Old 11-27-2005, 10:00 PM   #2356
The front belt looks loose, but with it set at normal position, it works just right. I have both side belts: the fiber one was way way to loose. The rubber one is just right. Make sure you don't put the 23 tooth in the rear.
mgreen is offline   Reply With Quote
Old 11-27-2005, 10:12 PM   #2357
MAVICXXX's Avatar
theres been few guys here asking bout the pulleys too,well u v got to identify d pulleys and mark it if u can.
Side belt came in 2 pieces,u cant missed it coz d 24t pulley came in a plastic bag together wit d belt and d ratio chart.Ezier way is d 24t belt clearly state bando sts which is rubber.
D frona nd rear u shouldnt got it loose coz stock aasembly fits in with good tension.Currently i m using all around rubber base belt and yes it is great too,smooth,less dirt sticking,not ez damaged by small rock goin in..
I came across too wit d 2nd gear housing ouching the sway bar,well d it happens when u get to much drrop on your rear..but if u nid to have that much,then make d turnbuckle on d sway bar attach to d lower arm longer..
MAVICXXX is offline   Reply With Quote
Old 11-27-2005, 10:20 PM   #2358
MAVICXXX's Avatar
i m tryin to get d weight close to 1720grams without transponder and fuel wit 57mm tyre diam. Currently mine stil wit 1750grams,what i did on is putting d alm Kfac rear lyshaft and 3pcs 3racing pulley adaptor and titatium pillows kfac.Thinkin of getting few titatium screw and 1st gear housing lightweight Kfac,should it b enuf?
well ofcoz bit hevy weight coz i m using d receiver box instead of stock receiver cover..
Old 11-28-2005, 12:29 AM   #2359
FF25510's Avatar
Originally Posted by k617nu-b
you mean the pulleys? can you tell me how many teeth pulley should go to what side and what shaft...im confused, this is my first build of the 4 and the manual is not as clear as to what number of pulley should go to this specific shaft...i saw some pics in the mugen website and it seems that for middle shaft, the side belt pulley is larger than the main shaft side belt pulley (outer one) and still i can see minimal slack in the belt, not so loose...
No, i mean the marks on the bulk head, there are total six marks on the front n rear, make sure you have used the standard one. By the way, front pulley - oneway + 18 , rear pulley rear diff + 19 , side belt - 23 or 24 + 18 attach photo can make it clear.(i hope from left to right 24, 23, 18, 18, 19)
FF25510 is offline   Reply With Quote
Old 11-28-2005, 12:36 AM   #2360
FF25510's Avatar
the marks on the bulk head, the position near the end chassis is the standard and the tighten one.
Old 11-28-2005, 12:45 AM   #2361
moot's Avatar
so the 'standard' position is the tightest?
moot is offline   Reply With Quote
Old 11-28-2005, 08:23 AM   #2362
FF25510's Avatar
Yes.
Old 11-28-2005, 08:52 AM   #2363
Jea3's Avatar
Well, I saw RCFOOLS MTX4 run at the World Famous Kissimmee RC Raceway, where the 1/8 Scale / 200mm Outlaw Nationals ran. He had the new carbon fiber chassis under the car. He seemed very fast on the track, and intentionally ran into the walls, breaking the car. I was surprised to see the chassis didn't have a problem taking the hits. His engine temps stayed under 240 with hard driving.
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 11-28-2005, 09:04 AM   #2364
asw7576's Avatar
He has 5 graphite chassis remember
Old 11-28-2005, 11:45 AM   #2365
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Not any more...Sold 3 of them. and have the other on ebay
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 11-28-2005, 01:23 PM   #2366
asw7576's Avatar
What is the handling effect of adding and reducing shims on the rear upright ?
Is it crazy if I add 3 shims or 3mm on the rear up right ?
Old 11-28-2005, 03:48 PM   #2367
rcfoolz's Avatar
The more shims you add, the more rear traction you will produce with lower roll center. Not crazy, I've seen that before.
Old 11-28-2005, 03:54 PM   #2368
moot's Avatar
Originally Posted by FF25510
Yes.
so looser the better? the futherest (is that a word )ones away from standard?
Old 11-28-2005, 03:55 PM   #2369
moot's Avatar
i always thought that reducing the shims on the rear uprights gave more traction?
Old 11-28-2005, 09:57 PM   #2370
drfritz's Avatar
The longer the camber length the greater the car will roll to the out side edge of the tire and that will give you more side bite.
drfritz is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
