Old 12-26-2002, 03:03 AM   #736
sausage_link's Avatar
Send a message via ICQ to sausage_link
youu have a leak
if your car is stock than thats way to lean.. try between 1 and 1/4 and 1 and 1/2
i used to run my car that lean and i ended up stuffing my flywheel bearing and that left oil everywhere because it leaked so check that out.
does the car stall alot and is it really hard to start?
sausage_link is offline   Reply With Quote
Old 12-26-2002, 03:12 AM   #737
Yep car stalls all the time and can never start it. I noticed it slid around alot. My tires are standard it was hard to drive, any tips on setting my two speed?
svranjic is offline   Reply With Quote
Old 12-26-2002, 03:38 AM   #738
squizzytaylor's Avatar
Default Re: Help
Originally posted by svranjic
Hi
I Raced my car for the first time today, but when i looked at it it was covered in castor oil. I tuned the engine properly and set the high speed needle at 1 turn outwards. Should i run it any leaner or is that not the prob. I have some probs starting the engine and gettin it to idle properly if this is any help
Shane
Shane, who told you to set the high end needle at 1 turn?
as a general rule I say start at 2-2 1/2 turns and work your way in, thats heaps rich but what has happened to your car is exactly why! Also check that you havent had a fuel line fall off or tear.
gt
squizzytaylor is offline   Reply With Quote
Old 12-26-2002, 04:33 AM   #739
Ok, I have set the needle at around 1 and 1/4. This has made it much easier to start. I have found where the fuel seems to be comming from and it looks like it is where the heatsink joins onto the engine. I am about to take the heat sink off and have a look.
How much oil shoild my muffler be spitting out also do i need to set the low speed needle or is that factory set???
Old 12-26-2002, 05:37 AM   #740
if that doesnt elimate the problem than u need a new flywheel bearing
i had the exact same problem, i ran it way to lean and the bearing behind the flywheel shat itself so i had to get a new one and it worked great, there not to expensive
around 15 dollars.
Old 12-26-2002, 05:40 AM   #741
Ok well tightening the heat sink seems to have fixed the problem.
Another questionm, if i want to race should i adjust the low speed needle???
Old 12-26-2002, 08:40 AM   #742
NitroNut's Avatar
so the only things i need for my new nova is engine mounts and linkages and that's it? ne more. plz help i am planning on buying it either today or tomarrow.
NitroNut is offline   Reply With Quote
Old 12-26-2002, 03:22 PM   #743
Default no no no no
you will also NEED an fd 49 flywheel!
gt
Old 12-26-2002, 07:46 PM   #744
that sux i have to get linkages as well
Old 12-26-2002, 08:48 PM   #745
NitroNut's Avatar
engine mounts,flywheel couldnt i use the flywheel from the stock engine? or diff one for sure and linkages and thats it
Old 12-26-2002, 09:05 PM   #746
NitroNut's Avatar
if a v1s with nova .12 engine and 2 speed wit a rb pipe kill or beat a gt4 rtr with stock engine?
Old 12-26-2002, 09:18 PM   #747
Default i repeat
THE 11TH COMMANDMENT
YOU CAN NOT FIT A STANDARD FLYWHEEL TO A NOVAROSSI AS IT WILL NOT MESH CORRECTLY AT THE PINION/SPUR.
nitro nut, be more concerned about getting around the track than hitting the wall at the end of the straight!
gt
Old 12-26-2002, 09:50 PM   #748
NitroNut's Avatar
no i know that imma have to practice like 24/7 but on straight will a v1s wit all those up hops beat a gt4 rtr?
Old 12-26-2002, 10:31 PM   #749
NitroJoe's Avatar
U better practice like 24/7 or I will smell my Nitro dust Are you want to go to R/C Perfromce tomorrow? nite nut
NitroJoe is offline   Reply With Quote
Old 12-26-2002, 11:15 PM   #750
Default mr nut
Yes I would certainly hope it would kick some Brokomo butt.
gt
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
