Old 07-01-2005, 11:56 AM   #151
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
its a little MRX-4.........
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 07-01-2005, 11:58 AM   #152
JLock's Avatar
Not quite, but it would have been nice if Mugen did design it the same as the big car.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 07-02-2005, 06:50 AM   #153
Seisick's Avatar
whoaa! finally a cad pic!
hopefully not late let's see if mugen pleases my wish list for this coming mtx4.
cvas at least on the front
3 post mount on the screw that goes over the steering bearing.
left side brace
machine aluminun mounts with 4mm hole, if not at least 3x10 on 3mm hole.
tank flatter (the pic already confirms it) and will let use 2/3 aa similiar to rrr's, which is great, 1400 mah might be used.
all this on $380 and lower! yeah! got myself a cristmas present!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 07-08-2005, 03:42 AM   #154
not sure if its just me but on the rhs bulkhead there are 2 screws which screw straight down that are not holding the top plate. could this be an easy to remove diff???
onto greener pastures
stuff for sale associated 12r5 $175, team magic 1/10 pit bag $40, top racing pit bag $30, KO helios with spektrum module and 3 receivers $200, CEN CT5 $100 all are plus post
dangles is offline   Reply With Quote
Old 07-08-2005, 09:48 AM   #155
Can we upgrade our MTX-3 to MTX-4? or is this a completely new car and parts are not interchangeable.
penggoy is offline   Reply With Quote
Old 07-08-2005, 10:49 AM   #156
Derby Bros Racing's Avatar
yeah the front end looks like the 710 with easy to remove diffs. if that's the case, that'll be great!! i hope the rear is easy to remove also.
Derby Bros Racing is offline   Reply With Quote
Old 07-08-2005, 10:53 AM   #157
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Im hoping this is possible. Even if it costs $100 to do so. There are some racers that can't keep changing cars each time a new one comes in the market. Reason why I choose Mugen, cuz they make good stuff that doesn't need to be changed in a while.
Riketsu is offline   Reply With Quote
Old 07-08-2005, 11:27 AM   #158
gonzoY5's Avatar
Well it has been at least 3 years since the 3 came out. I doubt there will be an upgrade if their history hasn't shown this.
gonzoY5 is offline   Reply With Quote
Old 07-08-2005, 11:35 AM   #159
Perez's Avatar
it looks just like the old one
Perez is offline   Reply With Quote
Old 07-08-2005, 11:58 AM   #160
Riketsu's Avatar
Hopefully they will make new history with this one.
Old 07-08-2005, 12:39 PM   #161
Two-speed's Avatar
They FINALLY centered the fuel tank! I don't know why, but that always bugged me.
The only upgrade Mugen offered in the past was the MBX4-RR to MBX4-XR conversion, which were very minor changes.
Hopefully some Prospec parts will work, i.e. universals, titanium pieces, hubs, bearings, gears, clutch parts, brake disk, fuel tubing etc.
Two-speed is offline   Reply With Quote
Old 07-08-2005, 12:41 PM   #162
fuel tubing
Old 07-08-2005, 05:38 PM   #163
Seisick's Avatar
I donīt know about you guys, but if having easy removable diff on both front and rears sacrifice rigidity and knowing how tough mugens are, I prefer not!
at least if the are like the ones on the 710s, they kind of move and canīt stand an impact like mugen
HobbymaniA
GoT MuGeN?
Old 07-09-2005, 09:53 PM   #164
rcabj's Avatar
this is my wild guess on what will be the changes...
1. lower cg
2. rear ball diff
3. smaler clutch bell
4. smaller/lighter 2speed system
5. shorter length for the uj's
6. different gear ratio's
7. easy diff removal
8. and as obvious from the pics...centered fuel tank , also looks like the shock spriing coil a bit less...
about the battery if they change it to the normal AA type , so additional weight...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-09-2005, 09:59 PM   #165
Riketsu's Avatar
1. lower cg
2. rear ball diff
I dont like ball diffs. I have never had problem with MTX-3's differentials. And I have have had bad experiences with ball diffs on other cars. Probably the 0.8mm gear ratios will become the standard ones. Also a tad-bit longer CVD/Dogbones so I dont have to use fuel tubing to keep it where it should be. Hopefully for the steering links they will use a large screw with nuts after it goes through the ball cup.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
