Old 10-26-2003, 03:21 AM   #3871
sausage_link's Avatar
Send a message via ICQ to sausage_link
I would say use 15 or 16
sausage_link is offline   Reply With Quote
Old 10-26-2003, 07:25 PM   #3872
weeee, v-one s II arrived on friday, thx XR400 and v one s racer
Rained over the weekend, but left me time to double check i assembled it correctly, touch wood, also time for the motor to idle through its tanks of fuel in the shed whilst raining,
I have no work today due to the weather over the weekend, and its now stopped raining, just had its first oppurtunity to run it out the front, wahey, shes a beast, even just puttering it around its smoooooth as silk, nice note from the motor, and suspension playing its part just as i had hoped
Will take a bit, but you'll see me at a few of the melbourne tracks for shits and giggles, especially castlemain, as Ballarat doesnt have scheduled races.
Hope to see some you'se there
Doff
doff is offline   Reply With Quote
Old 10-26-2003, 08:15 PM   #3873
uB3r_V-one-S's Avatar
Question
Hey guys me again...
Sounds good doff, i was hoping to upgrade my S to an R that i found really cheap but couldnt sell it off ... anyway i have ANOTHER question about ANOTHER engine fellas. So tell me what you think, if it will fit the S and so on.
Also if it did fit what i would have to change (if i had to) and if it would be compatible with the V-one-S 2-speed tranny...
Anyway this time i wont forget it but here IT is, it's an EPIC Pull Start Slide Carburetor .18 Nitro Engine
Here's the Specs and also a pic
SPECS: Displacement: 0.18 cu in (2.95cc) Output: 1.8HP @ 39,000 RPM Weight: 6.88/6.82oz (195/193.2g) Crankshaft size at threads: 0.196" (5mm)
FEATURES: True .18 displacement Short stroke/high rpm Slide carburetor with high and low needles Oversized ball bearings Standard, non-turbo glow plug Red anodized cylinder head with "EPIC" silkscreening Pilot Shaft (SG) crankshaft
Thanks in advance AGAIN guys
DB
uB3r_V-one-S is offline   Reply With Quote
Old 10-26-2003, 09:42 PM   #3874
Default Re: Question
DB
That engine won't fit because it's got an SG (Serpent) crank... for a V-One S you want an engine with a Threaded (Standard) crank.
V-One S Racer is offline   Reply With Quote
Old 10-26-2003, 11:29 PM   #3875
I recommend 16%. Go to
http://go.to/solaspeed
to see the mod they do to stop the wear on the second gear of the 2 speed.
Ryan
VoneS II is offline   Reply With Quote
Old 10-27-2003, 12:43 AM   #3876
Exclamation Not so sure...
I'm not so sure about the crank being wrong but you can get it in either Threaded or SG
Check these out and please give me another opinion:
http://www.nitroreview.com/compare/compareengines.cfm
http://www.epicmotorsports.com/
(if needed click Big Bore .18 Line of nitro engines) The EP 1800 model is threaded so...)
I'm really considering purchasing this motor if it will fit and be compatible with the V1S 2-speed (without moding it)
Cheers
DB
Old 10-27-2003, 02:29 AM   #3877
The engine SHOULD fit if it is threaded crank. V-one S only accepts threaded.
Old 10-27-2003, 03:55 AM   #3878
lee82gx's Avatar
i know this may sound repeated,
does anyone have a copy of the RCCar action touring car edition of 2003?
in it,one of the articles was :how to replace an rtr engine,and as model the V1S was used and the GS15R was replaced by a SG crank .18Sirio.
there wasnt any specific instructions,but the pictures say a lot.
i wish to know WHAT flywheel is that?
all u guys , do get a copy ,and have a look ok?
lee82gx is offline   Reply With Quote
Old 10-28-2003, 03:26 AM   #3879
Hi guys,
What's your opinin on this.
http://www2.towerhobbies.com/cgi-bin...?&I=LXEZV6&P=V
Ryan
Old 10-29-2003, 09:31 PM   #3880
Originally posted by VoneS II
Hi guys,
Ryan
It's hard to say without actually trying it... even harder for me since I don't own a V-One S any more !
Old 11-02-2003, 02:50 AM   #3881
Registered User
GTone's Avatar
hi !
look at the modif on the V-One S, the servo of the direction and a gaz are below radio platinium !!!
the modification was made on the car of my friend.
GTone is offline   Reply With Quote
Old 11-02-2003, 02:59 AM   #3882
Registered User
GTone's Avatar
other photos
Old 11-02-2003, 03:00 AM   #3883
Registered User
GTone's Avatar
Old 11-02-2003, 08:08 PM   #3884
lee82gx's Avatar
GTone:
wow!!
got anymore details on that modification?
bon jour!
Old 11-04-2003, 12:12 AM   #3885
Thats quite a interesting little mod there GTone
who makes the radio plate and have you got any better pics of the mod and more info ?
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
