Old 09-11-2003, 01:31 AM   #3616
Default foamies
I put a little more toe in alround and found this helped but it still handles a little different but worth the extra grip.
Ryan
VoneS II is offline   Reply With Quote
Old 09-11-2003, 03:58 AM   #3617
lee82gx's Avatar
after reading ur posts/advice and the sola link,
i feel the urge to upgrade to the UM210 clutch.
anyone knows how to differentiate the UM210 clutch and the regular one?
I'm asking this as i think mine looks like the UM210 , but not exactly.
I bought my V1S used,and i have no idea whether it's been changed or not.
lee82gx is offline   Reply With Quote
Old 09-11-2003, 06:02 AM   #3618
phildee's Avatar
Send a message via ICQ to phildee
UM210
http://www2.towerhobbies.com/cgi-bin...?&I=LXSC16&P=7
Stock Clutch
http://www2.towerhobbies.com/cgi-bin...?&I=LXT919&P=7
you should be able to work out which is yours
phildee is offline   Reply With Quote
Old 09-11-2003, 06:08 AM   #3619
lee82gx's Avatar
ok thanks.
i have the stock ones...
should've thought of tower,they have pictures that even Kyosho doesn't have.
Old 09-12-2003, 07:32 AM   #3620
lee82gx's Avatar
guys:
i'm rebuilding my engine after a bust up.more on that.
i need to know which orientation is the piston.at the bottom of the piston,it is longer on the bottom on one side and shorter.
as i look from the rear,ie removed the backplate
should the longer end be on the left side or the right?
Old 09-12-2003, 06:14 PM   #3621
sausage_link's Avatar
Send a message via ICQ to sausage_link
I dont quite understand what you mean...
Explain better
sausage_link is offline   Reply With Quote
Old 09-12-2003, 06:32 PM   #3622
lee82gx's Avatar
in the picture i attached,how should the cicrcled part of thepiston be oriented?
Old 09-12-2003, 06:33 PM   #3623
lee82gx's Avatar
also,as i pulled apart the engine,i THINK an 8mm C-clip just fell off.where does it belong?
Old 09-12-2003, 06:47 PM   #3624
Ok i think it should go facing the exhaust port... but i cant actually remember and the manual doesnt show that bit...
Get someone to clarify it.
Old 09-12-2003, 08:02 PM   #3625
Yep, the lower part faces the exhaust port .
C-clip .... never seen one in my two engines !
V-One S Racer is offline   Reply With Quote
Old 09-12-2003, 09:20 PM   #3626
Yeh i've never seen a C-clip in my engine either.
Must have come from somewhere else.
Old 09-12-2003, 10:31 PM   #3627
Default weather
Its raining I cant use my car
Ryan
Old 09-12-2003, 10:35 PM   #3628
Default Re: weather
Ryan
That means it'll be heading over here... and I'm supposed to race my EVO .
Old 09-12-2003, 10:57 PM   #3629
its a bummer ant it
Ryan
Old 09-12-2003, 11:49 PM   #3630
lee82gx's Avatar
yes i actually tried it both ways,and guess what?
the wrong orientation will cause the piston to jam on downward stroke,that means there's only one way to fit it.
no c clips huh?ok,must've come from somewhere else.
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
