V-ONE S Thread >
V-ONE S Thread
V-ONE S Thread
Old 03-06-2007, 05:45 PM
  #4576
Chaya's Avatar
apply a loctite to fasten your bolt. Usually they use loctite if there is a metal to metal contact ( bolt & engine mount) , before I have the same problem, what I did is I replace the existing screw with a flange cap screw ( although the head is potruding a little ) but much better than a screwed spur gear
Chaya is offline
Old 04-09-2007, 03:37 PM
  #4577
My v-one s has a O.S. .18 CV-RX engine... massive power. I wore down my 1st gear... replaced it... I'm really curious to find out if the new V-one SIII 2 speed can be modded onto the V one S I. If it wears down again, i'll try this out.
tiNtiN is offline
Old 07-19-2008, 08:49 PM
  #4578
Hi
Judging from the pic below. Do you guys think its a V-one S or SII?
Aero is offline
Old 07-19-2008, 11:22 PM
  #4579
ozpall's Avatar
v one s, i have one that is good for parts if you need it, all it needs its a motor and the 2sp.
ozpall is offline
Old 07-20-2008, 05:34 AM
  #4580
I'm actually trying to decide to get that or a RS4 Evo. The rs4 look newer but when I was looking at that pic it looks kinda dirty (which was said to be run only a few times). Both are $300.
Aero is offline
Old 07-20-2008, 08:48 AM
  #4581
ozpall's Avatar
i have 2 rs4 for sale, one has the 15 engine which i believe thats the evo and the other one has a 12ss, both run really good, they are not new but they run good, one of em needs a pullstart but i was using the starter box for it. i also have a starter box for sale. let me know what you need, i make you a deal, i have too much stuff that i don't have time to use.
ozpall is offline
Old 07-20-2008, 08:50 AM
  #4582
ozpall's Avatar
the reason i don't drive the v one s, is because is too hard to get parts for it, but that was the best car i ever had, the rs4 are great too and easy to find parts but man i gave hell to the v one s and it always run great and its very very strong.
ozpall is offline
Old 01-27-2009, 10:13 PM
  #4583
Default Need some info(need to get the V-one going
Hi all,
I have a V-one-S. The original version. When I built it couple of years back, I probably one had a 1 litre of fuel through that thing before I put it in storage.. Anyway, recently I am getting back into it. It is completely stock.
I took it for a run over the weekend and it runs quite well.. that is after I took the engine apart to clean it and sealed it up... was all gummed up ( lucky I put in some after run before I put it away)
I have been reading this very useful thread.
I am planning to add a 2-speed and a tuned pipe to my unit. I know I will have issues sourcing parts...
I have a spare OS12cvx engine which I might add at a later stage..
I have some questions.
1. The site mentioned in this thread http://go.to/solaspeed is down.. has it been moved or is permanently down.
2. I am keep on the fuel tank mod. coz, I did notice some bubbles in the fuel line. Is it just putting o-rings in the screws , to fix it ?
3.I am curios on the 2-speed mod to make it last longer.. anyone know where to find info on this.
4. What's a good(not too expensive) tuned pipe that I can use on the GS15R and then possibly on my OS12cvx.
cheers
PeNT is offline
Old 11-24-2013, 09:24 PM
  #4584
Thumbs up VOne S
Hi Guys,
Does any one of you have a new or used / mint condition VONE - S alloy chassis for sale? Other alloy V-One S parts ie GS .15 clutch set with flywheel is welcomed too.
So let me know thanks. I will need them to be shipped to Malaysia. If you paypall account i can make the payment directly.
Cheers!
Partiben
partiben is offline
Old 07-06-2014, 07:19 PM
  #4585
Anyone still out there driving their V One S? I still bash mine all the time!
Quickfinger is offline
