V-ONE S Thread
#3676
PLEASE HELP
#3677
Re: HELP
Originally posted by VoneS II
I started my car 2day and it was going about 40kays, from what i see all lines are fine, glow plugs fine, got tuned night bfore at hobby shop, but there is a little fuel coming from somewhere.
Ryan
Ryan
Where abouts is the fuel coming from? Front engine bearing is a problem sometimes.
#3678
I think its about time i checked the setup one my car... and gave it a bit of a clean
I need a new one way for my pull starter
#3679
Originally posted by NitroJoe
Hi ND
I saw you car on ebay and I saw the GPM Alloy threaded shocks front and rear and Carbon top plate set. Could you tell me where I can get those 2 thing.
thanks,
Hi ND
thanks,
#3680
I don't know, can't see where its coming from. I think I was running a bit lean bcause it was hot yesterday.
Ryan
Ryan
#3681
Originally posted by nitro dave
carbon plate i got from southern cross hobbies, shocks i got from a friend. but anywhere that sells GPM should get them, about 50 a pair.
Do you still have to do the 2 speed mod with them ?
#3682
last i saw stu had some GPM parts there, i guess he could order them in if you need them, or, i could supply them to you.
With the derlin gears, i stripped a couple (but that was uiser error ) and you dont have to do the mod (but you could if you wanted to make it stronger). i noticed that it still wears through the metal housing like it does with the plastic gears.
its a lose, lose situation unless you put a colt 2 speed on it or convert a v-one r gearbox to suit but then you have to make up new shafts etc (ive seen it done, looks good but takes too long to make).
#3683
Hmmm
So it has metal housing and it still wears thru...
Bugger
Has the Colt 2 speed got thicker gears ?
Bugger
#3685
Does it require much work to fit it ?
#3686
Ryan
Ryan
#3687
That must be it bcause thats where the fuel is after running the car. How much does it cost to replace? Does tower hobbies have it?
Ryan
Ryan
#3688
Is it really necessary to replace this?
Ryan
Ryan
#3689
You definatly need to replace them if they are leaking. Otherwise your engine will run strangely.
#3690
I got my bearing from MBA www.minibearings.com.au they are 689Z (17mm x 9mm x 5mm) any decent bearing shop should keep them but they were a lot cheaper online
