Old 09-13-2003, 12:03 AM   #3631
lee82gx's Avatar
another question:
how do i set the front droop?
i understand the rear is set via drop screws,i dont know how to adjust the front.
lee82gx is offline   Reply With Quote
Old 09-13-2003, 12:16 AM   #3632
The suns out its stop raining I just need to wait for the track to dry up a bit more and I can race.
Ryan
VoneS II is offline   Reply With Quote
Old 09-13-2003, 12:33 AM   #3633
sausage_link's Avatar
Send a message via ICQ to sausage_link
Originally posted by lee82gx
yes i actually tried it both ways,and guess what?
the wrong orientation will cause the piston to jam on downward stroke,that means there's only one way to fit it.
no c clips huh?ok,must've come from somewhere else.
Yeh i was thinking that it should only go in one way
The front is set via droop screws as well... just behind the front bumper
If you take it off you will see it... but you dont have to take the bumper off to set the droop as there is little holes to get there
sausage_link is offline   Reply With Quote
Old 09-13-2003, 01:19 AM   #3634
phildee's Avatar
Send a message via ICQ to phildee
Its raining here and Im in the bed with the flu
phildee is offline   Reply With Quote
Old 09-13-2003, 04:11 AM   #3635
lee82gx's Avatar
ahhh..i have finally settled tuning my V1S...
engine is 10%rich..2 speed is shifting...i'm all set for the track!bring on the top guns hehe..j/k.
getting foams and ditching the rubbers for now.
Old 09-13-2003, 04:16 AM   #3636
lee82gx's Avatar
yeah i see the screws,but don't u think that the links are made of soft plastics which can't really make too much difference?
i had some tweak on my car,and after much fiddling with the shocks(thank god for the adjustable shocks i have )
i was lucky to have 3mm droop , and it seems like the lower limit already.
can u guys get 2 mm?if yes,then it might be my springs.
Old 09-13-2003, 07:15 PM   #3637
its still raining this is bulls#*t I can't race .
It rains for ten mins then stops and just when the track isalmost dry enough to race it starts raining again.
Ryan
Old 09-14-2003, 10:42 PM   #3638
Why does god hate me? All I want to do this weekend is test my car and hopefully try some new springs, and what does the Melbourne weather do? nothing but rain and hail. Now I have to wait until next weekend to play.
Dishy is offline   Reply With Quote
Old 09-15-2003, 03:33 AM   #3639
xGSiR's Avatar
hows everyone going?
where is squizzytaylor?
xGSiR is offline   Reply With Quote
Old 09-15-2003, 03:55 AM   #3640
Hi,
Fine thanx.
Don't know.
I am going to TTP to race my car 2morrow and it doesn't matter if its raining bcause its under cover.I suggest u guys should go to an under cover car pack to. If its got a low ceiling the car sounds wick.
Ryan
Old 09-16-2003, 08:13 PM   #3641
lee82gx,
I have been thinking about this for awhile and I can't figure it out. How is it possible to have too much grip on the frount end? shouldn't I be aiming to get as much grip as I can on all four tyres, therefor shouldn't I be aiming to match the extra grip I have on the frount end with more grip on the back end. more grip all around not less. Hope this makes sense.
Old 09-16-2003, 09:20 PM   #3642
I think generally you want to find a balance of front and rear traction and set it the way you want and they way you like it.
Old 09-16-2003, 11:22 PM   #3643
So are you saying better to have less grip but balanced then more grip but unbalanced. what I mean by balanced is between under and over steer.
Old 09-17-2003, 05:02 AM   #3644
lee82gx's Avatar
Originally posted by Dishy
lee82gx,
well i disagree.
i had ur problem once(too much front grip , no rear) and i tried to cure it with harder front tyres.in the end i got an oversteering car in high speed and understeering car in low speed.
what u should do is fix the butt first,then fix the front.
do this by finding the proper rear tyre/spring/droop combination 1st.
then go on to the front and repeat(but might seem like ur front is ok)
remember,an understeering AND oversteering car goes in the right direction but on the WRONG LINE
Old 09-17-2003, 06:30 AM   #3645
what i mean is not the same on both ends but having just a balanced setup... like symetrical
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
