Old 02-28-2006, 05:11 PM   #3616
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by THE DOCTOR
Is Jack going to start to make one deg. offset rims?
Think they already do.
Artificial-I is offline   Reply With Quote
Old 02-28-2006, 06:42 PM   #3617
Lightbulb
Originally Posted by Jamie Corrado
Doctor,
Your kit came with 2 plastic shims on one of the part trees. Put them behind the the wheel hexes and set your track width accordingly. I myself use Jaco wheels and did the same.
I'm running 2 degree offset and setting my track width accordingly. Is that OK or should I really be running 0 degree?
mgreen is offline   Reply With Quote
Old 02-28-2006, 07:03 PM   #3618
Trader Rating: 15 (100%+)
Not from what I see on their site.
THE DOCTOR is offline   Reply With Quote
Old 02-28-2006, 07:09 PM   #3619
I can see that is what I am going to do. The spacers that come with the car is not tight on the shaft so it is going to rub on the shield of the bearing. Those spacers are SH*T I can only wonder what Mugen was thinking when they decided to have people use them.
Old 02-28-2006, 07:21 PM   #3620
Alright cool. Just spoke with Mike Swauger on the phone.
He said this:
Red and Yellow are very similiar. He said there a good shoe to use. Yellow will just give you more snap.
Red and Yellow will also last the longest , around 3.5-4 hours.
Then grey gives the most snap and he said was the best I believe, but will only last about 1.5 hours.
Use grey when grip is very good. If grip falls, switch to yellow. This is a strategy I found works well for me and always carry both shoes in my kit bag when out at the track. As for the spring, Mugen Super Hard.
going4#1 is offline   Reply With Quote
Old 02-28-2006, 11:32 PM   #3621
Moderator
Yes and when thats no good , red will offer a little less snap.
Old 02-28-2006, 11:44 PM   #3622
Moderator
So this is how it goes.
Hardest to Softest
Red --> Yellow --> Grey
Quick Overview:
Grey is 1.5 hours of use, most snap.
Red and Yellow are very similiar in grip and wear with 3.5-4.0 hours of use, with yellow giving a little more snap.
Old 03-01-2006, 12:43 PM   #3623
Lightbulb
Well I was way off then with the clutch. I always thought that gray would last a lot longer than red or yellow. How many colors are out now? Just gray, red and yellow; or black, gray, red and yellow?
Old 03-01-2006, 03:43 PM   #3624
Trader Rating: 4 (83%+)
Grey is probably the best all around shoe. Problem is the high plastic content makes it melt on extreme condition. If you are only getting 1 hr out of grey on a 12 engine, it is sliping too much and not getting power to the wheels. On 21 engine, grey last around an hour.
Red is a great shoe when it is set correctly. Margin of error on setup is very slim. It will slip if it is just a little off.
slooookomo is offline   Reply With Quote
Old 03-01-2006, 07:45 PM   #3625
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Well, the last package of hopups came in today in the mail. Guess I have no need to get a Pro-spec version. Just missing Titanium Pivot-Balls and Steering links (and chassis) which I have never broken either in my entire MTX-3/4 history.
Here is the list:
-Skyline Aluminum Brake Bar
-Skyline Aluminum Front Bulkhead Cover
-Skyline Aluminum Front Upper Roll Center mount
-Skyline Aluminum Mid Bearing Block
-Skyline Aluminum Upper Deck Support
-Skyline Hollow Main Shaft
-Skyline Aluminum Brake Bracket
-Skyline 3mm Rear Shock Tower
-3Racing Wheel Hexes
-Mugen Front CVDs
-Mugen 23T Steel Pinion
-Mugen 17T Steel Pinion
-RCScrews Titanium screws
-3Racing Aluminum Rear Brace RH
-3Racing Aluminum One Piece Engine Mount
-3Racing Lightweight Clutch Bell
-3Racing Lightweight Front Shaft
-SATO Aluminum Damper cup
-SATO Lite Alum. Rear Lower Arm Rear Mount
-SATO Lite Alum. Rear Lower Arm Front Mount
-SATO Front Sway Bar Holder
-K-Factory Hardened Vent Brake Disk
-5mm Middle Belt
-Center Post
-Mugen Teflon Brake Pads
-Mugen Yellow Clutch Shoe
-Serpent 710's diff balls in 2nd gear shoes (Yes, I know it might end with a rash)
http://img.photobucket.com/albums/v361/Riketsu/Car1.jpg
http://img.photobucket.com/albums/v361/Riketsu/Car2.jpg
http://img.photobucket.com/albums/v361/Riketsu/Car4.jpg
http://img.photobucket.com/albums/v361/Riketsu/Car3.jpg
Riketsu is offline   Reply With Quote
Old 03-01-2006, 07:49 PM   #3626
Looks like there is a front multi-front differential for the MTX-4. You can run a oneway, oneway solid, or a spool. Check it out:
http://www.rcatomic.com/main/modules...hp?storyid=145
Zac Project is offline   Reply With Quote
Old 03-01-2006, 08:19 PM   #3627
Derby Bros Racing's Avatar
Here is the list:
-Mugen Front CVDs
-5mm Middle Belt
-Center Post
very nice!
Derby Bros Racing is offline   Reply With Quote
Old 03-01-2006, 08:21 PM   #3628
that's not bad at all. it looks pretty cool. has anyone tested this product?
Old 03-01-2006, 08:30 PM   #3629
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Saw it in a V-One RRR. Looks like it works pretty good. Where do we get one
though?
Racing4Evo is offline   Reply With Quote
Old 03-01-2006, 09:10 PM   #3630
ogreasurada's Avatar
though?
http://www.rcmart.com/catalog/produc...ducts_id=17214
ogreasurada is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
