Old 04-10-2006, 08:30 PM   #4246
r1harper's Avatar
Trader Rating: 24 (100%+)
hello everyone, i am new to this onroad but went with the best. this is my first car, and i read alot of the threads but just too many, so here is my question. what is meant by say like a shore 37, 40 and so forth. also what is the prefered type of tire rubber or foam. i am in the breakin process right now a RBMods LR3 with a RB pipe and header, a ballistic powerplant. i am going to start with the kit setup for starters, but like always any tips are appreciated. thanks
r1harper is offline   Reply With Quote
Old 04-10-2006, 08:34 PM   #4247
Originally Posted by Edgar Millenium
Hi Guys!!!
I will be traveling soon, and will take my cars with me..... I am cleaning my MTX4 and found that if I remove the upper tray the chassis bend a little, about 1/8 in difference from the front end and the rear end, but with the upper plate, is looks straight if I use setting blocks.
Do you think that I should chage it or no?? What about a 4mm Chassis instead the stock one?
Edgar
Edgar:
You can remove the parts from the chassis in sections and then try to flatten out the chassis again by applying backward pressure at the point of the bend. Maybe not as good as new but handling should not be greatly affected. Typically the Mugen chassis will bend about 3/4 from the front, toward the rear just in front of the first engine mount (i.e. the mount closest to the font) so look there if the bend is present. If the bend is right at the front, trickier to flatten and I'd watch for cracks. If the chassis cracks, I wouldn't use it.
additionally
if the chassis is twisted, I would toss it. Certain bends are easy to fix but a twist is very difficult. A twist will also have a greater negative effect on the car's handling too.
Suggest an upgrade chassis. I use the Kawahara and it's only 3mm but much more sturdy than the Mugen. I've haven't used a 4mm but I wonder if weight is an issue??
going4#1 is offline   Reply With Quote
Old 04-10-2006, 08:43 PM   #4248
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Different shores 37, 40 so forth refers to the firmness of the foam. To make it easy, the higher the number, the harder the foam. Harder foam means less grip. Being new, there are definitely times when harder foam is better.... Less wear, less traction roll etc. In the USA, most nitro onroad racing is done on foam tires.
For setup help, a lot depends on the track and the surface prep (traction level). Start with the kit setup and then make changes to help. If you are new, I would suggest getting a less expensive pipe to learn with. They tend to get crushed and the RB is an expensive lesson to learn. Good pipe, but not a training pipe.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-10-2006, 08:44 PM   #4249
Rob:
The chassi start to bend where you say, close to the battery end and engine mount. If I lay it alone, the difference is about 1/8 of an inch. I doesn't look twisted, only bent. I do have 4mm 3 racing chassis in stock, so if you think I sholud change it, I think I should do it now.
Edgar Millenium is offline   Reply With Quote
Old 04-10-2006, 08:51 PM   #4250
r1harper's Avatar
thanks for the input. i already had the pipe so no loss there, also i am running a Lexus is 250 body at the moment. i will be racing on a tight track this weekend, so really dont know what to expect with the oneway and all, it is tricky on the brakes i know that much. i am hearing about the rear tower being a bit weak, my lhs does not carry parts for it so a small have to have parts list would do also, and thanks again
Old 04-10-2006, 08:52 PM   #4251
Bigtbone's Avatar
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
Send a message via AIM to Bigtbone
Originally Posted by GrandeGixxer
Bigtbone, I usually get all my spares from Acehardwarehobbies.com or RC-Mushroom.com
I will try ace. mushroom site has been down tonight..
Bigtbone is offline   Reply With Quote
Old 04-10-2006, 08:53 PM   #4252
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Edgar, I bent mine back and am just keeping the 4mm one for a spare. It will only take 10 minutes to change if it gets bent again. The 4mm is wuite a bit heavier and my car is a pig to begin with. But with the stock chassis bent back, the car is not tweaked at all after I set it all up.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-10-2006, 08:54 PM   #4253
Joe Os's Avatar
Originally Posted by Scott Fisher
That would be better.
Thankz bro
Joe Os is offline   Reply With Quote
Old 04-10-2006, 08:55 PM   #4254
It is down? I was wondering why it kept taking me to the damn search page. I was starting to get pissed.
Joe Cude
Old 04-10-2006, 09:01 PM   #4255
Joe Os's Avatar
Which one is better gearing for the large track 21/60 29/52 or 16/60 24/52?
Old 04-10-2006, 09:07 PM   #4256
Originally Posted by Joe Os
Which one is better gearing for the large track 21/60 29/52 or 21/60 24/52?
As Scott already said, you need to ahve the same number of teeth split between the pinions and spurs. The 21/60 24/52 will not work. Your 2nd gear probably would not even touch.
Joe Cude
Old 04-10-2006, 09:10 PM   #4257
Joe Os's Avatar
Try to go this site rc-toro.com
Old 04-10-2006, 09:17 PM   #4258
Joe Os's Avatar
Old 04-10-2006, 09:19 PM   #4259
Support authorized dealers.
Use Nitrohouse, Ace, Winners Circle... etc.
Old 04-10-2006, 09:25 PM   #4260
Thanks Guys I juts bent it back, it looks good now
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
