Old 06-17-2004, 02:30 AM   #4276
Sp Racer's Avatar
sounds to me like either the glow plug is a dud or the bottom end mixture is too rich..
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 06-17-2004, 10:08 PM   #4277
i too think that the glowplug is faulty but i lost my wrench!
ben1112 is offline   Reply With Quote
Old 06-20-2004, 08:11 AM   #4278
Adoika's Avatar
Upper rods
I am looking for some titanium upper rods for my V-one-sII. Am I able to fit the 92509's? They are 20x3 whereas the regular ones are 20x4. Does anyone know if there is a adjustable titanium upper rod in this size or will I have to source the links in 3mm size?
Cheers,
DA
Adoika is offline   Reply With Quote
Old 06-29-2004, 04:42 AM   #4279
I think I have some problems with my engine gs-15r.
The thing is that the fuel line has bubbles, the one to the carb, I have checked the lines and the tank and it is not any leak there.
One thing more the car is faster at half throttle but thats is because I have my high needle at 2 turns right??
Please check this tread and help me
johan798 is offline   Reply With Quote
Old 07-01-2004, 11:26 PM   #4280
Default v one s
Any v one s's out there for sale.
dinovones is offline   Reply With Quote
Old 07-01-2004, 11:54 PM   #4281
Do you take 500 Singapore dollars VoneSII stock with MX-3 full set transmitter?
Old 07-02-2004, 05:50 AM   #4282
BrainTeased's Avatar
You getting rid of your VoneS already? whats next FW-05?!?!?! hehe
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-02-2004, 08:56 PM   #4283
empty's Avatar
two things to check that can cause this;
Is the fuel cap seating correctly?
On the V1S-1, the fuel tank has a habit of rubbing on the chassis near where the fuel line comes out. You may need to scallop out a little bit of the chassis to it doesnt rub.
On both models, make sure that you put little o rings on the fuel tank screws to absorb some of the vibration from the engine.
empty is offline   Reply With Quote
Old 07-03-2004, 11:41 AM   #4284
NUT
Default 2 SPEED TRANS
IM RESTARTING THIS HOBBY AND ABOUT TO BEGIN ASSEMBLING MY V-ONES WHICH I DISASSEMBLED A YEAR AGO, BUT THE PROBLEM IS, I MISPLACED THE INSTRUCTIONS FOR THE 2 SPEED. CAN ANYBODY SCAN IT AND POST IT, BECAUSE IM NOT FAMILIAR WITH THE PARTS, AND I HAVE MIXED THEM WITH OTHER PARTS OF MY MK2.
PLEASE HELP. THANKS
NUT is offline   Reply With Quote
Old 07-06-2004, 01:32 PM   #4285
Adoika's Avatar
Default 2 Speed
Nut, PM me your details and I will send a copy of the instructions if you still need them.
Old 07-06-2004, 01:35 PM   #4286
Adoika's Avatar
Default Rear foams
Does anyone know what parts and or modifications I need to do to fit 30mm foams on the rear?
Old 07-07-2004, 04:23 AM   #4287
when i had my VoneS i just let the foams grind the rear uprights. although you can file them if you want. file it where the rim touches the upright.
Old 07-09-2004, 08:48 AM   #4288
To fit 30mm's you need to get the V1RR out drives they come with a 2mm washer which makes the fit perfect.
frozenpod is offline   Reply With Quote
Old 07-11-2004, 06:39 AM   #4289
MRWRX_69's Avatar
Default Re: Kyosho Factory hop-ups
Originally posted by squizzytaylor
OK here they are ......the new chassis and carbon fibre top plate.
and that is a v-one-r fuel tank.....I guess its not as tidy as the standard v-one-s but its definately got a bit of testosterone going on.
(I've got a spare carbon plate for $70.00, if any Aussies interested
PM me)
hey in ur pic u hav the manifold that goes down, to make the pipe parralel with the chassis
may i ask wat brand pipe it is and were you got it from
thanks
http://www.rctech.net/forum/attachme...&postid=181335
MRWRX_69 is offline   Reply With Quote
Old 07-13-2004, 05:46 AM   #4290
guys can u link me or tell me thae page on what i need to do the rear floating pod conversion. And how much is it too if possible, thanks
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
