Old 11-13-2005, 07:44 PM   #2011
MAVICXXX's Avatar
Originally Posted by rcfoolz
has anybody had a problem with the clutch bell hitting the 2speed hub? I've had this happen 2 times and my 2 speed is showing signs of "bands" being rubbed on the edge. I'm thinkinb about machining a few mills off the 2 speed hub where it is rubbing
did u put thick shimming before assembling d flywheel?but it shouldnt be it,mybe accidently u mount d engine misaligned..strange..
MAVICXXX is offline   Reply With Quote
Old 11-13-2005, 08:00 PM   #2012
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by MAVICXXX
i dunt think so u may do like X3 coz been trying few times cant be done..
current practice me do take out d whole unit rear part then only d engine comeout ezly.. d problem is d upper deck bit longer til touches d engine mounting/crankcase while u wana lift up to take out..
try and c.. i also want to get d simpler way to do it..
another thg, Riketsu:
1st no more using long screw for d rear knuckle assmbling d camber linkage or steering linkage,it is now more better way it was done..but for the front&rear 3mm shock tower,it is like logical to fit 4mm,there should be option parts for it later..but d lastyear Brazil WC,i saw most RRR running wit 3mm still maybe their hands stiffens d shocks..
I have seen some drivers at my track with the rear camber link loose. Better safe than sorry.
Riketsu is offline   Reply With Quote
Old 11-13-2005, 08:03 PM   #2013
asw7576's Avatar
Mtx3 flywheel onwards are totally different than in mtx4, so be careful not to mix the flywheel and clutch bell.
Maybe you use mtx3 flywheel ?
Old 11-13-2005, 08:10 PM   #2014
MAVICXXX's Avatar
i wont make that mistake in assembley..
riketsu,by d way..how they solve d camber linkage from loosen? i understood d linkage should b like kyosho better coz mugen linkage is smaller and small picth threading,so thats why when turning few times ofcoz to adjust d camber,it tends to loose..
good after sales s/parts too..
Old 11-13-2005, 08:11 PM   #2015
ilaybrk's Avatar
mine did same thing today i also already blew one of 5/8 bearings so I hoped bearings would hold up better other than that car was great faster than my 3 with same setup. Does anybody know what kit tires are as in shore.
ilaybrk is offline   Reply With Quote
Old 11-13-2005, 08:15 PM   #2016
Hello everyone
Im looking at both the serpent 710 and the MTX-4. Im just wondering what has the best parts availability, plenty of hop-ups and is very durable. Just looking for some opinions.
Thank You in advance.
cars.cars.cars is offline   Reply With Quote
Old 11-13-2005, 08:15 PM   #2017
Riketsu's Avatar
Guess my grammar aint that good. Meant the link came off. Like the shocks's quick release. If you observe the MTX-3's construction, most of the parts will hold together because of screws and there is no such thing as a quick release (except steering turnbuckles). I gotta ask the question: when have you broken a MTX-3 Shock, or one of the shocks has come off? Its just some of the weak points I have seen the drivers suffer at my track.
Old 11-13-2005, 08:37 PM   #2018
sparksy's Avatar
Trader Rating: 14 (94%+)
Check to see if its the rear roll bar hitting the housing. If my down stops are not set correctly the roll bar will rub.
sparksy is online now   Reply With Quote
Old 11-13-2005, 08:51 PM   #2019
MRX_joe21's Avatar
Send a message via Yahoo to MRX_joe21
Originally Posted by cars.cars.cars
Hello everyone
Go with MUGEN.
MRX_joe21 is offline   Reply With Quote
Old 11-13-2005, 08:52 PM   #2020
any reasons...is it more durable, better handleing, better speed?
Old 11-13-2005, 08:56 PM   #2021
MRX_joe21's Avatar
It depends on your taste? for me i like Mugen than kyosho or serpent...
Old 11-13-2005, 09:02 PM   #2022
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by GrandeGixxer
The car seems to be a little more sensitive to setup changes. It has a lot better acceleration because of the new gearing. It seems to be faster on the track, but is a little more fragile. There are a couple of weak points(rear shock tower/probably more). The eccentrics to adjust the belt tension are a good idea, but it is hard to tell when they are "keyed" into the bulkhead caps. I believe this car will spank the RRRRRRRRR in the worlds. If I am wrong, I will buy myself the first round at the bar that night.
Joe, I think that you forgot your radio at the track today, you should give them a call.
Walter Diaz
wad is offline   Reply With Quote
Old 11-13-2005, 10:25 PM   #2023
rcabj's Avatar
hi..anyone havin problem the tires touching either the front/rear knuckle...(when using 0 offset tires) thanks...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 11-13-2005, 10:41 PM   #2024
asw7576's Avatar
What tires brand do you use rcabj ?
Old 11-13-2005, 10:46 PM   #2025
rcabj's Avatar
actually its a friends car, he tried with the 'arrow' tires from grp (i believe 0 offset) it touches the knuckles...and when using the ellegi's with 1mm offset its ok...
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
