Old 03-29-2006, 07:47 PM   #4051
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by Jamie Corrado
Alex,
What side pulley are you running?
18 teeth rear
25 teeth front
gonzo416 is offline   Reply With Quote
Old 03-29-2006, 07:48 PM   #4052
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Every time I ran at Rev's, there was way too much traction. CP was better all around except for the bumps. I am sharing what worked for me, and it seems to be about the same for you.
I am running the 24t side pulley in front.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 03-29-2006, 07:57 PM   #4053
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by jam rock
do I need to shim the ball end at the bottom of the shock when i use the 4mm shock tower from mugen? If so, what shims and thickness?
Anybody try 30,000 or 50,000 diff oil? which is works better?
You don't have to run a shim at the bottom of the shock, but I would. If you use one then get a shim that is 1-1.5mm thick. I do run a 4mm shock tower, but mine is only 2.5mm thick at the bottom where it bolts on. This keeps the body mounts and shock angle the same as using a stock tower.
I have run 10k, 30k and 50k shock oil. What the other people have said about the shock oil differences is true. As a general rule of thumb, the more traction, the heavier diff oil.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-30-2006, 05:58 AM   #4054
Corse-R's Avatar
Anybody try 30,000 or 50,000 diff oil? which is better?
All depends... on the track conditions and setup of your car, two weeks ago went up to 30k oil with o-rings on the planetary gears (just to make it a little stiffer). That day, the car with dark blue springs and 40's everywhere was completely dialed. Next weekend, needed to return to light blues, 40's and 10k diff.
Have here a 50k oil bottle.. but seeing how performed with 30k oil on diff I don't think I'll need it on the future unless I find some extreme track conditions that warrant the use of such thick diff oil - probably I'll go solid rear.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 03-30-2006, 06:01 AM   #4055
Thanks all!
I got the mugen option shock tower. I will try it this weekend.
The reason for wanting changing the shock oil for 10k is that the car is pushing. I have rear end traction now so i was thinking that changing the oil would help with the turn in.
Any other suggestions?
jam rock is offline   Reply With Quote
Old 03-30-2006, 10:34 AM   #4056
Are you talking shock oil or diff fluid? If you are pushing, you should go higher in viscosity, not lower. Lower viscosity will allow the wheels to "diff" easier, hooking up that end of the car more.
Joe Cude
Old 03-30-2006, 10:50 AM   #4057
asw7576's Avatar
Upper mounting shock location need 2mm - 3 mm shims when using 4mm rear shock tower. In my case I use 2mm shims that comes in the box ( for rear upright / rear upper link ). Twist the shock absorber to make sure it doesn't hit the carbon fibre. You could add 2mm shim at lower shock position if you feel the shock position is not straight top to bottom.
30k diff oil or 50k diff oil ? ask A class drivers who play together in your circuit.... 30k is mostly use for medium to wide open track while 50k is more suitable for technical track.
Old 03-30-2006, 01:17 PM   #4058
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I just milled the rear of the shock tower down 1.5mm where it mounts to the rear cross-over block and that also moved the body mount forward. This kept the strength of the unit and leaves everything in stock locations.
Simple fix.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 03-30-2006, 01:31 PM   #4059
Are you guys using a total of 3 5x8 bearings with the MTX-4 clutch bell? I was looking at the manual and it shows 2 5x8 bearing being installed on the inside and 1 5x8 going on the outside.
mgreen is offline   Reply With Quote
Old 03-30-2006, 03:16 PM   #4060
TPB
Rear Diff
What rear diff oil is best when using a one-way?
The track has a sweeper on to the straight but has a fairly tight corner at the end of the straight (which is still high speed) then another straight after. Also has a tight hairpin in the infield. The traction is ok but the track is quite rough.
Will a tighter diff give me more traction or will a looser diff.
Please explain.
Also what shock setup would you recomend for a bumpy track?
TPB is offline   Reply With Quote
Old 03-30-2006, 06:30 PM   #4061
Joe Cude
Old 03-30-2006, 07:28 PM   #4062
Joe Os's Avatar
Please explain.
10,000w
40w shock oil all around
Joe Os is offline   Reply With Quote
Old 03-30-2006, 07:57 PM   #4063
Please explain.
Thicker diff oil will make it more like a locked rear (more forward traction) but hurt you in the turns ( not as much steering).
Thick shock oil for smooth tracks and thinner oil for bumpy tracks.
THE DOCTOR is offline   Reply With Quote
Old 03-30-2006, 07:59 PM   #4064
Yes three bearings.
Old 03-30-2006, 10:06 PM   #4065
Yes, use three bearings like the manual says.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
