Old 01-02-2003, 04:31 AM   #841
sausage_link's Avatar
Send a message via ICQ to sausage_link
yep squizz i just checked rc nitro, with the review of the yokohom gt-4 and the q power manfifold is the same as the yokohomo's manifold accept the yok's manfiold is chrome or shiny
but its the same design
sausage_link is offline   Reply With Quote
Old 01-02-2003, 06:49 PM   #842
Hi guys!
My diffs keep leaking oil. How can I prevent this?
darthkir is offline   Reply With Quote
Old 01-02-2003, 07:10 PM   #843
squizzytaylor's Avatar
Originally posted by darthkir
Hi guys!
If you put a one-way in the front and a solid in the rear it will never leak again!
Only joking! the screws that hold the diff together are 2.6 x 8mm,
replace these with 3 x 8mm, you can give these a little extra torque which will seal it. I know this works for the rear but not the front as it will distort the front pulley.
gt
squizzytaylor is offline   Reply With Quote
Old 01-02-2003, 07:37 PM   #844
well i got a new plug today
the car seems to run good again which is good so i dont need a new engine, but i was trying to take off the heatsink and i stripped to bolts
how can i fix this, im very pissed off
Old 01-02-2003, 07:47 PM   #845
Default sl
Major bummer man! did you just strip the screw or have you stripped the internal block thread? if its just the screw, just clean out the thread and replace it, if its the block I'm not sure. Let us know how you get on.
gt
Old 01-02-2003, 09:02 PM   #846
i stripped the part of the screw where the allen key goes in
the bad thing is its still screwed into the engine
Old 01-02-2003, 09:07 PM   #847
Can you get your hands on a hudy hex driver? that will probably get it out! Other wise try a "torx" type driver Theyve got either 8 or 12 splines on them, Ive used them before with good results, If all else fails Local hobby shop!
gt
Old 01-02-2003, 09:12 PM   #848
ill see if i can buy the hudy hex driver thingy's
what are splines?
Old 01-02-2003, 09:21 PM   #849
what are splines?
Splines are the number of ribs on the driver, Dont buy one dude take the car to the lHS theyll probly do it for you on the spot!
gt
Old 01-02-2003, 09:42 PM   #850
ok
luckily my lhs is accross the road from me
does anyone know if the special heatsink for the gs-15r comes with bolts for it?
Old 01-02-2003, 10:12 PM   #851
Default sl
ok
does anyone if the special heatsink for the gs-15r comes with bolts for it?
Im pretty sure it comes with shims but no screws.
gt
Old 01-02-2003, 10:58 PM   #852
darn
ill jusy buy some
Old 01-02-2003, 11:54 PM   #853
Wow, now I have to buy some new screws! That settles the rear but what about the front? Changing to a one-way will solve this
Do I really need to get the one-way?
Old 01-02-2003, 11:56 PM   #854
just put some liquid sealant around the diff that should hold in the oil :P
Old 01-03-2003, 12:04 AM   #855
Can gasket sealant works?
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
