V-ONE S Thread
Old 09-22-2003, 03:27 AM
  #3691
sausage_link's Avatar
Hey will either of these 2 speeds fit on the S?
here and here
sausage_link is offline
Old 09-22-2003, 04:08 AM
  #3692
Thanx guys!!
Ryan
VoneS II is offline
Old 09-22-2003, 05:04 AM
  #3693
phildee's Avatar
Originally posted by VoneS II
Thanx guys!!
Ryan
No Probs, its a real pain in the butt to replace if ya gonna do it yourself, u need to strip the engine right back to just the block and bearings, heat it up in the oven to a bit over 200 degrees and they should be easy to get out. same for putting the new ones in ya goto heat it up
phildee is offline
Old 09-22-2003, 08:22 PM
  #3694
I didnt need to heat it up to put em back in
They slotted right in.
You could try a bearing hammer... They have the rubber end.
Old 09-22-2003, 10:26 PM
  #3695
will the lhs do it? I never pulled my engine apart is it easy to do?
Ryan
VoneS II is offline
Old 09-22-2003, 10:59 PM
  #3696
This is a fairly new engine (had around 5 ltr of fuel through it
) should this be happening? could it just be normal (that a little of fuel is coming out) ?
Ryan
VoneS II is offline
Old 09-23-2003, 12:12 AM
  #3697
phildee's Avatar
Ryan
Mine did it before 5ltrs, it may or may not be the bearing I guess, some lhs' will do it for you some wouldnt I guess, ud have to ask them
Cheers, Phil
phildee is offline
Old 09-23-2003, 01:54 AM
  #3698
Yeh mine did it when it was reasonably new my LHS did it the first time.
Then it happened again so i did it my self. It was 15 dollars from LHS. For me to get the bearings and put it in my self worked out to like 3 dollars. But thats because my uncle got the bearings as he does that kinda of stuff.
Old 09-23-2003, 04:14 AM
  #3699
Ifixed it, the bearing wasn't sitting in right.
Ryan
VoneS II is offline
Old 09-23-2003, 04:23 AM
  #3700
Nice one
So there is no more oil ?
Old 09-23-2003, 06:35 PM
  #3701
Trader Rating: 15 (100%+)
I have a brand new GS15r for sale if anyone is interested.
* never used
* new in packet #8 OS glow plug
* length of fuel tube
PM or me me an offer
Dave
nitro dave is offline
Old 09-23-2003, 07:23 PM
  #3702
Franky's Avatar
V one S II, nice car. just wonder what insert is better for rubber at the track mrccr?
my v one s II, only 1/2 ltr thru it. still in run in process.
already so fast. i am bidding a two speed for it.
should i use harder insert for the front, softer for rear?
Franky is offline
Old 09-23-2003, 08:36 PM
  #3703
I'd start with harder front/softer rear and see what you think, but I tended to use the same insert & tyre combo front & rear... mainly out of laziness and then I just thought bugger it, i'll just use foams !
V-One S Racer is offline
Old 09-23-2003, 10:34 PM
  #3704
lee82gx's Avatar
lee82gx is offline
Old 09-23-2003, 11:29 PM
  #3705
it all depends on what rubber you use, it the track has high or low grip, etc. but I use softer on the rear. Now I mainly use foamies and find ellegi to be the best.
Ryan
VoneS II is offline
