Old 06-06-2004, 09:15 AM   #4261
i think it's called a clutch bearing. do you need me to find the number for you? im busy, if u desperately need it then tell me.
ben1112 is offline   Reply With Quote
Old 06-06-2004, 04:11 PM   #4262
Yeah I desperately need it because without it, I can't run my baby .
Thanks Ben
If you there's no part number for it, would someone be able to make the measurements of it ?
The outer and inner diameter and also the length, I could try the bearing factory to see if they have something in that size.
Thanks in advance!
elim is offline   Reply With Quote
Old 06-07-2004, 02:19 AM   #4263
LD70 is the number. clutch bearing. i just went to the website to download the manual, find the part number. easy as 1 2 3.
Old 06-07-2004, 02:21 AM   #4264
dude I'm terribly sorry!
Dazza has found out for me aswell !
FFS so stupid of me to completely forget about the exploded view. I kept looking at the 2spd manual and not the main car.
Thanks a ton dude!
Old 06-07-2004, 04:00 PM   #4265
dazza's Avatar
Send a message via ICQ to dazza
The joy of ICQ
dazza is offline   Reply With Quote
Old 06-07-2004, 08:33 PM   #4266
Indeed !
Old 06-08-2004, 01:06 AM   #4267
Can anyone tell me how much will it cost to do the rear floating pod? roughly in USD. Thanks lots.
Old 06-08-2004, 07:07 AM   #4268
hey guys. there's a problem with my engine. it will not run properly, there is always dark coloured fuel inside the engine. this is what i do: i took apart the engine, use clean fuel to rinse the insides, assemble and run. it can idle properly, but when i rev it, it stalls at a certain rpm. i suspect there is a clutch problem as well. the glow plug always seems to be soiled by dirty fuel. help me pls
Old 06-11-2004, 09:28 AM   #4269
Dude to rich or to lean go to a good hobby shop and get the write info.
V1S racing is offline   Reply With Quote
Old 06-11-2004, 07:23 PM   #4270
BrainTeased's Avatar
It sounds like your air filter is dirty to the point the dirt is covered solidly inwhich when you give it full throttle @ high RPM the engine lacks Air. have you cleaned your air filter? as i've ran my VoneS for 4 weeks and my engine was practically very clean inside!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-12-2004, 08:52 PM   #4271
xax
Can the v one r carbon plate b fix on the S? i had replaced the shocks wif those from serpent n handling is great but it is legal to use it for race?
xax is offline   Reply With Quote
Old 06-14-2004, 01:11 AM   #4272
I changed the clutch and cleaned the filter. when i fire it up, it idles and then stalls. my mate stripped the screws so i cant see the glow plug. How? Help me guys...
Old 06-14-2004, 08:03 AM   #4273
What exactly does oil in the differential do?, I dont have one just wondering.
johan798 is offline   Reply With Quote
Old 06-16-2004, 12:43 PM   #4274
Adoika's Avatar
Wow! Unbelievable thread guys congrats. Heaps of info for someone like me who is just starting, although it did take me a week to finish it
Adoika is offline   Reply With Quote
Old 06-16-2004, 03:17 PM   #4275
dazza's Avatar
Hi Ben1112,
Check the head bolts, exhaust bolts, and the screws that hold the carb on. Sounds like an air leak to me. You may even want to change the fuel lines.
Dazza
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
