Old 05-08-2005, 02:36 PM   #4486
bugoy21's Avatar
Send a message via Yahoo to bugoy21
Originally posted by bulletdays
tol send me an email tapos magrereply ako sayo para masend ko ung manual through email.. nasa bahay kasi ung file tapos na cut pa internet ko pero promise tom.. send ko sayo.tnx
pare, i sent you a pm regarding my email
bugoy21 is offline   Reply With Quote
Old 05-14-2005, 09:49 AM   #4487
Chaya's Avatar
Default oil comming out from engine
Just need your advice guyz. ..
I tried running my V1S2 this afternoon, and after several lap, when i checked the under chassis, there is a lot of oil dripping from the engine side. . .
all i can remember is that i adjusted the mixture to leaner mixture about 1.5 turn from close position. . .
Did I broke my engine. . . What do you think guyz???
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 05-16-2005, 02:09 AM   #4488
bulletdays's Avatar
Default Chaya
Try to check, the rubber sealing in the manifold, remove your muffler and manifold, and check the rubber if its worn out, if it is.. replace with a new one...
secondly... try to see where the leak is comin from, Try to check the thread where you put the glow plug if its already lost thread, needs a replace.
i dont think you broke your engine...
bulletdays is offline   Reply With Quote
Old 05-18-2005, 05:52 PM   #4489
Chaya's Avatar
Hey thx a lot Bulletdays. . .
I just checked my car based from your advice and forund out that the gasket on the exhaust manifold was already worn out. . . i have already replaced it & I will try to run it this coming saturday. . .
By the way, also got a UM210 clutch shoe and fitted it last night. . using the washer from my 18teeth pulley ( spare from 2 speed replacement ). It just fitted very well plus the E -clip as suggested by solas. . .
Tnx again kabayan. . .
Old 05-18-2005, 11:51 PM   #4490
bulletdays's Avatar
Default Chaya
Anytime just tell me how does it go after replacing the gasket, you should have plenty of that gasket coz those things really worn out easily.
UM120 is a good clutch, even before i used it also, it makes the car easier to drive.. but i prefer you get the 3 pcs rubber clutch for vone S...
Goodluck kabayan, sana kahit konti may naitulong ako.
Old 05-19-2005, 01:12 AM   #4491
Chaya's Avatar
to bugoy21
Bossing,
Does your 2 speed already functioning. . .
Old 05-19-2005, 11:46 PM   #4492
bugoy21's Avatar
dude hindi pa, hindi pa kase ko nakakabili eh hehe
Old 05-20-2005, 10:18 AM   #4493
Hey guys, so my connecting rod bearing blew and scratched all my internals up last summer. and i havent run my v-one s ever since.
i tryed to find replacement parts off of towerhobbies.com but there discountinued. soo my question is what engine should i get that is similar performance wise to the gs15r? Thanks
tiNtiN is offline   Reply With Quote
Old 05-21-2005, 04:08 AM   #4494
Chaya's Avatar
based from my research:
current stats on .12 & .15 engines
.12 & .15 Engines Peak HP MAX RPM
HPI .12R Nitro Star Pro SC 1.00 35,000
HPI .12R Nitro Star Pro SC P - Evo II 1.25 34,500
HPI .15 FE Stock RTR 0.56 29,000
NovaRossi .12 CX12P 1.00 34,000
NovaRossi .12 EX P 1.00 34,300
NovaRossi .12 RS 1.35 36,000
NovaRossi .12 RS T 1.35 37,000
NovaRossi .15 CX 1.20 33,000
NovaRossi .15 CX R 1.30 34,000
NovaRossi .15 TX 1.35 34,500
Ofna .15 R Force Outlaw 1.15 34,000
OS .12 CV-R series 1.00 33,000
OS .15 RX 1.20 33,000
Traxxas .15 Stock 0.78 28,000
Trinity Picco .12 1.25 34,000
Trinity Picco .15 1.30 34,000
This list is no longer updated as new engines come out about every month.
You can pick your own choice form the above table. But you have to remember that yu can use only threaded shaft. . ( same type of your GS15 engine. . .
by the way. GS15 engine has 0.56hp. only. . . So if you want better performance engine. you can check the above items. .
hope this helps
Old 05-23-2005, 08:19 AM   #4495
bulletdays's Avatar
Try to get OS 12TZ the new one its good or OS 12TR.
Old 05-23-2005, 11:20 AM   #4496
thakns Chaya and bulletdays
too much info
ive only been messing with rc cars for 2 years now so im a newb!
wow .56 hp only?? lol and i was is shocked by the speeds
Old 05-23-2005, 04:37 PM   #4497
Oh and, i was wondering if these engine mounts would work for my v-one s chassis...
ebay link...
http://cgi.ebay.ca/ws/eBayISAPI.dll?...sPageName=WD1V
or better, what engine mount are you guys using?
Old 05-23-2005, 05:57 PM   #4498
Chaya's Avatar
ebay link...
I think that is the same engine mount offered as option part for V1S/V1S2. . .You can check the kyosho site just tobe sure. . .
Old 05-23-2005, 06:13 PM   #4499
Kyosho mounts use 3mm screws.
3434 is offline   Reply With Quote
Old 05-23-2005, 06:35 PM   #4500
coo but you dont think 4mm wont fit?
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
