Old 02-07-2003, 01:43 AM   #1216
squizzytaylor's Avatar
Default two-speeds
Originally posted by V-One S
I asked the same question once,
I was explained it, now i know how it works
But I'd have every1 in worse a shape then before i started explaining
U follow me there?
But i asked mine to my LHS when i was first starting Nitro.
I dont see why they dont make 2 speeds for electrics.
Or do they?
Cause then they would go a little quicker.
(540's i mean)
There are some electric two-speeds available however, I would suspect that 2 primary reasons for electrics not generally running them and or accepting the idea as a whole is.
1) Gearing is accepted as being readily changeable on an ep and most drivers have several spur/pinion combos making thier gearing far more adaptable to particular tracks than a nitro.
2) An electric has a far more useable power/speed range than a nitro allowing good accelaration without so much sacrifice of top end and visa-versa.
This is not fact just my opinion, feel free to respond
gt
squizzytaylor is offline   Reply With Quote
Old 02-07-2003, 01:49 AM   #1217
Send a message via ICQ to V-One S
I see what u mean
Well with the 540's
When i went to a meet while it was on the guy said something about it being the theoretical slowest class our club ran
So i thought, u run a 2 speed, what is it, u gear 1st 25%lower, 15% higher then with a 1 speed, so they'd still end up with a quicker accel and a higher top end.
But then, the other reason out there could be that the sudden drop in RPM isnt good for the electric motors.
But thats my opinion as well.
V-One S is offline   Reply With Quote
Old 02-07-2003, 01:56 AM   #1218
I see what u mean
Well with the 540's
It also requires higher rpm and torque to power a 2 speed although with the big capacity packs now available it shouldnt really be a problem.
gt
Old 02-07-2003, 01:58 AM   #1219
Well they could always develop a softer spring for it.
But yeah
It prob comes down to the power produced from an electric is way lower then a nitro car.
Old 02-07-2003, 03:34 AM   #1220
Brett's Avatar
u would need a stiffer spring to make 2nd kick in at a high rpm
or
u could just screw the grub screw in to make it stiffer
Brett is offline   Reply With Quote
Old 02-07-2003, 03:40 AM   #1221
Brett's Avatar
or
Old 02-07-2003, 04:30 AM   #1222
Well how i took wat squizz said was, that he was meaning a nitro revs higher then an electric, thats why i said a softer one, cause an electric motor might only rev to 6000 whereas a nitro might rev to 10,000 instead, so for the nitro u might engage at 7000 so your engaging at a higher rpm then what the electric motor can spin
Thats why i said softer to allow it to engage at a lower rpm for the motor.
Oh well.
I dont know which engine spins quicker.
So its all my opinion
Old 02-07-2003, 01:24 PM   #1223
Oh well.
Exactly.....Nitros can rev 32-38000 rpm with 1.5+ hp
An electric (I think) Is around 10-20000 rpm so a softer spring would be required.
gt
Old 02-08-2003, 01:10 AM   #1224
Shit i thought it was lower then that.
So how fast u rekon the GS15-r engine revs at?
Old 02-08-2003, 01:16 AM   #1225
Brett's Avatar
yeah i see i thought u wanted it to change at a higher rpm
not that the eninge would have to spin at a higher rpm to get it there
Old 02-08-2003, 01:19 AM   #1226
Oh well, we all make mistakes.
Old 02-08-2003, 01:30 AM   #1227
sausage_link's Avatar
Send a message via ICQ to sausage_link
hi?
i heard that the gs-15r rev's are 29-30000rpms
sausage_link is offline   Reply With Quote
Old 02-08-2003, 01:32 AM   #1228
Default revs
Id reckon 25000 would be optimistic
gt
Old 02-08-2003, 01:34 AM   #1229
Ok kools
I was trying to work theoretical speeds.
But i didnt have an rpm to work with
Old 02-08-2003, 01:38 AM   #1230
Default revs
Originally posted by sausage_link
hi?
I could be wrong but I made that call based on the fact that the engines biggest attribute is torque, this is why the car responds so well to a 2-speed (gearing compensates for low rpm)
gt
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
