Old 04-03-2005, 07:38 AM   #4441
Originally posted by Chaya
Adjust the gear shift timing to your engine and the track with the 3x3mm set screw. As you tighten ( turning cw) the set screw , the shift timing becomes slow, and as you unscrew it ( turning ccw) the shift timing becomes quick. Adjust the timing by unscrewing the 3x3 set screw by 1/4 turns actually while running the car. Match the timing to the specific track conditions.
Start from 3.5 turn from close position.
Good luck! ! !
Don't over tighten your set-screw. The number of turns is dependent on the track type. I've always found it easier to make big changes either way to determine the when the two-speed kicks in.
I set it from the flush position and turn CCW or CW depending on when it kicks in on the track that I am running at.
ajlim is offline   Reply With Quote
Old 04-03-2005, 10:31 AM   #4442
Chaya's Avatar
Default V1S two speed mod.
Originally posted by misterlister
V1S two speed mod.
I have used the Mugen MTX2 gearbox and clutch. the only things that needed to be changed was the spacer between the bulkhead-gears and the rear support/brake brace for clearance on the second spur gear.
just wondering what engine are you running with these type of modification.
does the MTX2 fits very well on the spur gear shaft???
Can you share some tips regarding this mods...
Tnx. . .
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 04-03-2005, 02:51 PM   #4443
the mtx2 spur gears fit directly to the shaft, no mods required on the shaft or spurs. mod required on the brace just to clear the second gear spur.
i found it easier to fit the spurs into place then align the engine to the spurs with a multi position engine mount.
the engines i am using are MT-12 and Sirio 12 TUPPRO
hope this helps
MisterLister is offline   Reply With Quote
Old 04-03-2005, 04:06 PM   #4444
Chaya's Avatar
hope this helps
Hey thanks a lot sir
by the way, Does the mtx2 spur gears runs in 2 speed??????
Maybe you can share some pictures here. .
Thanks again bro
Old 04-03-2005, 04:44 PM   #4445
i have been asked by a racing pal for instructions on how i did the mod, once i have written them i will post a link to the doc.
but it a simple 2 speed mod using the complete mtx2 gearbox and clutch
Old 04-04-2005, 05:10 AM   #4446
Chaya's Avatar
OK misterlister.
Thanks again. We'll wait for that post. . .
Old 04-06-2005, 09:28 PM   #4447
Chaya's Avatar
Hey Guyz, , ,
Have any one tried installing sirio engine or any racing engines in your V1s2 and using the same 2 speed intended for this model. . .
I have heard from some feedback that this kind of setup would destroy your spurgear on 2 speed. . .they say that V1s2 tranny is not designed for high performance engines. . .
Any comment guyz. . . .
Old 04-07-2005, 02:42 AM   #4448
joel's Avatar
Hey Guyz, , ,
i have a V-one SII installed with a novarossi racing engine and no problems so far with the 2-speed.
joel is offline   Reply With Quote
Old 04-07-2005, 09:02 AM   #4449
Chaya's Avatar
really, great then. . .
So can you give some tip. What mod did you do. . .Did you still use the same clutch bell which comes frm the stock ( GS15engine, if so did you also use the UM210 clutch disc...)
By the way Bro are you a filipino
Thanks in advance. ..
Old 04-07-2005, 09:51 PM   #4450
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
Send a message via AIM to kyoshoBOY
Hey Guyz, , ,
pare alang problema don,kahit anong makina pede.
fren ko mas gusto nya gamitin ung gear ng V1S2 sa V1RR evo nya kaya switch nya,ala naman ako nakitang problema.
kaya ok lang na maglagay ka ng malakas n makina.
kyoshoBOY is offline   Reply With Quote
Old 04-08-2005, 03:00 AM   #4451
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
bro what modification did you do? thought that the S-II only uses short shaft engines
buboy28 is offline   Reply With Quote
Old 04-08-2005, 08:38 AM   #4452
Chaya's Avatar
Pre salamat sa info. Muntik ko na binenta yung v1s2 ko. . .
Bitin na kc yung speed ng GS15. kaya isip ko bili ng malakas na makina. may nag feedback lang na d daw pwede sisirain yung gears. . .
Thanks again. . .
Old 04-08-2005, 11:30 PM   #4453
joel's Avatar
with a bit of modification on the main tranny shaft, I got an old two-speed transmission set(alongwith the adjustable clutch set) for v-one rr and installed it on the main tranny shaft.
and yes I'm a pure filipino.
Old 04-11-2005, 03:32 AM   #4454
Post tires
Hey guys, thank for teaching me how to tune the two speed.
By the way what type of tires you all always use..
I try before buying 1 pair of tires and found out that the rim will vibrate when i turn it faster... So care to recomem any brand??
Kyosho_GTR is offline   Reply With Quote
Old 04-11-2005, 09:08 AM   #4455
Chaya's Avatar
I try before buying 1 pair of tires and found out that the rim will vibrate when i turn it faster... So care to recomem any brand??'
I used New arrows racing tires. GRP gandini.
Very good grip
front tires: 26mm width x 45 shores
rear tires: 30mm width x 45 shores
The tires comes with foam and mags in pre assy condition.
Hope this helps. . .
You can visit www.grpgandini.com
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
