Old 02-20-2006, 08:27 PM   #3496
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by rcfoolz
4mm shock tower from mugen....T0508
James why don't you put a pic of the option parts you are making for your car especially the camber link mount
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 02-20-2006, 09:23 PM   #3497
Originally Posted by GrandeGixxer
The wheel hexes and shock tower are the first things I upgraded as well. However, after breaking the 3mm Skyline shock tower, I am now back to the stock one because its the only one I could find at the time I needed it. I am very happy with the car though. The only real other weakness is the clutch bearings. The 5x8mm is just too small to be durable.
I've heard of others killing their bearings as well but I still have not lost a single one. I lube them with teflon grease about every hour run time. I'll try to get a photo online of the stuff I use.
As for the shock tower, just go 4mm. 3mm is too fragile.
Rob
going4#1 is offline   Reply With Quote
Old 02-20-2006, 10:34 PM   #3498
asw7576's Avatar
Originally Posted by Corse-R
And sometimes with the car at 199mm width, handles like sh*t. Specially on tight tracks or tracks where you need a quick response and change of direction.
Ways to cope with traction roll are:
- Smaller diameter of tyres (shave the outer side of the tire with a rounded shape).
- Lower the ride height of the car (I've run the MTX3 up to 4mm high). That's why I missed the rear upstops.
- Stiffer hidraulics along stiffer springs.
- Camber on the front external wheel.
- Stiffer roll bars.
And... if the track allows it (most of the turns to the same side), put on the front external wheel something harder (i.e: Fr. 40 interior, 42 ext and 40 int/ext at the rear).
oops... sorry, you are right !! ..... my hometrack has lots of sweeper corners and not very technical. I guess 200mm front and 199mm rear setup only apply to my hometrack.
Originally Posted by going4#1
I use the JP version (6 fin model) but it's the same thing. 6 fins is great on a mixed track with both long straights and lots of tight turns. Car is very responsive.
Tip
Small number of fins = speed
Large number of fins = torque
Are you sure about the number of fins ? .... never heard of that.
I guess the fewer fins is designed for JP stock engines while more fins for JP mod engines. I could be wrong ....
Old 02-21-2006, 12:54 AM   #3499
Thunder racer's Avatar
hi all. im planin on buying a MTX4.
whats the Cheapest Price anyone has seen them for on ONLINE shops?
send me links.....
THANKYOU
Thunder racer is offline   Reply With Quote
Old 02-21-2006, 01:18 AM   #3500
sparksy's Avatar
Trader Rating: 14 (94%+)
Why dont you try google?
sparksy is offline   Reply With Quote
Old 02-21-2006, 04:25 AM   #3501
I guess the fewer fins is designed for JP stock engines while more fins for JP mod engines. I could be wrong .... [/QUOTE]
With a smaller number of fins, the pipe is shorter so exhaust pulses are faster (i.e. the exhaust gas escapes faster so the piston will move with less resistance). With more fins, the pipe is longer and exhaust pulses are slower (i.e. the gas escapes slower). With more exhaust gas your engine+muffler is like a water pipe with partial blockage: you have less water coming out but it's coming out with more pressure.
The kind of engine doesn't matter. Take a look at the competative 1/8th buggy crowd. Very long manifolds for max torque. Concept is the same for on-road but due to lack of space, makers elongate the manifold in a different way but with the same result.
Old 02-21-2006, 06:06 AM   #3502
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
710baby....The guy that had the idea of putting the camber link with the body mount....excellent Idea. It will be done later today, and i will post a pic of that.......EXCELLENT IDEA GrandeGixxer!!!!
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 02-21-2006, 07:26 AM   #3503
Corse-R's Avatar
If you're killing thrust bearing is because you have too much play on your clutch bell, 0.5 - 0.75mm of total endplay is enough, too much and your bearing will suffer excessive punishment with the fatal and expensive consequences (12 euros the piece) that a blown thrust bearing will have for you.
I don't know if it's available now, but some time ago I got one tube from Ron Paris specially for the thrust bearings (Ronnie's Grease seemed to remember was called - their color is green).
Ever before a practice day or race I checked the thrust bearing, cleaned (a spray with brake cleaner) and applied the grease with toothpick or the edge of a screwdriver a little of it to the thrust bearing balls and never repeat: never had a blown thrust bearing. In fact, the one that goes on my MTX3 was the one that came in the box and he has about 50 or 60 litres of fuel over their shoulders. Got lucky probably, this is an extreme case, but many of my friends never needed to retire due to a blown bearing.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 02-21-2006, 08:40 AM   #3504
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
RC FOOLZ, does this mean I get to assist in the R&D of the product? I can test for no charge whatsoever!
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 02-21-2006, 08:50 AM   #3505
asw7576's Avatar
The kind of engine doesn't matter. Take a look at the competative 1/8th buggy crowd. Very long manifolds for max torque. Concept is the same for on-road but due to lack of space, makers elongate the manifold in a different way but with the same result.[/QUOTE]
I see.... you were talking about JP pipes.
I thought you were talking about Engine Heatsink 's Fins.
Sorry...... got it mixed up.
Old 02-21-2006, 08:50 AM   #3506
rcfoolz's Avatar
I don't charge for my items, I do it more for fun. Just send me an address via PM and I will send one as soon as I have it done.
Old 02-21-2006, 02:25 PM   #3507
rcfoolz's Avatar
Ok.....had time to play with the design. I came up with one, but the problem is that the body mounts are now narrow. I had to do this due to the camber arms. The only other way to do it is to put the body mounts up through the rear window, and this would cause all the down force to be removed from the wing and soften the rear of the car.
Old 02-22-2006, 12:13 AM   #3508
FF25510's Avatar
Default new parts from KAWAHARA
one pair of uper arm holder 3360 yen, 6300 got both.
chassis 6090 yen
FF25510 is offline   Reply With Quote
Old 02-22-2006, 12:24 AM   #3509
asw7576's Avatar
chassis 6090 yen
How many mm thick ?
Old 02-22-2006, 01:06 AM   #3510
jaykay's Avatar
Hi guys,
do you primed your new ball bearings? Like cleaning it with brakecleaner and put in new bearing lube ?
I have seen, that some guys open one side of the bearing and let it open.
jaykay is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
