Old 02-22-2006, 10:00 PM   #3526
Vinyard's Avatar
Originally Posted by Scott Fisher
Tag:
YGPM
Hi scott,
any special reasons for the 23T?
Vinyard is offline   Reply With Quote
Old 02-22-2006, 10:03 PM   #3527
ogreasurada's Avatar
Originally Posted by Tag
can't figure why they make 23t in the first place, i have tried and needed to run some crazy splits like 6mm to get the car run right
Maybe Drag Race? lol
ogreasurada is offline   Reply With Quote
Old 02-22-2006, 10:14 PM   #3528
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by Vinyard
Hi scott,
Honestly I think somebody in Japan hit the wrong buttons on their calculator. The most telling thing is that the original kits came with 23 and 24 pulleys, and they now come with 24 and 25 pulleys.
For those guys that wear out rears fast, start with a 5-6mm split and a 23t pulley. When the rears wear some, switch to the 24t and when the tires are the same size, use the 25????????
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-22-2006, 10:51 PM   #3529
asw7576's Avatar
Are talking the side pulleys ? ( rear bulkhead, near to engine manifold ? )
Old 02-22-2006, 11:00 PM   #3530
Its the front outside one.
Old 02-22-2006, 11:14 PM   #3531
front side pulley
Old 02-23-2006, 12:08 AM   #3532
Vinyard's Avatar
U must be joking..
Old 02-23-2006, 05:27 AM   #3533
VenomWorldOrder's Avatar
for those who running 25t side pully, how do you guys manage to wire the exhaust hanger without touching it ? i am running 24t and there's barely any space between it.
instead of putting the wire holder UNDER the top deck put it on the top, screw on the bottom. and pass the wire through the top of the pipe. you will have ample clearance this way. you might need to bend the wire, but i found this method to be the best. also did it with my 3. check out pic, it's the only one i have sorry.
VenomWorldOrder is offline   Reply With Quote
Old 02-23-2006, 07:58 AM   #3534
You can also bend the wire a bit and it will not touch.
TomiRC is offline   Reply With Quote
Old 02-24-2006, 10:13 PM   #3535
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
after tearing the car down from the winternats, I took some major abuse hits during my main, I found the top deck is cracked and the rear camber bar and shock stay holder is broke. I'm cutting a new upper deck with some extra material around the pipe mount hole, as that is the area it is broke.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 02-25-2006, 06:41 AM   #3536
Corse-R's Avatar
Change your exhaust hanger (the aluminium piece that holds the wire) for a Serpent 950-R one. It's slimmer and has two positions, allowing to decide how high or low will be your exhaust. I use it on my car and like it.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 02-25-2006, 06:46 AM   #3537
Corse-R's Avatar
Seeing your photo I see some things that needs to be revised:
1. Put the body posts that go over the bumber on the outer holes, body gets much better support, you're putting on the inner ones. Helps to avoid body distorting, specially at high speeds.
2. Change the wide bumber for the narrow one, the wide bumper can touch on the ground during heavy cornering and make weird things that can drive you mad.
BTW: You're using the 23T and the short belt? Better to use the 24T ones (at least you want to throw up to 6mm of diameter of your front wheels). Handling is much better. Use the 24T and about 2.5mm of tyre split between Fronts and Rears, helps too to have a little more shoch travel on the front.
Cheers,
Corse-R
Old 02-25-2006, 10:48 AM   #3538
Thanks for the recommendations Corse.
Old 02-25-2006, 10:59 AM   #3539
asw7576's Avatar
That's the good side of using short bumper..... more consistant driving and easy cornering.
However, there is also a good side for using wide bumper, if you hit the wall at angle, there is more chance you save the front suspension arm or save the steering upright and continue the race.
My friend keep using the wide bumper while I don't .... I watch his car often survive from impact ( thus he is able to continue racing ). In contrast sometimes I can't continue racing if I hit the wall and lost the steering upright ( pop off !!! ).
Old 02-25-2006, 12:15 PM   #3540
I think you can file the bottom of the sides of the wide bumper at an angle so when the car turns at extreme angle there is still recess space for the bumper..
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
