Old 02-16-2006, 05:37 AM   #3406
ElectricConvert's Avatar
Originally Posted by GrandeGixxer
Convert, who makes that front sway bar, is it the 3racing one? I have been looking for one with the cams on both sides.
Kawahara makes them.
ElectricConvert is offline   Reply With Quote
Old 02-16-2006, 06:07 AM   #3407
VenomWorldOrder's Avatar
looks good Allan. get the alloy skyline rear brace and also very important the alloy sway bar holder thingies, (the bit the grub screw goes through)
what brand is the rear swaybar. i want one man!!
also kawahara chassis is $60 oz landed. you should see my car. check it out when you pick up the body.
VenomWorldOrder is offline   Reply With Quote
Old 02-16-2006, 06:38 AM   #3408
Trader Rating: 15 (100%+)
Question for anyone that wants to answer. How are you setting up the cam on the front arms for the sway bar? Are you doing it with the shocks not hooked up or with them hooked up? Are you looking at the through of the arms? Let me hear the process you go thru. Thanks
THE DOCTOR is offline   Reply With Quote
Old 02-16-2006, 07:23 AM   #3409
This is how I set my droop.
1. Take of shocks from bottom arm mount.
2. Remove one of the sway bars but leave the holder.
3. Set the cams to the bottom of its range of movement.
4. Set the droop on the Hudy droop guage giving it 1 mm less droop than I intend.
5. Install and set the sway bars to the desire angle.
6. Connect the shocks.
7. Re-measure droop on guage and use the cams to adjust to the originally desired setting. Snug down the screws on the cams.
As I run throughout the day and suffer from chassis tweak, I'll simply use the cams to eqaualize my droop. The 1 mm allowance in step 4 comes in handy during these times.
If the cams aren't giving me the correction I need, I'll redo it from step 1 but not before I check the chassis' flatness.
I hope this helps
Old 02-16-2006, 07:44 AM   #3410
I can see how you can do that with the double cams but I can't see how I could set the droop on both sides with only one cam like the stock set up. I use the cam more for setting the swaybar in the neutral position.
Old 02-16-2006, 07:57 AM   #3411
In your case, I'd use the droop grub screws as the primary means to get neutral setting, and use the cam for fine tuning. The issue here is that the side with the cam is reliant on the one without, assuming the side with the cam hasn't lost it's setting, I'll adjust the other side using its grub screw.
Old 02-16-2006, 08:23 AM   #3412
GrandeGixxer's Avatar
Thats why a swaybar with the cams on bith sides is SOOO important. Hello MUGEN, what were you thinking? I definatly will be making that addition to my car.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 02-16-2006, 11:45 AM   #3413
Chris West's Avatar
Send a message via MSN to Chris West
Coming soon are:
MR Ninja R01
I think a MR Ninja T01 will fit alot easier
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 02-16-2006, 11:57 AM   #3414
ogreasurada's Avatar
OMG, everyone's MTX4 is so shining. ....Mine's still looking plastic black..
ogreasurada is offline   Reply With Quote
Old 02-16-2006, 02:43 PM   #3415
Doh!, thanks.
Old 02-16-2006, 07:23 PM   #3416
Dumb question but want to make sure for this car. Type of motor: rear exaust slide carb right....what about the shaft....can i use a rotary? What are the pros and cons ?
Bubonic-X is offline   Reply With Quote
Old 02-16-2006, 07:39 PM   #3417
Who makes those double cams?
Old 02-16-2006, 07:41 PM   #3418
Kawahara.
Old 02-16-2006, 07:48 PM   #3419
I don't think there is any choice in crankshaft. It has to be an SG type. Slide carbs are the way to go for onroad due to the linear response it gives to user input.
Old 02-16-2006, 07:51 PM   #3420
Derby Bros Racing's Avatar
rear exhaust slide carb - yes
the shaft has to be pilot also know as SG shaft. the threaded like those used mostly for gas trucks will not work.
the car is designed to use slide carb. rotary will not work. it may with some modification but the linkages included with the kit as well as the placement of servos only accepts slide carbs.
Derby Bros Racing is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
