Old 03-24-2006, 01:34 PM   #3976
gonzo416's Avatar
Trader Rating: 39 (98%+)
jaimie YGPM
gonzo416 is offline   Reply With Quote
Old 03-24-2006, 10:48 PM   #3977
Bigtbone's Avatar
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
Send a message via AIM to Bigtbone
Default Big gears
I am running on a big track what is the best gears? spur I pinion fo the car? I mean 250ft. straight Pleazzz help
Bone!
Bigtbone is offline   Reply With Quote
Old 03-24-2006, 11:07 PM   #3978
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Go up 1 tooth on the 2nd gear pinion and try that. It should be close. Might need to come down a tooth or 2 on the spur as well. I wouldnt mess with 1st unless you have to. You want to still have that power out of the hole.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 03-25-2006, 03:10 AM   #3979
Joe Os's Avatar
Bone!
Try 16/24 pinion and 52/60 spur gear...
Joe Os is offline   Reply With Quote
Old 03-25-2006, 08:21 AM   #3980
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Bone!
What engine and pipe you running? Some engines and pipe combinations cannot handle large gears as well as others.
Riketsu is offline   Reply With Quote
Old 03-25-2006, 09:01 AM   #3981
Bigtbone's Avatar
Default Gears
The EB mod OS tz... 3 port.
Old 03-25-2006, 10:07 AM   #3982
Riketsu's Avatar
With the TZ, it should be able to handle the 24 pinion. Try to get also the 23 pinion and compare them. You can only succeed in this hobby by trial and error, when there isn't someone else that has already done it.
Old 03-25-2006, 02:43 PM   #3983
Bigtbone's Avatar
ok another problem. bell is not spinningfreely. I added spacers after the thrust bearing now what?
Old 03-25-2006, 03:17 PM   #3984
How much clearance (end play) do you have? Does the nut that holds the spring on have any threads showing?
THE DOCTOR is offline   Reply With Quote
Old 03-25-2006, 03:25 PM   #3985
Bigtbone's Avatar
yes somewhere up near .7 MM like the book says? should I tighten it more?
Old 03-25-2006, 03:30 PM   #3986
Joe Os's Avatar
How long you driven rc already bro?
Old 03-25-2006, 03:41 PM   #3987
Bigtbone's Avatar
Old 03-25-2006, 04:49 PM   #3988
gentleman81's Avatar
Default X3 VS X4
I HAVE AN MTX3 AND AM STILL SEARCHING FOR A SETUP, I DONT GET TO RACE AND PRACTICE AS OFTEN AS I NEED TO. HOW MUCH BETTER ARE THE X4'S TURNING OUT TO BE. I WANT ONE BUT I WOULDNT MIND WAITING FOR THE PROSPEC MODEL (IF THATS NOT GONNA BE 3 YRS FROM NOW) BUT IF THE DIFFERENCES ARENT OBVIOUS IM GONNA STICK WITH THE 3.
ANY SUGGESTIONS???
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 03-25-2006, 05:05 PM   #3989
ogreasurada's Avatar
Originally Posted by ogreasurada
THANKS everyone so much for giving me so much ideas on solving the front sway bar problem, I think I will take off the front sway holders to inspect the slots aliments, I believe I'm just one of those super unlucky guy getting the car from the first batch....first bulkheads problem, then defective turnbuckles, then drive cup couldnt fit in to bearings......now the front sway holders....sigh......o wellz, at least the overall quality and finish of the chassis compensate on the bugs....also especially from the help of you guys. THANKS again.....now time to take out my tools again >_<;
After thorough inspection it was discovered that the aliment of the sway bar slots in the front holders were not straightened (or may because of binding due to the material and screws)....so I switched them to the alloy holders (single cam) and all the twitching and unbalance were gone. Anyways, thanks again to everybody that gave me tips and suggestoins. Also hope this can remind anyone else having the same issue with the stock holders.
ogreasurada is offline   Reply With Quote
Old 03-25-2006, 05:23 PM   #3990
BigTBone, the clutch setup that I have found that works best is as follows:
Grey shoe
lightweight flyweights
silver hard JP spring
clutch nut adjuster .8mm
endplay-.25mm
This has worked out good for me. I have not tried the yellow shoe yet, but I will probably try it out this year.
Joe Cude
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
