Old 01-11-2006, 12:38 AM   #3046
asw7576's Avatar
I double the rear shock tower. I added 1mm spacer.
Old 01-11-2006, 04:29 AM   #3047
VenomWorldOrder's Avatar
thanks for the good words about my car! i also like it arot
regarding weight i have added up all my option parts and the results are this:
STANDARD PARTS
all the standard part from the kit i removed weighed a total of 72.4 grams. i weighed each part individually
OPTION PARTS
all option skyline parts weighed 92.9 grams
RESULTS
the option parts make it 20.5 grams heavier. i also have installed titanium pivot balls and a even lighter two speed shaft. the shaft i am using is 10.5 gams so my car is actually only 15 grams heavier.
the mono titanium screws weigh a total of 39.7 grams but not all the screws in the kit are used, and i left the steel screws on the bottom of the chassis on the car for strength reasons. all other screws are titanium, so my car is probably equal if not lighter than standard due to the screws and titanium pivots.
VenomWorldOrder is offline   Reply With Quote
Old 01-11-2006, 11:10 AM   #3048
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
For all those guys that are doing the weight watchers thing going on here lately, I got to weigh my car the other day. We are getting ready for the Winter Wind Up race so I decided it was time to check the weight.
My car has the following changes compared to a stock MTX4
Mugen Titanium pillow balls
Skyline radio tray support
Skyline hollow steel 2 speed shaft
Kawahara 1st gear adaptor
Kawahara 2 gear adaptor
Mugen Titanium upper screw kit
Mugen MTX3 rear CVD's installed on the front
Mugen MTX4 rear CVD's installed on the rear
RC products 4mm rear shock tower.
AMB Personal Transponder
I was using the following servos both with aluminum servo horns. I have a Futaba 9451 on steering and an Airtronics 94737 for throttle. I used a Protoform Dodge Stratus. I measured using a hotmod Novarossi N12LL3 with a monotuning 11 fin head (stock head weighs 42g, monotuning head weighs 45g). I weighed it using Kawahara tires trued to 58.5f, 59r.
My car weighed 1695g.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-11-2006, 11:22 AM   #3049
Derby Bros Racing's Avatar
wow! that's great. i think i'm headed that way also as far as upgrades/changes to the car. i posted a while back about my "diet" program and i'm still not done.
me and my bro won't make it to vegas for the windup. we'll just make it up on april. good luck to you and all mugen people!
Derby Bros Racing is offline   Reply With Quote
Old 01-11-2006, 11:25 AM   #3050
Corse-R's Avatar
Originally Posted by asw7576
I installed mtx3 prospec brake rotor, and for your information, the upper brace ( rear bulkhead brace on top of brake rotor ) is not fit.
You need to file some plastic underneath it so the width of the rotor would fit.
I also add springs between the brake pads.
Look beefy now
Hi Asw.
As you told it, needed to file a little the upper brace, but nothing that a quick pass of dremel could solve.
Regarding springs between brake pads, tried as many people on my MTX3 and MRX3 and gave us many probs (I tried with 1/12 front spring) and didn't worked at all, better to thinker a little more and with a sanding drum, remove a little the threads at the end of the screw (where the metal pad touches with the screw) to free as much as possible and ensure that brake pads doesn't bind with anything.
Agree, looks beefy and brakes much better (at least mine does).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-11-2006, 11:30 AM   #3051
Corse-R's Avatar
Keeping your lower side steel screws is better, in fact, lightening the upper side you're lowering your CG a little more.
On all mine cars, titanium pivot balls only went on the front upper side, to help a little more to do this, the lower are of steel.
Cheers,
Corse-R
Old 01-11-2006, 12:01 PM   #3052
sohlman's Avatar
Trader Rating: 89 (100%+)
Scott, why aren't you bringing that "light-ass" 4 to the WinNats? Or are you?
Steve Sohl
sohlman is offline   Reply With Quote
Old 01-11-2006, 12:10 PM   #3053
The Internal Revenue Service and I are having a debate so I am keeping travel to a minimum until we resolve our disagreement.
Old 01-11-2006, 12:19 PM   #3054
sohlman's Avatar
Ahhhhhh ...well then guess I'll see you at the RD Logics race. Good luck!
Steve Sohl
Old 01-11-2006, 12:29 PM   #3055
Cool Steven. Good luck in Florida and I guess I will see you in April.
Old 01-11-2006, 07:27 PM   #3056
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hello, anyone know the thickness of the 3-racing rear shock tower ? looking to get one soon and need input.
thanks
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 01-11-2006, 08:23 PM   #3057
THESHOCKER's Avatar
Dear VenomWorldOrder,,
Here is YOUR quote "DEAR USA, this is YOUR president:
"Bureaucracy is not going to stand in the way of getting the job done for the people." -President Bush, Sept. 6, 2005. after 5 days of idiotic inaction towards helping katrina sufferers DEAR bUSH, you ARE THE ADMINISTRATION!!!!..so either move aside, or better yet, STAND DOWN "
Did you not hear the goverment tell all the people of New Orleans to get out?
Why should our government help the people that did not listen to them.
If your government told you to get out or die what would you do??????
I hope you would choose the latter..............
Please lets keep your political and religious views to yourself.
THESHOCKER is offline   Reply With Quote
Old 01-11-2006, 08:30 PM   #3058
chookgb's Avatar
Trader Rating: 26 (100%+)
although this is the mtx-4 thread i would say the issue is the less fortunate people who did not have their own transport or enough money to pay for the transport out for their whole family were left with no choice but to stay and fend for themselves , enough said lets get the thread back on topic
chookgb is offline   Reply With Quote
Old 01-11-2006, 11:02 PM   #3059
MAVICXXX's Avatar
Originally Posted by tommi
Maybe you should use spacers/shims on the lower suspension arm ball stud to compensate back the shocks' angle resulted from the thicker shock tower? From what I gathered, shims were included in the 4mm rear shock tower made by Skyline for the RRR, reviews on it were nothing but great.
i v got good clearance wit the spacer ofcoz..but thats not the reason coz from the 1st day i double it up,got it in great position,it is straight,but it does not do any good,thinkin of getting it STOCK again..
current my kit is lighter by 20grams.by adding double lay,ofcoz increase now..
MAVICXXX is offline   Reply With Quote
Old 01-11-2006, 11:07 PM   #3060
ay chook did i beat you with the bling factor?? my car is too nice to race now.
and here is my body for it its a blitz mazda 3
Mugen MTX-4-mtx46.jpg   Mugen MTX-4-mtx45.jpg   Mugen MTX-4-mtx44.jpg   Mugen MTX-4-mtx43.jpg
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
