Old 03-28-2006, 04:03 AM   #4021
Send a message via MSN to ZELOKO
thanks guys..
ZELOKO is offline   Reply With Quote
Old 03-28-2006, 06:58 AM   #4022
typer's Avatar
Scott, how can i eliminate the push on my car when exiting a turn? I'm using A ackerman, 0 mm droop in front, 400 wt shock oil with 1.3 x 1 piston,1 deg toe out, stock shock position up front. 5mm rear droop, shock position 1 hole higher,2 deg toe in, 30k diff oil. 5mm front ride height and 6 mm rear ride height.purple springs all around. Using 40 shore tires.
typer is offline   Reply With Quote
Old 03-28-2006, 08:07 AM   #4023
rocca30's Avatar
Default push
have you tryed 30,000 or 50,000 oil in the rear diff, thart should help.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 03-28-2006, 08:12 AM   #4024
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
he's already using this diff setting..........
i'd try front spool..........
reduce front droop (+2mm should be ok)
move some caster clips forward......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 03-28-2006, 08:18 AM   #4025
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
what side pully are you running ? if you are running 24t then give about 3mm splits between the front and back, it should give you little better turn ins.
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 03-28-2006, 08:21 AM   #4026
typer,
Maybe 10k rear diff... would help...
Old 03-28-2006, 10:43 AM   #4027
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You could try reducing the front droop, or adding some front caster, but I would try reducing the rear toe in first. Try going to 1.5 or less per side. If you start spinning out, then look elsewhere but it might give you just what you need. If you notice no changes, then at least you will pick up a little bit of straightaway speed.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-28-2006, 11:09 AM   #4028
gonzo416's Avatar
Trader Rating: 39 (98%+)
does anyone have a front diff they don't need? i'll be glad to take it off your hands.
gonzo416 is offline   Reply With Quote
Old 03-28-2006, 12:03 PM   #4029
gonzo416's Avatar
WHAT (MM) TIRE SIZE SHOULD THEY BE CUT TO?
Old 03-28-2006, 12:15 PM   #4030
Alex,
What side pulley are you running?
Jamie Corrado is offline   Reply With Quote
Old 03-28-2006, 04:46 PM   #4031
If your side pulley is 24 tooth, then I would run a 2.5 or 2 MM split. I cut my tires to 63 MM rear and 61 MM front so they will last all day. In a real serious racing environment, I would run something like 62 MM rear and 60 or 59.5 MM front. Now I've read somewhere that if you run the 25 tooth pulley on the side, you don't have to run a split. If thats the case, then you could consider the roll-out distance and all that other stuff and just cut all four tires to 63 MM or whatever. Also, its my understanding that running a split helps with on-power stearing in the corners since the front tires are spinning faster than the rear tires at an angle.
mgreen is offline   Reply With Quote
Old 03-28-2006, 10:19 PM   #4032
asw7576's Avatar
How about rear tyre wear ? When people use 25t front side pulley what happen with 1:1 ratio if rear tyres wear faster than front's ?
Old 03-28-2006, 10:26 PM   #4033
Tag
Tag's Avatar
running 25t will give you close to 1:1 ratio so you dont have to run splits for front and rear not to mention your tires will wear evenly.
Old 03-29-2006, 06:30 AM   #4034
typer's Avatar
Thanks for all the suggestions...hope it works...
Old 03-29-2006, 07:27 AM   #4035
blanks596's Avatar
Trader Rating: 14 (100%+)
to anyone out there:
I recently purchased an MTX-4 and I wanted opinions on the cars performance and quality, especially in relationship to the MTX-3 and Team Magic G4. Are there any quirks about the car which most owners have a problem with? If so, what are your solutions? Are there any option parts that are absolutely necessary to be competative?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
