Old 04-17-2006, 07:10 PM   #4366
Joe Os's Avatar
Originally Posted by GrandeGixxer
I think it is caused by the setscrew backing off just slightly. When this happens, the shaft rotates back and forth in the gear adapter and causes this. It has happened to me(once ) I check that setscrew every run along with all of the others.
What JP you runnin'? stock or modify?
Joe Os is offline   Reply With Quote
Old 04-17-2006, 07:14 PM   #4367
Originally Posted by asw7576
BRB = berrylium piston sleeve ?
I think its okay but my friend was having problem with those berrylium P/S/R because the heat ate the filament 5 times. He said the engine temp for berrylium is set at 120 degree Celcius which I think is good operating temp for that. I think you need cooler glow plugs to compaensate higher engine temp.
Malaysia Boleh !!! Good Luck at Suwon
I used a BRB with my JP engine and it was like a nuclear reactor. HOT! I can appreciate the hard work someone put into trying something different but so far I haven't seen anything better than the ABC sleeves that have been the mainstay of RC engines for years. You'd think if some of these alternative technologies were as good as their creators say they were some of the main engine makers would use them. So far, it's still ABC.
going4#1 is offline   Reply With Quote
Old 04-17-2006, 07:14 PM   #4368
Derby Bros Racing's Avatar
Originally Posted by musee
Does anyone know where I can get the rear MUGEN CVD's and yellow clutch shoe? I'm in Southern California right now.
try mo nitrohouse.com
Derby Bros Racing is offline   Reply With Quote
Old 04-17-2006, 07:19 PM   #4369
Originally Posted by MAVICXXX
....kawahara has comeout wit hardened 3mm chasis too..havent got a chance to see anybody on it..
I've been using the Kawahara for a while. Good? Hey man, it's Kawahara. Do you need to ask? The chassis is great and definitely less bendable than the Mugen. Just the right amount of flex for me. Not only is it better quality than the Mugen, it's cheaper too!
It's what I use and will continue to use as long as I have an MTX-4.
Old 04-17-2006, 07:24 PM   #4370
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
does anybody have the kawahara web site link?
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 04-17-2006, 07:28 PM   #4371
Roger's Avatar
http://www.kawahara-racing.co.jp/
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 04-17-2006, 07:46 PM   #4372
MAVICXXX's Avatar
dont really get it bro..better stick to abc rather than brb?what is HOT and nuclear reactor means?
MAVICXXX is offline   Reply With Quote
Old 04-17-2006, 07:52 PM   #4373
MAVICXXX's Avatar
oh ya?then i should try for suwon.. flex or bent is nature of aluminium when it is construct like a chasis..but how bout the tweak?the major problem wit stock is the too flexy and tweak..
Old 04-17-2006, 10:01 PM   #4374
Just trying to track down the front CVDs for the MTX-4 does anyone have a link and also a link to a better rear shock tower would be great, I need it to be able to be shipped to Australia so a hooby store that will ship worldwide would be great but if that can't be found just showing me the products would be most appreciated
jprevolution is offline   Reply With Quote
Old 04-17-2006, 10:37 PM   #4375
EdwardN's Avatar
BRB stand for Berryllium Bronze ( 1.8 %) and actualy it is as most p/l set ABS (Aluminium piston, Bronze, not a brass for sleeve and Chrome plating.)
This p/l sets are not required to run hot at all, but in the mean time it can withhold operating temperature higher then Brass-expantion rate for BRB is lower and pisto material we design for it mutch it perfectly on most immaginable temperatures up to 400 F.
Yes it is legal to race-nowhere in the book any restriction for materials use in engine constraction beside no ceramic except bearings.
Edward.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 04-17-2006, 10:43 PM   #4376
EdwardN's Avatar
It is not that simple-if nobody make then it is not better. There is factor as profitability and nobody can afford ( I mean it) make BRB sleeves beside us and be profitable. Price for BRB is about 6-10 times higher then for regular brass and with this difference it won't be possible to make profit, unless known how to make it profitable.
Edward
Old 04-17-2006, 10:43 PM   #4377
banky71's Avatar
here is a link to the frt universals for the MTX4.... which are the same ones as the MTX3......
http://www.acehardwarehobbies.com/2....ducts_id=12993
also have the rear universals for the MTX4 here too.....
banky71 is offline   Reply With Quote
Old 04-17-2006, 11:56 PM   #4378
Trader Rating: 44 (100%+)
what's the car's main weakness(es)?
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 04-18-2006, 12:54 AM   #4379
Chris West's Avatar
Send a message via MSN to Chris West
nothing if you dont crash but the shock tower would be my main concern and the front dogbones NEED to be replaced with universals
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 04-18-2006, 01:03 AM   #4380
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
rear shock tower to clarify.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
