Old 04-05-2006, 11:44 PM   #4186
Roger's Avatar
Originally Posted by Bigtbone
What are my options to stop tracksion rollz?
I be running the stock set-up
For high traction situations, use a higher roll center ( less distance between the RC and CG ). This prevents the car from transfering too much weight and feeling lazy when transitioning between left and right turns ( or vice versa ), or worst, traction rolling. Raising the front roll center will take away steering, and in the rear, it will take away grip. Or try harder shore rated tires. Hope this helps.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 04-06-2006, 04:38 AM   #4187
Bigtbone's Avatar
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
Send a message via AIM to Bigtbone
Default still not sure how to do on the car
Thanks fellas..
I am very new to this car.
I wil definately try the camber.
how do I measure the track width?
should I just use washers? on the arm mounts?
What is the set-up boatd that most people use?
Bigtbone is offline   Reply With Quote
Old 04-06-2006, 05:12 AM   #4188
asw7576's Avatar
Thanks fellas..
how do I measure the track width? Ruler, outside edge of tires
Before you do the below ( affect Roll Center ), I hope you try the above suggestions FIRST ONE BY ONE and see what happen. If your car don't traction roll anymore you can skip the below.
should I just use washers? on the arm mounts? MTX4 front upper arm position, you could remove the 1mm shim below the front upper arm mount. This makes higher roll center ( more V angle ) reducing the chance of traction roll. At the rear, you could lower the rear upper link at carbon fibre plate to very bottom hole position..... I prefer that because it's more side grip for mtx4 and mtx3.
Old 04-06-2006, 05:33 AM   #4189
Trader Rating: 15 (100%+)
Thanks fellas..
I will be at the track each week so you can use my Hudy board to check the width. Mike Keely
THE DOCTOR is offline   Reply With Quote
Old 04-06-2006, 05:23 PM   #4190
PTP Racing's Avatar
Ok guys I am going to give you the same question I just asked the guys on the V1RRR thread. What makes the MTX4 the car to have vs the V1RRR WC. I admit with my previous experience with Mugen vs Kyosho I would pick the Kyosho but thats in 1/8th buggies. I have been offered a good price on MTX4 but it seems to need more hop-ups to really be race ready like universals for instance.
What makes the MTX4 the car to have? I plan to race on a large permanent track if that makes any difference.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 04-06-2006, 05:29 PM   #4191
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Hop-ups are just for looks. The only hop-ups you need are universals and aluminum hexes. Thats it. Honestly, I'd say the quality of parts that Mugen produces is far better than Kyosho. Not to mention that Kyosho changes their car far more often than Mugen. This can be seen with the 1/8 buggies and 1/10 sedans...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-06-2006, 05:33 PM   #4192
PTP Racing's Avatar
OK but if you add the universals and hexes to the cost of the mtx4 it is the same or higher than the v1rrr wc.
And in my experience racing 1/8th buggies yes Kyosho cost more but it was worth the money I had a MBX5 I sold to buy a Kanai 2 which I wish I still had it was the best r/c car I ever had.
Jason Miller
Old 04-06-2006, 05:39 PM   #4193
Riketsu's Avatar
I dont have much experience with 1/8s. But I had a 1/8 Kyosho (Inferno DX)before taking a 2 year break from the hobby. When I came back, there were already 4 or more other versions of the Kyosho 1/8 available. According to someone else that said on another thread, Kyosho is constantly upgrading their cars. While the Mugen MTX-3 was around for almost 3-4 years before there was even word of the MTX-4. They are both awesome cars, but I prefer the Mugen for the parts availability in my area and the material used in the parts.
Old 04-06-2006, 05:42 PM   #4194
PTP Racing's Avatar
So in onroad mugen is the most durable?
Durability is very important to me I would rank it as the most important thing.
What about handling? Anyone had both these cars? Which is your favorite?
Jason Miller
Old 04-06-2006, 06:40 PM   #4195
What hop-ups will I need for my new MTX-4? What hop-ups are just bling? Thanks in advance.
Jamminjd is offline   Reply With Quote
Old 04-06-2006, 06:54 PM   #4196
GrandeGixxer's Avatar
Jammin, if you look on this very page, you will find the answer to your question. For me, along with the CVD's and wheel hexes, I like the Mid chassis brace as well as the front sway bar holder from 3Racing.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-06-2006, 10:13 PM   #4197
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
dont forget to beef up your rear shock tower, it's the weakest point i have found so far.
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 04-07-2006, 03:04 AM   #4198
Chris West's Avatar
Send a message via MSN to Chris West
speaking of which here is my 'home made' job
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 04-07-2006, 03:20 AM   #4199
Chris what material is that made out of? It looks metal. NIce job too.
Joe Cude
Old 04-07-2006, 03:28 AM   #4200
Chris West's Avatar
thanks mate, its fibre glass, stonger than 2 together,
look at the other side (wheel nuts)
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
