Old 04-28-2006, 03:12 PM   #4531
Derby Bros Racing's Avatar
stiffer section on that part of the chassis
Derby Bros Racing is offline   Reply With Quote
Old 04-28-2006, 05:39 PM   #4532
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
I haven't heard it called that. For that I also ise the 3Racong one. Everything lined up perfectly.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-29-2006, 05:05 AM   #4533
itchy b's Avatar
i've finally had the time to take my mtx4 out for a spin for the first time and got to tell you guys i'm impressed also was running in my new os tz 5p and after 7 tanks its showing some promising performance great combo of mtx4/ostz/mugen pipe, cant wait till race day oh yeah, i'm exited!!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 04-29-2006, 06:34 AM   #4534
Dreamcatcher's Avatar
What setup did you use?
R/C World hobbies, Team Magic, Lombardo motor sports,
Dreamcatcher is offline   Reply With Quote
Old 04-29-2006, 09:32 AM   #4535
itchy b's Avatar
Originally Posted by Dreamcatcher
What set did you use?
set?
EX1.5-SC10 4x4
Old 04-30-2006, 07:43 AM   #4536
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
set?
Dreamcatcher Probably meant " what set up did you used ? "
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 04-30-2006, 09:42 PM   #4537
4wheeldrift's Avatar
Default MTX-4 KAWAHARA chassis
Who carries the MTX-4 KAWAHARA chassis? I need one by Friday. Thanks in advance.
4wheeldrift is offline   Reply With Quote
Old 05-01-2006, 04:22 PM   #4538
Your right Evil, i did mean setup, Thanks, Thats what you call a brain fart
Old 05-02-2006, 09:56 AM   #4539
teo
Default Clutch bearing durability?
This weekend my MTX4 arrived and yesterday I had a chance to test it. It ran very nice from the first run But I am a bit concerned about the clutch and specially the bearings.
Even on the new clutch/bearings I can feel quite a bit of play when I try to move the clutch housing (I'm not talking about play in the direction of the crankshaft ofcourse).
Can someone who has run some gallons on this car share some experiences if the bearings hold up, and when they let go.
I also noticed the side belt is really lose, especially with 24t pulley. Is this a problem?
Thanks!
teo is offline   Reply With Quote
Old 05-02-2006, 10:15 AM   #4540
asw7576's Avatar
Thanks!
Total 3 bearings : 2 inside the clutchbell, 1 outside.
Yes, they have little bit of play ( wobble a bit ) but it's okay. Just make sure to replace the three bearings quite often..... maybe every 1 gallon of fuel.
There is belt tensioner to tighten the side belt.
Old 05-02-2006, 10:49 AM   #4541
Originally Posted by straightaway
What is the difference between brake pads, black, blue and yellow teflon. Thanks.
I know that the yellow teflon ones don't soak up the fuel so you have better brakes.
THE DOCTOR is offline   Reply With Quote
Old 05-02-2006, 12:00 PM   #4542
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
In the clutch, the 3 bearings I havn't had a problem with them there, but the ones in the break and in the steering servo saver, I've lost 4 of the little buggers in this area. I lost breaks this past weekend and I tried everything, then I finally pulled the rear section off the chassis and found that the lower bearing was completely shot. Anybody else have this happen?
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-02-2006, 12:10 PM   #4543
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I've heard from some of my friends that they have bearing problems in the engine. Also, at a regional race, the Mugens had problems with rocks getting lodged in the belts, where the Kyosho drivers had none of those problems. Another friend sold his 4 for a RRR because of the bearing problems...
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 05-02-2006, 12:37 PM   #4544
teo
Thanks for your comments. I'll see how the clutch bearings hold up. Btw; I see the original ones have metal shields, but the ones I ordered in reserve have rubber shield. Any preferred type?
Regarding the side belt tension, yes I do know there is an adjustable tensioner there, but even so the belt is really loose to the point that it looks like both "sides" might touch and interfere during running. But I guess it's not a problem then
Old 05-02-2006, 12:39 PM   #4545
Osiris 75's Avatar
I was told the side belt should be fairly loose, so it is normal...
Chris Kemper
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
