Old 08-12-2002, 02:21 AM   #46
Racmark's Avatar
Default Re: Squizzy
Originally posted by Vifer
Thanks for the link.
Been busy with work and nothing much to contribute though, so I kept quiet. Just found out last night that my stock shock gave way...so got to buy the Eagle shocks before this weekend. Going for some roundings down at my "playground".
Hope you have fun with your new setup. I always want to get a front one way for my car. A bit tired to see my tyres doing wheel spin when I full throttle out of a corner.
Hi Vifer!
Where is your playground in Singapore? Will like to meet up with more V1S kakis.
Racmark is offline   Reply With Quote
Old 08-12-2002, 04:15 AM   #47
Send a message via ICQ to V-One S
If you are running in the wet, id run as soft of a tyre as possible, and heaps of tread, and brakes in the dry i dont even use, i found itll go into the corner better for me with no brakes, so i only used the brakes to kick it around the 2 hairpins in our track
V-One S is offline   Reply With Quote
Old 08-12-2002, 07:21 AM   #48
Vifer's Avatar
Default Wet Weather
rhandee>
I really suggest that you don't play in any wet weather. First of all, your car is more prone to accident due to unpredictable tire slippage. Secondly, I had destroyed a brand new servo while playing on wet surface.
I would rather let my car live another day then killing it just for a short period of fun.
Racmark>>
Hi Racmark. I usually play at Marina South track or join another group of guys at Pasir Ris Carpark for heavy vehicles just beside TPE on weekends.
PS: U hav PM.
Vifer is offline   Reply With Quote
Old 08-12-2002, 05:56 PM   #49
Default WET Weather
Youre right vifer. even if the Battery and receiver is locked in....water still gets inside. and i also noticed that most of my screw starts to corrode after that wet race.
Next time i'l never play on wet grounds! Thanks guys!
rhandee is offline   Reply With Quote
Old 08-12-2002, 06:57 PM   #50
Racmark's Avatar
Default Re: Wet Weather
rhandee>
Racmark>>
PS: U hav PM.
Hi Vifer!
If you play at Pasir Ris and MS, I guess you would know a guy who drives a V1S too and just got himself a Serpent.
Old 08-13-2002, 04:27 AM   #51
sausage_link's Avatar
Send a message via ICQ to sausage_link
do you guys no if a set of hpi r5's will fit my v1s???
sausage_link is offline   Reply With Quote
Old 08-13-2002, 07:04 AM   #52
Vifer's Avatar
Default Re: Re: Wet Weather
Originally posted by Racmark
Hi Vifer!
Need more info...
Old 08-17-2002, 08:40 PM   #53
squizzytaylor's Avatar
Default Another body
Man this painting addiction is getting silly, This is the new HPI S7 saleen....super low not too long but racing is the real test....next weekend.
GT
squizzytaylor is offline   Reply With Quote
Old 08-21-2002, 12:51 AM   #54
Default heeeeeeeeeelllllllllllllllllppppppppppp
Has nebody got a picture of a v-one rear sway(roll) bar installed?
I bought a venom one today and im ^&%$ed if i can work out how it goes on!!!!!!!!!
GT
Old 08-22-2002, 05:28 PM   #55
Send a message via AIM to Infineon
Hey have you guys had expirience with the Kawahara Negative Zero differential? Does it work better than stock? Alsomy the clutch on my GS15R is pretty worn. What should I replace it with?
Infineon is offline   Reply With Quote
Old 08-23-2002, 01:19 AM   #56
Default Infineon
Firstly the clutch, why is it wearing? these clutches are really good wearing units, is there anything binding in the drivetrain?
Anyway Kyosho do a "vespel" clutch part #39673, really hard wearing!
On the diff- the neg-gear diff is really cool and will prevent unspooling through corners.....a pretty dear option though.
What is the car doing that makes you want to change the stock unit? Once again the stock diffs are a really good unit and can be tuned really well with the right diff oil to suit whatever you want to do. My v-one-s currently runs a one-way on the high speed track I race seriously at however on the rough track which i call home i run the standard diff with Mugen50000 wt oil in the front.
Do Tell
GT
Old 08-23-2002, 01:43 AM   #57
Lol, well...I liek to hold the brakes, high rev it, and launching the car . Also, I want the diff simply cuz it looks cool and its easy to adjust.
Old 08-23-2002, 02:53 AM   #58
Default mmmmmmmmmmmmmm
yes.........................well.................. .....if ya got it......................spend it.............................just make sure its on a Kyosho not one of those other inferior cars.
Old 08-23-2002, 03:02 AM   #59
How do you manage to hold the brakes at the same times as revving?
do you just lock them on when the car is set stationary and adjust right up tight?
and if you want burnouts, just drop the drive belt to the front wheels. It will get seriously sideways with the GS15-r.
Old 08-23-2002, 12:20 PM   #60
I just hold the brake with my hand then let go.
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
