Old 04-14-2005, 02:56 PM   #4456
Originally posted by Chaya
OK misterlister.
Thanks again. We'll wait for that post. . .
well i finally got 10 mins to put together some quick instruction on how to use an mtx2 gearbox on a v1s
V1s meets MTX2
MisterLister is offline   Reply With Quote
Old 04-15-2005, 10:23 AM   #4457
Chaya's Avatar
thanks again. MisterLister. . .
It would help a lot of newbie guyz out here. . .
Till next time. . .
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 04-15-2005, 10:57 AM   #4458
is it true dat changing the pinion can increase the speed of the stock V1S2 engine?
ArEa_51 is offline   Reply With Quote
Old 04-15-2005, 04:09 PM   #4459
Chaya's Avatar
hey Bro,
Check this link. . .
Maybe it can help. . .
[/url])http://download.teamassociated.com/p...HandbookV2.pdf
Old 04-15-2005, 07:47 PM   #4460
thankz...it helped
Old 04-17-2005, 04:42 AM   #4461
Default 3 shoe buggy clutch on novarossi
Just stumbled across this thread and thought I would share my V-one SII...I know I will be able to learn alot
Pics of my car and a shot of a Cheap but good modification.. can lengthen the life of your exaust for the cost of a pen spring ! ....know its been done before however thought I would share my version on my V-one SII....
Exhaust MOD
http://img.photobucket.com/albums/v3...IMG_0050-1.jpg
Car Body
http://img.photobucket.com/albums/v3...y/IMG_0007.jpg
3 shoe buggy clutch MOD with Nova pullstart
http://img.photobucket.com/albums/v3...y/IMG_0046.jpg
cheers rob
Bad Inferno is offline   Reply With Quote
Old 04-17-2005, 05:00 AM   #4462
Default Re: 3 shoe buggy clutch on novarossi
Exhaust MOD
Car Body
cheers rob
can i ask??! wat do the spring do at the exhaust?? can someone pls explain...totally haf no idea of how it functions...
Old 04-17-2005, 05:03 AM   #4463
Default Exhaust
Oops sorry..If you drive like me and when you hit something instead of your stinger bending it allows the exhaust to move into the car by 1/2" and the spring takes some of the impact.
Old 04-17-2005, 05:11 AM   #4464
ic...so the spring acts as a shock absorber for the exhaust?
thankz for the explanation
Old 04-19-2005, 03:48 PM   #4465
ralliartlanevov's Avatar
Send a message via AIM to ralliartlanevov
i have a v one s with a sirio s15 turbo engine... i got a eagle motor mount and the engine still doesnt seem be long enuf to tough the spur gears.. i was wondering wat kind of motor mount is best for this engine..
ralliartlanevov is offline   Reply With Quote
Old 04-22-2005, 01:22 AM   #4466
Chaya's Avatar
http://img.photobucket.com/albums/v...ay/IMG_0046.jpg
What 2 speed did you use with your modification. Did you also use the stock 2 speed which originally came from V1s2 or different???
Thanks. . .
Old 04-22-2005, 05:44 AM   #4467
Default Clutch
No its the v-one R clutch I think.
Old 04-22-2005, 06:17 AM   #4468
Default Re: tires
Originally posted by Kyosho_GTR
Hey guys, thank for teaching me how to tune the two speed.
By the way what type of tires you all always use..
I try before buying 1 pair of tires and found out that the rim will vibrate when i turn it faster... So care to recomem any brand??
Generally I use power tires but it's really about our driving style. the harder the tire the lesser the wear and grip. The softer the tire the better the grip.
You should try with the different compounds to find out which suits your driving style.
I've done soft.. and found that the rear wear was very high.... result of me running harder rear stablizers and harder springs.
That said, I switched to a harder rear compound to test. thus far which my current driving style, i've experienced less rear end slippage while having lesser wear.
ajlim is offline   Reply With Quote
Old 04-22-2005, 06:27 AM   #4469
Chaya's Avatar
Default 3 shoe buggy clutch MOD with Nova pullstart
Well done Mr. Bad Inferno.
Does the V1R clutch spur gear and the 3 shoe buggy clutch pinion gear fits well. . .By the way what the gear combination. Spur & pinion???
Tnx. . .
Old 04-22-2005, 06:40 AM   #4470
Default Clutch
It does not line up well and you maybe able to see a spacer between the clutch and the nut where the shoe spring has to sit. this was so the pinoin and spur lined up. trouble with moving the engine over was the exhaust manifold hit on the rear housing. Would not really recomend this unless you had a nova cx12p and you are trying to fit it into a v-one
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
