thoughts are on ceramics bearings in general. If cost wasn't a factor, would you be using ceramics instead?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-03-2006, 07:33 PM   #4558
richey's Avatar
Send a message via MSN to richey
Thanks for the update....
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 05-03-2006, 07:40 PM   #4559
The prices are beginning to come down a little now with the hybrid bearings. You can get a set of them for about half the price of full ceramics. They should be just as free though. The only ceramics I have on my car are the clutch bearings. I have not raced it with them yet, so I don't have a durability report, but it spins very freely. The first race I will be attending will be next weekend! I am ready.
Joe Cude
Old 05-03-2006, 09:18 PM   #4560
hi rmd,
yes i have tried ceramics and they are nice also. but as long as the clutch bearings are "prepped" they will spin
freely even if they are not ceramics.
the cost factor is the big issue. as far as the rotational weight goes, the clutch bearings are so small that it is almost a nonfactor.
the cost for 5x8x2.5 ceramics is around $7 (the average anyway)
the cost for avid 5x8x2.5 is $1
so to have the complete set, which is three bearings in our case, it will be $21 for ceramics and the avid will be $3.
by using the regular bearings, you can replace them 7 times just to match the cost of the ceramics. say you replace them every 2 hours of run, that's 14 hours of runtime. by the time the ceramics get close to even 10 hours of run time they are probably gone already or be gritty and have a lot of wobble anyways.
as for your question, if the ceramics are $1 each like avid, yes, i'll use them. but since i really didn't see performace gain by going to ceramic clutch bearings, i'll stick to my dollar bearings
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
