Old 11-28-2002, 10:06 PM   #331
squizzytaylor's Avatar
Default v-one s
look at the photo...when you build these it actually specifies to trim the corners as shown in the photo.
gt
squizzytaylor is offline   Reply With Quote
Old 11-28-2002, 10:07 PM   #332
AMGRacer's Avatar
but what was amg talking about to do with trimming the brake holder?
Yep you are right it is the two little "raised" bits in the brake holder. They need to be cut down on an angle to prevent them clipping (just hitting) the brake pad.
My car and a NTC3 did a roll off the other day. The NTC3 only just out rolled my car by around 2 feet over a distance of about 12 feet. And my car DOES roll very far by itself with just a push.
AMGRacer is offline   Reply With Quote
Old 11-28-2002, 10:09 PM   #333
Send a message via ICQ to V-One S
looks like it is time to pull down the car then
So do i have to oil the bearings in it heaps?
and is your rolling with engine in it, or withi\out?
V-One S is offline   Reply With Quote
Old 11-28-2002, 10:13 PM   #334
Default re rolling resistance
I remember you mentioned that before..its bizarre, the v-one-rr being over driven "should" have a higher resistance than any 1:1
front/rear car. The v-one-s seems to always have had a little resitance. After you mentioned that before I tried it v-one-s vs v-one-rr and the rr won.
gt
Old 11-28-2002, 10:14 PM   #335
AMGRacer's Avatar
Things you can do to get the V1S rolling VERY well.
1. Pull out all bearings, clean them and lube them with a light oil. I do not encourage removing bearing shields from a nitro car.
2. Replace the belts with the SP belts available for the V1RR.
3. Replace the pulleys with the hardened pulleys available for the V1RR (I dont think all pulleys can be replaced)
4. Replace the shafts with lightened shafts.
5. Ensure the brake pad is not dragging at netural throttle.
6. Remove all debris from pulleys and belts (if you are not replacing them)
Old 11-28-2002, 10:16 PM   #336
AMGRacer's Avatar
Default Re: re rolling resistance
gt
If you run the gear diffs on each end and then overdrive the car then you are right, the rolling resistance is very high. I use a one-way in front and a gear diff in the rear, which is another way to reduce rolling resistance.
The par number VZ008B (hardened pulleys) and the SP belts make an enourmous difference. I was skeptical myself but owning a R then a RR I coud immediately tell the difference.
Old 11-28-2002, 10:16 PM   #337
Ok thanks the advice
Old 11-28-2002, 10:19 PM   #338
Default re re rolling resistance
All pulleys are replaceable (kawahara even do the 2-speed pulley).
rear and side belts are available (sp)
gt
Old 11-28-2002, 10:23 PM   #339
If im guna replace the pulleys, should i wait till i get the 2-speed, or do u use the same puylleys whihc are already on, (no new ones given)
Old 11-28-2002, 10:34 PM   #340
ozone's Avatar
really appreciate all the infos ... juz stripped the car... and found out the pulleys are in bad condition...tink i gotta replace them... qn do i need to use only v1s pulleys or i can use v1r or rr...
ozone is offline   Reply With Quote
Old 11-28-2002, 10:40 PM   #341
Ok guys
How fast would a DEAD STOCK V-One S go
I mean nothing has been changed at all.
Just give me a figure in the km/h please.
Old 11-28-2002, 11:53 PM   #342
sausage_link's Avatar
Send a message via ICQ to sausage_link
My stock v-one s went 70km/h
I know this because i live near a main road and most of the cars do 70km/h as it is the speed limit and i kept up with them
another thing i found that cause the car to catch when its rolling is rocks stuck in your insides of your rims and they get caught on the things that you adjust the toe in on, i forgot what there called is it hub carriers?
ive had this problem alot and they leave some nasty scratch marks on the inside of your rim
sausage_link is offline   Reply With Quote
Old 11-29-2002, 12:14 AM   #343
Default questions
ozone
Some of the pulleys are the same as the v1r, the 2 speed pulley is different.(r and rr have different large pulleys)
The alum pulleys will last forever however are slightly heavier than the stock ones.
v-one s. A full set of pulleys goes for about $20.00 (stock)
gt
Old 11-29-2002, 12:20 AM   #344
Jack's Avatar
Default Re: questions
ozy,
the RR pulley is different from the R ..
the RR is using 25teeth and the R is using 27.
however the rest of them uses the same 18 and 19 teeth pulley
there is pros and cons for using alum pulleys. but i perfer to use the plastic pulley. they are light and they last pretty long.
Jack is offline   Reply With Quote
Old 11-29-2002, 12:35 AM   #345
ozone's Avatar
u guys r great...thanx...
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
