Old 12-18-2005, 05:22 PM   #2716
Just used my MTX4 for the first time and after about 20 mins the second plastic spur gear stripped. Why would this happen? the engine is square with correct mesh.
josh_c is offline   Reply With Quote
Old 12-18-2005, 05:36 PM   #2717
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Check the clutch bell bearings. The inner one is probably gone.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 12-18-2005, 05:39 PM   #2718
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Scott Fisher is correct about the Alfa, But at the last state race at Ft Myers, I had to run the Alfa after trashing my Mazda body. I was suprized to see how it performed of the mtx4, but on the 3, it was unstable.
If your 2speed hub was rubbing the clutch bell, this gear will strip out. Look at your 2nd speed hub to see if there is a small ring rubbed in it from the clutch bell. It has very little clearance.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 12-18-2005, 05:42 PM   #2719
dg8one's Avatar
Originally Posted by ogreasurada
I thought the Alfa was for elet. carpet?
yah!!! but a couple of guys here run it......i'm having diffuclty on the masda 6
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 12-18-2005, 05:43 PM   #2720
dg8one's Avatar
difficulty mounting the masda 6
TOKWA'T BABOY LTD
Old 12-18-2005, 05:48 PM   #2721
rcfoolz's Avatar
I think somebody wrote the best way, remove the foam bumber and mount it, then put the foam back on and cut it till till it fits.
who all on this thread is going to the January race for a warm-up for the winternats?
Old 12-18-2005, 05:51 PM   #2722
ogreasurada's Avatar
Have you tried running with the Stratus 3.1 yet?
ogreasurada is offline   Reply With Quote
Old 12-18-2005, 06:08 PM   #2723
Checked the bearings and theyare fine
Checked the two speed hub and no marks.
I think i found the problem, clutch bell wasn't shimmed enough and had too much play.
Old 12-18-2005, 06:29 PM   #2724
dg8one's Avatar
i did that but theirs nothing left on the bumper
TOKWA'T BABOY LTD
Old 12-18-2005, 06:45 PM   #2725
Send a message via AIM to jeff whiting
I am going, got my tickets, hotel and rental car. I'm working out what I can get on the plane and what I will check. Should be interesting. My X3 Prospec is so good that I may start out with it. I will bring my X4 and give a good test. It hasn't turned a wheel yet so we will see.
JEFF
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 12-18-2005, 07:43 PM   #2726
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You won't have a lot left of the bumper, but you will still have enough bumper.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-18-2005, 07:50 PM   #2727
We have also found another cause for the spur gear stripping. Check you carburetor and make sure it is not hitting your brake disk. I know it sounds stupid, but check it anyway. Some people have rotated their carbs and it rubs on the brake disk. It has caused a problem for some racers.
Another thing that can cause 2nd gear to strip out regularly is if you are catching air. When you catch air, you have two things that strip gears.
1st: The launch and landing cause chassis flex which can strip gears.
2nd: When you land, if you don't get off the gas you have all the instant loading on the geartrain.
Old 12-18-2005, 08:10 PM   #2728
Scott, you haven't been to Crystal Park again have you? I did strip 1 2nd gear there, in the first round of qualifying.
Joe Cude
Old 12-18-2005, 08:17 PM   #2729
I wonder if the small engine mount screws have anything to do with striped gears?
Old 12-18-2005, 08:22 PM   #2730
What do you mean by small? the mounts and screws look to be the same as they were on the -3?
Joe Cude
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
