Old 11-25-2005, 01:48 PM   #2326
chookgb's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Scott Fisher
Chookgb:
I see you mounted your rear body posts backwards. Move your rear suspension through its motion of travel and make certain your camber links don't hit the body posts. Remember there will be some movement and flex. At very least you will probably want to use a dremel to thin the body post area or the suspension will hit it during use on the track.
Why did you mount them backwards?
i have already dremelled the body post and the camber link doesn't rub, it didn't rub on the standard tower so it wont rub on the 3mm tower as it wont flex like the standard one and the reason i turned all the posts around was because i had brand new painted pre drilled bodies from the mtx-3 which i needed to use
chookgb is offline   Reply With Quote
Old 11-25-2005, 05:05 PM   #2327
Remy's Avatar
Just saying hello. I used to own a hopped up to death r-40 which ran very strong this past season. Now I own a mtx-4.....well I will next week when it arrives.
I hope I could be of some help here or rather the other way around lol
Remy is offline   Reply With Quote
Old 11-25-2005, 10:04 PM   #2328
rcmike's Avatar
Trader Rating: 40 (100%+)
Default Rear body posts
When i had my hudy set up guages on the rear end of car. The body posts were in the way of the toe-in plate.Probably will flip them around the tower for the next new body
rcmike is offline   Reply With Quote
Old 11-25-2005, 11:02 PM   #2329
Chris West's Avatar
Send a message via MSN to Chris West
I like those aluminium parts , will they ever be available in New Zealand or on RC-Mushroom. I want to get some.
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 11-25-2005, 11:23 PM   #2330
Default 2pcs Centrifugal Shoe
Hi to all!
Has anybody try running 2pcs Centrifugel Shoe instead of 4pcs in your engine clutch system?
If yes,what is the feeback?Thanks!
MTX4 is offline   Reply With Quote
Old 11-25-2005, 11:34 PM   #2331
Christ West, you can email us for more info. Thanks.
[email protected]
monotuning is offline   Reply With Quote
Old 11-26-2005, 05:32 AM   #2332
stefan's Avatar
Send a message via AIM to stefan
[email protected]
Aaron,
did you get my PM?
Thx,
Stefan
stefan is offline   Reply With Quote
Old 11-26-2005, 09:56 AM   #2333
nitrodude's Avatar
I was wondering if someone can tell me the number of teeth on the MTX4 pulleys. I need to know them all. Front , inside layshaft, outside layshaft, outside 2spd shaft, brake pulley and rear diff pulley.
thanks
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 11-26-2005, 10:25 AM   #2334
one-way 28, mid 18, side front 24, side rear 18, brake 19, rear diff 41
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 11-26-2005, 12:29 PM   #2335
Registered User
MTX-4's Avatar
Originally Posted by MTX4
Hi to all!
Nice name....
MTX-4 is offline   Reply With Quote
Old 11-26-2005, 04:26 PM   #2336
2 shoe or 4 shoe should not matter just as long as it fits. I'm running Ofna parts with the MTX4 clutch-bell and pinnion gears. You would have better performance with the 4 shoe setup.
mgreen is offline   Reply With Quote
Old 11-26-2005, 10:48 PM   #2337
k617nu-b's Avatar
Guys question about the MTX4 build, approx. how long should the exposed part be of the upper and the lower ball screw for the front upper and lower a-arms connection to the knuckle arms as shown in the pic, i used the mtx-3 front universal joint but when i screw in the ball screw so that the thread are all imbedded in the a-arms and exposing only the smooth part, it feels hard to turn the knuckle arms. Just started the build last night but i managed to do the front suspension only, will continue it tonight. Thanks..
k617nu-b is offline   Reply With Quote
Old 11-26-2005, 11:42 PM   #2338
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Something to look out for and inspect after every race.
Rear lower arm hinge pin inserts. If you push down on your chassis and hear a click, or you hold your car off the ground and rev the engine, you might hear a "click" or a feel a thump in the car when the engine comes back to idle. You will need to check these often.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 11-26-2005, 11:48 PM   #2339
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Scott, Are you ready for toys for tots? Is the set-up similar as for Revelations? I have never been there.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 11-27-2005, 12:04 AM   #2340
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
K617: There isn't a correct amount to turn in the pillow balls. How much they go in depends on how wide you want to run your front end and what offset wheel you are using. I found when using the Mugen 2mm offset wheels and running the front end narrower than 199mm that the MTX3 front universals would bottom out and bind inside the oneway outdrives. I am currently using MTX3 rear universals on the front of MTX4. Before you change anything put on your front tires and use a caliper to measure the width of your front end. If you don't understand, ask again and I will show you a picture of my car with the calipers as well as the length difference of the two different universals.
rcfoolz: Did you break one of adjustable roll center hinge pin bushings? Mugen uses a similar system on the MBX5 and not too long after somebody was making brass bushings.
Gixxer: I don't know if I am ever really ready for a race. I got two new engines this week and I hope to get some gas through them before I get there. This is the perfect race to test new engines. While I have never been to Crystal Park, I have been told by SEVERAL racers that whatever setup I come up with on my home track will work well at Crystal Park. Revelation is a unique place and I wouldn't count on using a Revelation setup anywhere else except Revelation. I had a good test day last weekend and weather permitting will get a good test day in here tomorrow. Hopefully I will have something dialed for Crystal. I need to since I told a couple east coast Mugen drivers they are going down like a couple of $2 hookers.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
