Old 07-15-2003, 05:40 AM   #3436
Sp Racer's Avatar
If I can sort out my engine problems ill be comming fo rall of ya
I'll sort those out for you ....no probs
Sp Racer is offline   Reply With Quote
Old 07-15-2003, 06:37 AM   #3437
Taylor-Racing's Avatar
Originally posted by Sp Racer
......for those here that don't know, V-One S Racer is the best Michael Schumacher look a like I've seen!...specially with that red hat on!
(post a picture Ryan!)
glad the setup worked for you!
LS
Ohhhh, that's who he is . . .
Yes, Ryan, your car looked good on Sunday . . . . a lot better than ours.
Taylor-Racing is offline   Reply With Quote
Old 07-15-2003, 07:24 PM   #3438
phildee's Avatar
Send a message via ICQ to phildee
did you get my pm, iv completely stripped and rebuilt the engine making sure everything was snugg and tight I cant think of anything that would have caused it to be so lean, ill have my kyosho pipe/manifold and 2 speed tommorow probly so ill put it all back together and try to sort it out
phildee is offline   Reply With Quote
Old 07-15-2003, 07:53 PM   #3439
phildee's Avatar
Got my 2 speed an pipe already!
Cant figure out this mod, there is a steel pin in the plastic bit, where do I put the extra one
Old 07-15-2003, 10:34 PM   #3440
Trader Rating: 15 (100%+)
when racing at penrith last night, i spoke to a friend who did a pretty neat conversion on his v-one s. He has a 2 speed but not the kyosho 2 speed, a Colt 2 speed! apparently it fits straight on with one very minor mod which is to cut away a small amount od plast on the bulk head. these gears are twice as thick as the std gears and last heaps longer. he also has a kyosho 3D centax clutch and a stupidly modified RB that can outrun even some of the fastest rear exhaust engines.
i'll try and get some pics soon.
nitro dave is offline   Reply With Quote
Old 07-15-2003, 11:18 PM   #3441
Default Alternative 2 speed for V1S
Pardon me,what is a Colt 2 Speed?? Other 2 Speed transmission that can be used on V1S are from Hyper 10 and Thunder Tiger. And you need to put some spacers to match the position of the gears,the pinion and spur. So nitro dave, your friend is more advanced cause he is using the Kyosho 3D clutch.Hope to see your pics soon.
Cilla is offline   Reply With Quote
Old 07-16-2003, 12:22 AM   #3442
LS
You get a photo put in Racing Lines like you said you would !
You're not the only one who thinks I look like him, Ron Wilson said I do too ! Is it something with you Kyosho Cup boys..... ?
V-One S Racer is offline   Reply With Quote
Old 07-16-2003, 12:33 AM   #3443
Thank ya ! First outing with the new car and I like it !
Old 07-16-2003, 09:59 PM   #3444
Franky's Avatar
Default cooling fan for V 1S
ANy one try the cooling fan , is it able to cool down without cutting a air inlet in the front windscreen?
i am planning to buy one. anyone give me some advice.
i am using a stock engine, and another is OS CVX12 engine,
is it ok? on both engines?
anyone can share their photos with the cooling fan???
Franky is offline   Reply With Quote
Old 07-16-2003, 10:20 PM   #3445
Franky's Avatar
Default the pic of the fan
here is the pic of the fan.
Old 07-16-2003, 11:51 PM   #3446
Franky, I think you do not need that. The holes in front and at the back of the windscreen are already enough for the cooling. Better save your money for a good heatsink head.
Old 07-17-2003, 12:20 AM   #3447
Franky's Avatar
i am thinking without a hole in front. will improve the speed and aerodynamic, and that will offset the lost power in the cooling fan,
those EP cars have better downforce without the hole.
also, looks nice.
Old 07-17-2003, 03:34 AM   #3448
Default gs15r engine breakin
hi
i have a gs15r engine which i will run on 10%nitro what plug would i use . i think it should be a os A3
also what are the standard high speed needle setting for running rich in break in please
plus (heres a biggie) how do you think i should break it in
thanks for any help.
geoffrey is offline   Reply With Quote
Old 07-17-2003, 04:58 AM   #3449
Franky's Avatar
Default Re: gs15r engine breakin
Originally posted by geoffrey
hi
ask your local shop, or
open to a setting that u run the car in full thro but still slow. around 10-20 Km/h, really rich, then, close a little bit by bit, 1/8 a tank, till u find a good speed and also watch carefully the temp variation. never exceed 120. i suggest u use 16 or 20%. no need 10%.
Old 07-17-2003, 05:37 AM   #3450
Does anyone know what is happening with the Kyosho Cup in Australia this year? thinking about giving the tamiya a miss and having a play with the noisy cars.
Please advise
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
