Old 03-26-2006, 10:12 AM   #3991
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by gentleman81
I HAVE AN MTX3 AND AM STILL SEARCHING FOR A SETUP, I DONT GET TO RACE AND PRACTICE AS OFTEN AS I NEED TO. HOW MUCH BETTER ARE THE X4'S TURNING OUT TO BE. I WANT ONE BUT I WOULDNT MIND WAITING FOR THE PROSPEC MODEL (IF THATS NOT GONNA BE 3 YRS FROM NOW) BUT IF THE DIFFERENCES ARENT OBVIOUS IM GONNA STICK WITH THE 3.
ANY SUGGESTIONS???
All I can say, the difference is not great. I have seen X3 vs X4 in the A main and the X3 had no trouble keeping up. I only made the change because the opportunity fell on me.
Riketsu is offline   Reply With Quote
Old 03-26-2006, 10:19 AM   #3992
gentleman81's Avatar
Talking
thanks alot, i didnt feel like making a $440 dollar investment if there werent some obvious changes and differences. i know it has a lower cg and the fuel tank move has made a difference when pitting. the overall design is easier to work on the car but that is all stuff that will save u time inbetween races in my opinion. maybe ill get one when i win the lottery, but until then i can get 2 more equally equiped x3s online. thanks (wo)man?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 03-26-2006, 10:28 AM   #3993
Riketsu's Avatar
man...
Old 03-26-2006, 10:30 AM   #3994
we got some nitro vixens up my way so i had to be politically correct
Old 03-26-2006, 09:04 PM   #3995
S Rossi's Avatar
ran the car today and it is money
S Rossi is offline   Reply With Quote
Old 03-26-2006, 10:38 PM   #3996
asw7576's Avatar
mtx4 drive like V1 RRR, very agile, stable and higher cornering speed compare to older mtx3.
Yesterday I race national series, my buddy drove mtx4 while I drove my old trusty mtx3. Surely mtx4 have higher cornering speed and love tight S turns than mtx3..... I couldn't keep up his driving until luck factor comes into play. I got B main second and he got third.
Old 03-26-2006, 11:07 PM   #3997
Regional Moderator
daniz24's Avatar
Haha congrats
You must say thanks to that low quality but expensive rims (not the tyres)
daniz24 is offline   Reply With Quote
Old 03-27-2006, 05:11 AM   #3998
Trader Rating: 52 (100%+)
Hey Guys
does anyone have any universals for the front...Hobbyshops,ECT.
thanks
Mo
Mo Denton is offline   Reply With Quote
Old 03-27-2006, 06:42 AM   #3999
Originally Posted by 1fastguy1
Hey Guys
thanks
Mo
NYC Hobbies
718-366-6262
Jamie Corrado is offline   Reply With Quote
Old 03-27-2006, 06:43 AM   #4000
Mo
Old 03-27-2006, 07:46 AM   #4001
Default set up ride height
how????????????????
mr.TUNED is offline   Reply With Quote
Old 03-27-2006, 07:53 AM   #4002
Riketsu's Avatar
Originally Posted by mr.TUNED
how????????????????
Find a flat surface (table or board) and use a ride height gauge? (with wheels and shocks attached)
Old 03-27-2006, 08:40 AM   #4003
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
More like someone hit me where it hurts the center of the wheel broke.. .. oo well that's racing..
This was my First time racing nitro in 3 years.. my old car was NTC3. here's my impression of MTX4. my X4 was good but It could be better if I could find a better setup, I would like to get more turn in cause the car understeers alot.. any one have a set up for a fast flowing Euro types track ?
the Track best time yesterday was about a sec off the track best lap record ..
it's a bit slippery.. I ran 40 shores on practice day using the box setup.. had to tap the brakes on each turn in. so I changed the set up a bit..
I moved the rear upper camber links down. it helps abit.. but still pushed like a dumptruck. but then one the fast guys at the track notice that my rear shock had no movement cause I doubled the rear tower.. so .. I put a 2mm spacers on the top shock links so now the rear suspensions got movement like back when before I doubled up the rear tower.
made some changes from the box setup. changed from 2mm front droop to 0mm and from 5mm rear droop to 3mm. put 3mm rear toe in. put 0 deg toe in on the left and 1 deg toe on the left.. (cause it got more right sweeping corner).. 6mm rear ride height and 5 mm front ride height. tweak it with 1/2 fuel tank and I used 35 shore tires. Took it out and practiced on Race day. the car turns in a bit better but it still have an understeers and a little oversteers, on fast transitions corners..
Over all The MTX 4 is a good car, but I need to find the setup for it.
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 03-27-2006, 08:55 AM   #4004
Derby Bros Racing's Avatar
what ackerman are you using? you didn't say but from what the car is doing, i'm assuming you're using the "a". try using the "b" ackerman, it will give you a better turn in. also try going down a hole on the shock tower for the rear shocks.
Derby Bros Racing is offline   Reply With Quote
Old 03-27-2006, 10:42 AM   #4005
EvilDriver's Avatar
Thanks for the Suggestion Jo.. I'll do that.. I'm using The A ackerman per the box set up. I'll swap it to the B and I'll move the shock position down, and I'll let you know the next time I'm running the car..
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
